Question about Samsung SGH-V200 Cellular Phone
Swicth not working
Message appearing in screen "paused by temperature"
  • Anonymous Sep 28, 2008
    I have charged my phone on the screen appears "battery fully charged", but when i switch on the phone the screen reads "Paused by Temperature".
    can somebody help with this problem? It has been going on for along time now. Thank you.
  • rhinegold Jan 23, 2009
    It is not possible to charge the battery as 'paused for temperature' message appears. I have already tried a new battery.
    Does anyone have a remedy as this mobile still has a long and useful life?
Power on/off button print is brake now then tell me what can i do to repair it
Posted on Jan 09, 2009
Please ineed your help v200 power key solution
Posted on May 25, 2012
6ya staff
SOURCE:
Hi I'm having this message, 'low oil pressure' when temp go to suitable temperature my car Peugeot 407
The engine bearing clearances expand with heat which, if excessive, will lower the oil pressure. The spring in the pressure regulator in the oil pump will cause the pressure to drop for the same reason. A partially plugged oil intake screen will work in conjunction with the oil pump to cause it too.
Nov 15, 2015 | 2009 Peugeot 407 2.7
Trying to reset Region Code on Toshiba SD290EKB
I used the settings recommended Power on, Open the drawer, key in 9879 slowly, pause for a 3 second delay then type 0, all via the remote and a message appeared on the screen saying Region Code now set to 0. I can now play Region 2 and region 1 DVD. Well done and thanks for all the hard work. God bless. Be encouraged. The truth is out there!
Aug 07, 2009 | Televison & Video
The washing wont spin or drain i replaced the lid swicth didnt work
Set the washer for spin and turn it on.
If it does not spin, open then close the lid and see if it spins.
If so set the timer for regular wash. When the timer gets to the final spin it should PAUSE a few seconds. The transmission will lock in, then it should spin.
If you do not get the PAUSE in the timer at the beginning of the spin cycle the timer is bad.
If you do get the Pause and it does not spin the transmission is bad.
Mar 18, 2009 | Whirlpool Washing Machines
Region unlock for LG DV480
If you have the LG DV 480 then try these steps
1 Turn the DVD player and open the disc draw, leave it empty
2 Press Pause
3 Type 0000
4 When the blue screen appears type "0" in the new region code
5 Press Pause
6 Power off the DVD player then turn it back on
It worked for me
Mar 15, 2009 | Televison & Video
Start/pause switch works intermittently. How do I
i have found that the micro switch burns out on them and needs to be replaced. remove rear screws remove top cover , remove shield the unclip cables and front panel
Use a multi meter to test micro swicth on circuit board replace if faultsy
Mar 06, 2009 | LG WM2077CW XL Front Load Stackable Washer...
Phone
at first you do the swicth off your mobileand remove your battery also upto 15min after swicth on your mobile then go the settings >phone settings>in that is given default settings select it after some min again swicth off and swicth on after u send the message
Jun 03, 2008 | Nokia 6111 Cellular Phone
Open Questions:
Samsung SGH-V200 Cellular Phone Logo
152 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
