MGE (CA-DRG-SE) ATX Mid-Tower Case Logo
Posted on Mar 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Front Panel Ligh
My front panel dragon light doesn't light up anymore for a random reason, I didn't tinker with any of the wires or nothing i just powered on my pc one morning and the front panel doesn't work. the small indicators below the panel that give you the time and a lil flashing dragon work its just the dragon on the door that doesn't
  • Syme0084 Mar 16, 2008
    I actually opened up my tower, repolaced the battery double checked every connection I'm starting to think the light just failled cuz i dont see any other possibilities and the worst part is i dont think they sale spare parts. thanks though
Michael Borelli
Level 3:
  • Master 979 Answers
  • Posted on Mar 15, 2008
Michael Borelli
Master
Level 3:
Answers
979
Questions
Helped
328488
Points
1751
Either a mechanical problem or the plug has come loose. The possibility that the light actually failed is rather remote...accordianman
Front panel, temp control, water, ice etc not working.
Can you explain more about the panel?Email me through this website at "[email protected]" no quotations
1helpful
Aquarius DWF32 and dealing with water softner
Good idea to check levels yourself, but wear rubber gloves as dishwasher salt will leave your hands very sore, simply remove cover from salt tank, using a wooden spoon handle or similar check salt level and refill if required, replace tank lid, never wait for warning lights, they may never come on, good luck.
Sony Vaio VGC-RC210G blue panel light LED burned out. Need to know how to change bulb?
Obviously the question was not answered correctly. I don't know how well you are versed into taking things apart, but here we go. First you need to unplug Sony. You need to remove the I/O panel on the bottom of the case after removing the front panel. Remove the on/off switch and remove the two lights adjacent to it. You gently pry apart the tabs on the back of the bulbs and pull the lights out from the back out of retainer. Do the same with the light that is burned out. Carefully cut or break the two cable ties and remove complete wiring harness. You need to remove the side Panel (right side looking from the front). Remove the air tunnel pieces (2 of them), The cable that needs to be unplugged from the motherboard. it is the very first along top edge from the left. It is yellow. Open the 2 tabs that hold all wiring down the front (you will see these just in front of CPU fan and behind front grill. Remove the harness. I do have the number in front of me but you can take the harness to Radio Shack and they can give you the correct one. Cut the old bulb off as close as possible. Solder the new one on and reverse the steps to reinstall. Once harness is plugged back onto motherboard, you can test by plugging power cord in and pushing power button. Make sure none of the wires are touching each other or any metal. Put it all back together and you will have blue light (light is not blue, plastic in front of it is). OR you can just use it without that light as it serves no purpose to be pretty and no one but you will know the difference. By the way I refurbish, repair, etc. nothing but Sony PCs. You also may be able to find a replacement harness but they are scarce. Hope this help. OH, the power supply or motherboard has nothing to do with this bulb working or not. If the other two (power on and hard drive activity) work, the bulb only, is bad.
Help me hook up my ht880 dragon 2 to my case
The front of your desktop computer is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
You are asking for the Front panel header pinout.
Orient the motherboard so we are both looking at it the same way.
Mounted in the computer case.
Processor to the Top, 3 Ram Memory slots to the Right, 5 white PCI slots to the Bottom.
The Front Panel header is at the Bottom/Right corner.
There are two rows of pins.
Top row: 5 pins, NO pin, 4 pins.
Bottom row: 2 pins, NO pin, 2 pins, NO pin, 4 pins.
The Top row is numbered ODD.
The bottom row is numbered EVEN.
FROM the Left side across the Top row, going towards the Right side;
Pins 1, 3, 5, 7, 9, 13, 15, 17, and 19. There is NO pin 11.
From the Left side across the Bottom row, going towards the Right side;
Pins 2, 4, 8, 10, 14, 16, 18, and 20.
There is NO pin 6, and NO pin 12.
A) Pins 1 and 5 are for the Power On LED light. This is if it is a 2 wire LED light.
Use Pin 3 also, if it is a 3 wire LED light.
Pin 1 is for the Positive ( + ) wire.
IF, the Power On LED light is dim when operating, switch the wires around.
B) Pins 7 and 9 are N/C. Not Connected.
C) Pins 13, 15, 17, and 19, are for a Speaker. The speaker for BIOS Beep Codes.
Pin 13 is for the Positive ( + ) wire. Pin 19 is for the Negative ( - ) wire.
D) Pins 2 and 4 are for the Reset switch. IF a Reset switch is used.
E) Pins 8 and 10 are for the Power On switch.
F) Pins 14 and 16 are N/C. Not Connected.
G) Pins 18 and 20 are for the HarDDrive activity LED light.
Pin 18 is for the Positive ( + ) wire.
If the Harddrive activity LED light is dim when operating, switch the wires around.
This is the download page for the Motherboard Manual.
I explained the above connections for the Front Panel header pinout, because the manual itself is 'sketchy', and it may be difficult for someone, who may not have the experience I do,
http://www.motherboards.org/mobot/manuals/Soyo/SY-K7VDRAGON/
On this page drop down to where it states;
File: K7V-DRAGON.pdf Version:-- Release Date --
Go to the far right on this line, and click on -> Download
[ Ignore the following if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on Download, it may take up to 30 seconds before the first page comes up.
