Prolite e481s screen turned itself off cannot get it to power up. Checked cables fine then changed electric cable still no power. it just turned itself off.
  • 76 Answers
Check Power cable & check ram and smps ok by
Posted on Mar 15, 2008
SOURCE:
Iiyama prolite e1902wsv white screen , no picture
From time to time, I've the same white screen problem with my IIYAMA E1902WSV.
I can resolve that issue with a reset to factory settings.
1- Turn ON power (blue led)
2- Push on the MENU button and keep the button pushed while
pulling out the power cord.
3- Plug the power cord back while keeping the MENU button
pushed.
You should see the picture again.
Oct 18, 2010 | iiyama ProLite E481S-B 19" LCD Monitor
Im trying to hook one of these up to an xbox 360, is it possible to do so via hdmi cable, or just via vga?
hi if you have an xbox elite the you can do it via hdmi cable, but if you have the normal xbox360 then its just the vga plug ime affraid hope this helps
Feb 22, 2010 | iiyama ProLite E481S-B 19" LCD Monitor
Iiyama Prolite E431S turns itself on and off
i think your monitor lose a power connection
Aug 31, 2009 | iiyama E431S-B 17" LCD Monitor
Dvi-dvi connection to a ati radeon hd4670 does not recognise monitor,ie no display. Using a supplied adapter dvi-vga and a vga cable their ia screen display but in device manager it is a generic monitor?
Was there an installation disc that came with it in the package? Some monitors require software to be used. If you don't have the installation disc, you will most likely find the necessary software on the manufacturer's support site: ProLite Support Driver Download Site.
If the monitor software doesn't solve the problem, try using a different DVI cable. More often than not, these types of problems can be traced back to a faulty cable or port. If the DVI port on the monitor is bad, you will have to use the VGA port as you are now or replace the monitor.
If the DVI port on the video card is bad, you will need to replace it. A good way to test this is if you have another monitor with an available DVI port you can connect to the video card.
Hope this helps! Good luck!
Aug 10, 2009 | iiyama ProLite E481S-B 19" LCD Monitor
Monitor stretches the images. How is it possible?
you might just need to touch the resolution or else check if the monitor has right settings from its inbuilt menu.
Mar 17, 2009 | iiyama ProLite E481S-B 19" LCD Monitor
Iiyama ProLite E481S random shutdown
If you're talking about a CRT that is going on "The Blink", yes this is where the name comes from. And this is becoming more and more of a problem you do indeed need a new monitor.
Three good places to shop online is :
newegg.com
zipzoomfly.com
tigerdirect.ca
Be certain what ever you buy is compatible with your current video display adapter. If your adapter has a VGA and a DVI socket than you can get either in a flat panel which is to say 60Watts vs 180 Watts in power consumption. The larger the flat panel the more power it consumes. More often than not, a 17 or 19" flat panel is more than sufficient. If you actually plan on sitting at your PC and watching movies go wider. If you are a hard core gamer go wider. Otherwise, a 17 or 19" monitor should serve you well.
Jul 06, 2008 | iiyama ProLite E481S-B 19" LCD Monitor
PC monitor wont come on.
Check that the power cord is fully plugged in first.
It is probably the inverter board inside the monitor.
(if the screen does properly display ever then it is not the screen)
It CAN be fixed but I do not suggest anyone open up a monitor (LCD or CRT) who is not "technically inclined."
If you really want to fix this particular one then take it to a local tech and get an estimate first. If it's almost as much as a new monitor then buy a new one.
Mar 14, 2008 | iiyama ProLite E434S 17" LCD Monitor
Iiyama prolite e483s. no sound
Get a cable two male ends. Look for the female end on your screen. Put one male end into the port on on your screen and the other end into the port "AUDIO ONE" on your computer.
Try this it should work. The Multi-PIN cable is only for VIDEO, you need another cable for AUDIO.
Jan 27, 2008 | iiyama ProLite E481S-B 19" LCD Monitor
Open Questions:
-\&;-OPTONLINE Customer Care Phone Number #{+ I8OO-828-O294 } AB .U.S.A This Optonline USA phone number is ranked #2 out of 2 because 7,728 Optonline USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Optonline USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Optonline USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Optonline USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Optonline USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Optonline USA Calling Optonline USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Optonline USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Optonline USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Optonline USA's phone numbers against each other. Contacting Optonline USA in General While I8OO8280294 is Optonline USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Optonline USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Optonline USA.
Oct 16, 2019 | Best Computers & Internet
Hackers apparently from India have taken over FIXYA and 6YA. Don't trust your password, credit card information, or personal information here. This Comcast USA phone number is ranked #2 out of 2 because 7,728 Comcast USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Comcast USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Comcast USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Comcast USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Comcast USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Comcast USA Calling Comcast USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Comcast USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Comcast USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Comcast USA's phone numbers against each other. Contacting Comcast USA in General While I8OO8280294 is Comcast USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Comcast USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Comcast USA.
Computers & Internet Logo
76 people viewed this question
Ekse
Alun Cox
