Question about Refrigerators
Drain Hose in Refrigerator
I am getting water inside my refrigerator and would like to know how do I get to the drain hose
  • sapphy44 Mar 15, 2008
    Its a Kenmore (Top Freezer) model #78867891 (about 9 yrs old)
    I believe it has the drain hoses inside the shell.
  • wandajackson Dec 04, 2008
    My fridge has a bad smell. I cleaned it all out, took off the back to clean the tray and the hose but the smell is still there. How do I pour water down the tube to clean?
    Scholar:
  • 178 Answers
Depends on the refirgerator. Some drain hoses will be enclosed inside the shell, others will be expose around back draining into the evaporato fan on top of the compressor. If you post again, please include the make and model nuimber for more accurate assistance.
Posted on Mar 14, 2008
Liking water front door
You need to remove the panel inside the freezer compartment to access the evaporator rain line. Once accessed,you will see a drain hole. That drain has a hose leading to a pan in the back of the refrigerator; this drain is plugged an causing water from defrosting ice to drain to the pan in the back of the refrigerator. You need to unstopped that drain hose with compressed air and not chemical.
If you have any probem removed the panel inside the freezer, removed the cardboard panel to access the drain hose. Grab the hose and blow compressed air into it. Please note that you will be blowing back into the freezer compartment, and some cleaning will be necessary. The drain hole will then be opened.
Dec 16, 2010 | Hotpoint HSS25GFP Side by Side...
Why is there water sitting in my fridge: water
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 05, 2010 | Frigidaire Refrigerators
My refrigator is leaking water
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
hope this helpout ......
Aug 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer leaks water and the fridge is 43 degrees and full of condensation on the inside
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Hope this works...............
Jul 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Sometimes water is flooding to the bottom of the refrigerator.. I know the drain hose is stopped up. I found one end at the bottom in the back. However I can't locate the drain in the freezer to blow out...
The drain is behind the panel inside the back of the freezer. It is under the coil. You may need to run hot water through the drain line to defrost it before you can blow it out. Good luck
Apr 30, 2010 | Roper RT12VKX Top Freezer Refrigerator
There is water accumulating at the bottom of my refrigerator. How do i clear the drain or remove an obstruction?
You can try a flexible plastic tube strong enough to
go through the drain of your refrigerator. Better still
if you can buy, a 1/4 inch diameter flexible spiral
rod for manual declogging equipment. You can buy
it at the hardware stores.
Sep 25, 2009 | GE GTS22KBP Top Freezer Refrigerator
I keep getting water in the refigerator. Everything works fine, but the water just drips and drips
Hi
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 03, 2009 | Haier RRTG21PAA Refrigerator
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Water leaks down back of frig and pools under veg crisper
there is a drain hose that drains the frost from the freezer down to a drain in the botton of your refrigerator. then: to the evaporator tray under your refrigerator If the tube or, drain get clogged the water has no where to go and, pools in the refrigerator To fix this clean the hose with a coathanger or, stiff wire If you do not know where the hose is see the parts diagram for your refrigerator at: searspartsdirect.com
May 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking inside the refrigerator
Hi
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 17, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerators Logo
174 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