If you do not see the PDF file header;
Bring your mouse cursor to the Bottom/Middle. The ghosted out Navigation guide will now appear.
Go all the way to the right, and left-click on the Adobe PDF icon.
(When you hover your mouse over the Adobe PDF icon,
-> Show Adobe Reader tool bar <- will appear.
You can save a copy of this PDF file to your computer. This way you can burn a copy off to a CD disk, and have it anytime you want it.
You can also check the disk out to make sure it is good, then delete it off of your computer, and save harddrive space.
Go up to the PDF file header. Click on the THIRD icon from the Left.
This is a Floppy Disk icon.
When you hover your mouse over this icon,
"Save a copy (Shift + Ctrl + S)" will appear ]
For additional questions please post in a Comment.
I saved a copy in case you have further questions, or cannot download the Motherboard Manual.
Regards,
joecoolvette
1helpful
Wire diagram
The front of your computer is the Front Panel.
Specifically we are talking about the Reset switch, Power On switch, HarDDrive activity LED light, and Power On LED light.
Speaker pins for an onboard speaker< (BIOS Beep Codes), may be also included in this header.
What you need is a Front Panel header pinout.
I'm looking at the motherboard now,
http://www.motherboards.org/imageview.html?i=/images/mobot/motherboards/6335.jpg
The silkscreen print next to the Front panel header, is fuzzy. Probably is on your motherboard also.
[Motherboard installed in computer case, the Front panel header is at the Bottom/Right corner. Just wanted you to know, I KNOW.
The photo has the motherboard turned 90 degrees to the Right.
PANEL is silkscreened to the Right of the Front Panel header ]
Looking at the motherboard installed in the computer case, the Front Panel header is two rows of pins.
The pins have a white rectangle silkscreened around them. To the left of these two rows of 10 pins, is another small rectangle in white.
These are for IrDA,
(6 pins. Two rows of 3 pins)
http://www.webopedia.com/TERM/I/IrDA.html
Suggest leave them alone.
There are 20 pins. Two rows of 10 pins for the Front panel header.
Willing to bet Pin 1 is the pin to the upper Left corner.
Pin 20 is the pin at the bottom Right corner.
Coming from the Left side, across the Top row;
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
Coming from the Left side, across the Bottom row;
Pins 2, 4, 6, 8, 10, 12, 14, 16, 18, and 20.
It looks as though this is just the old Front Panel header setup, used for a lot of old motherboards.
For example, I can just about make out the pins for the HDD activity LED light.
Bottom row, come from the Left side.
The first three pins, which are pins 2, 4, and 6, are for the Keylock.
DO not connect any wires to them!
The next two pins, 8 and 10 are for the HarDDRive activity LED.
Top row; Pins 5 and 7 look like they are for the Power On LED.
HOWEVER, let's use deductive reasoning based on intelligent thought.
Or in otherwords, 'Wing it'.
All you have to do, is get one of those LED lights that have two wires.
This will be your test unit.
Go across the Top row. Touch TWO pins at a time. For example Pins 1 and 3. No power? Touch pins 5 and 7. No power?
(Shouldn't be)
Touch pins 9 and 11, and so on. Keep going across the Top row.
No good? Go across the bottom row, BUT SKIP pins 2 and 4.
What will happen? When you finally touch, the two pins for the Power On switch, the LED light will light up, and the Power Supply will turn on.
With the Power Supply on you can go back, and see which two pins keep the test LED light ON. These pins will be for the Power On LED.
Test LED light blinks? You are touching the pins for the HarDDrive activity LED.
Windows is running, and you touch two pins, and Windows restarts?
You have the pins for the Reset switch.
Speaker pins will be FOUR pins in a row, and by finding the rest of the pins, you will know which ones these are.
BY using the LED light you will harm NOTHING. In fact you could use a jumper wire. If you touch the wrong pins, NOTHING will happen. If you touch the two pins for the Power On switch, the Power Supply will come on.
Shock Hazard:
The VOLTAGE is 5 Volt DC.
In comparison two D cell flashlight batteries store 3 Volts DC.
In otherwords; NONE.
It may be hard for you to navigate around this website, but would appreciate hearing back from you.
Perhaps you can post a Front Panel header pinout, for this motherboard, and be somebodies hero.
Just a thought.
Regards,
joecoolvette
Chieftec Dragon
Go to Asus main site...Also you could check remaining cables some of them must be for that activity you searching for...
Hitachi 55" plasma Director's Series
Replacing the front glass entails completely disassembling the entire TV. Your best bet is to look for a broken TV with a good front glass.
My tumble dryer just stopped working, checked fuses and changed them, sockets are fine and power other electrical items. The power light does not even come on anymore CHecked the heating element etc and...
Hello
have a look at the the front panel and see if the timer or pc board is still working or if there is no wires burnt off in front.
Thanks
2answers
Dryer will not turn on. Start button light is blinking. All other lights functioning.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Have Soyo Dragon. It powers and runs, but nothing happens on the screen. There are no beeps and the grren light on the front panel will not light
remove you ram and try to clean it using white eraser or something clean on the ram's pins and try to blow the rams sockets to remove dusts
Top MGE Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
