Question about Kenwood KAC-8152D Car Audio Amplifier
Car amp amp is working now but it will shut off after about five minutes
    Novelist:
    Champion:
  • 219 Answers
Make sure your speaker load is right. When you use dual voice coil speakers or more than one speaker per channel and such it can get pretty confusing. If you are bridging the amp be sure you understand how to bridge correctly. It is different than a normal speaker hookup. Also be sure the amp isn't getting hot and that there is nothing blocking it from getting good ventilation all around it.
Posted on Mar 16, 2008
SOURCE:
Craftsman 100ac infinant amp arc welder just stopped working ....the fan still runs. anybody know what's wrong with it????
probably over heated and blew the reset button
100 amp welders have a duty cycle ( time in actual welding use ) of less than 20%
that means for welding for five minutes you have to let it cool down for 20 minutes
the lower the amps the longer you can weld for
beware tat the total amperage of the welder does not mean that you can weld for a long time at that amperage
on the plate on the welder is the duty cycle and you have to be aware of it or the machine will shut down
Apr 18, 2015 | Craftsman Welding Tools
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Trane xe1200 compressor fan motor only runs for about five minutes
Than it's not wired correctly. Did you splice the motor wires? Black on left, common to cap which should be the right from contactor and fan which I think, without looking, is brown. purple common...
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jan 17, 2018 | Heating & Cooling
We have a tempstar down draft furnace. 2 years ago the heat exchangers where replace because we were told they were cracked. This year the downdraft motor was makikg a lot of noise & we were told the...
Sounds like the low limit or high limit is out these control the fan motor.They are usually set to kick on around 150 degrees and set to go off around 95 to 100 degrees. Over heating does happen with cracked heat exchangers and it can possibly take these two items out. Normally your furnace should run approximately five minutes or a little less then your fan motor comes on and then for cooling down burners should drop and the fan motor should run again roughly five minutes or so then shut down. Times may vary as to your settings.
Dec 20, 2010 | Heating & Cooling
Where is the fuel pump relay located on a 1988 ford f150
under the hood in front of the brake cyclder
Jul 09, 2010 | 1988 Ford F 150
My alpine is a five channel, at low volume it works fine. when you crank it up it will stay working for about two minutes then shut off. How can I resolve the issue
You are overloading your amp... the best way is to have it tested with a multimeter and make sure that your speakers are in the correct impedance load range for your specific amp
Mar 21, 2010 | Car Audio & Video
Subwoofer Help
check the amp. the "switches" gain,bass boost...etc they might be over powering your subs and heating them up. if those are fine then you mite want to try your subs on another amp...it migt just be that the subs are easily over heating.
Aug 26, 2009 | Rockford Fosgate Car Audio & Video
2004 s40 volvo-ac works for 10 minutes then gets warm.
evaporator leaking or condensor fan inop
Jul 31, 2009 | 2004 Volvo S40
Shuts down after about five minutes and wonr
If it runs really rough before shutting down it is most likely a spark plug.
Jun 29, 2009 | Watts Onan Portable Generator - 4000 ,...
Door speakers don't work and it shuts off after five minutes
Shorted speaker wiring?? Check with a multi meter to make sure that speakers test at 4ohm and no wires are shorted to ground.
Jan 26, 2009 | Alpine IVA-D300 Car DVD Player
Car Audio & Video Logo
67 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
