Question about Car Audio & Video
Car audio i have a kenwood amp and it will cut off after about five minutes of playing
  • Tygh Duval
    Tygh Duval May 11, 2010
    • What is your setup (i.e. what speakers, are they wired directly, bridged, etc)?
    • Does the amp turn back on at any point?
    • Where is the amp mounted?
    It sounds like the typical symptoms of an overheating amp, but it depends on how it's set up.
    Problem Solver:
  • 9 Answers
Bde505 gud noon..Stop playing the unit.. it is in harm right now..Check the connections of the speakers if there is a short circuit...besure to set up the power tighly..then try it..If the problem still exist..bring your unit to the nearest repairman bcause there's a problem on ur power amplifiers..thanks
Posted on Mar 17, 2008
Kenwood reciver cutting off
Sounds like it is going in protect. You probably have shorted output transistors in the amp.
May 26, 2013 | Audio Players & Recorders
Need a wire harness plug for a kdc319
Kenwood adapter looms are readily available from your local Auto Accessory store, of from Ebay.
These are a 'plug & play' solution (pre-wired), which eliminates the need to cut any of your existing vehicle's wiring.
Ideally, you want a single adapter loom with Kenwood plug on one end, with your vehicle's "factory" plug on the other (all common brands are available).
e.g. Kenwood ---> Ford; Kenwood ---> GM etc etc
Cheers,
Dec 30, 2012 | Kenwood KDC-319 CD Player
After driving for about thirty minutes my amp will just cut off, it seems a little hot and then it will turn back on in about 10 minutes. I'm not playing my music loud at all and I have all kenwood...
sounds like your speaker is either the wrong resistance for your amp ie your amp may state 4 ohms and your speaker is 2 ohms which means that the speaker is shorting out the amp and its going into protection mode or the speaker could be burning out and shorting out the amp
May 30, 2011 | Car Audio & Video
My Kenwood amp shuts down and goes into protection mode after I play it for a minute or so. I have it cranked pretty loud. I have checked out my speakers and there are no shorts. I have a preamp between my...
could be you don't have enough voltage going into the amp or it could be the pre amp in between. if your voltage is below 11 volts then you need more voltage. you should have at least 12 to 14.4 volts.or you might have a small short in your amp.
Aug 03, 2010 | Kenwood KAC-9102D Car Audio Amplifier
Amp cut off
Hello there:
Yes you may have overloaded the amp if you still have a warranty with the amp use it if not and you feel that you may want to troubleshoot it deeper yourself
open the amp up and there will be a small fuse that sits on the electronic board that may need to be replaced also while you are in their check the board out real good to see if you see any burned areas or you smell anything burnt this may indicate a fried part on the board ok?
I hope that this has been very helpful for you
best regards michael
Nov 11, 2009 | Kenwood KAC-9104D Car Audio Amplifier
Amp keeps cutting on and off
Do you own a capaciter if not get one. If that dont help check all your wiring make sure it is the proper thickness and lengths.
Jul 30, 2009 | Alpine MRV-F540 Car Audio Amplifier
AMP FOR SUB SHUTS OFF SOMETIMES
your amp may be overheating, or you have it up too loud and the surge protector is shutting it of in fear of damage to your amp.
Apr 24, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Car amp
Make sure your speaker load is right. When you use dual voice coil speakers or more than one speaker per channel and such it can get pretty confusing. If you are bridging the amp be sure you understand how to bridge correctly. It is different than a normal speaker hookup. Also be sure the amp isn't getting hot and that there is nothing blocking it from getting good ventilation all around it.
Mar 14, 2008 | Kenwood KAC-8152D Car Audio Amplifier
KAC-9152D AMP TURNS OFF AFTER 2-3 MINS.
when your amp cuts out,is it when your stereo is produceing a long low note.if it is then the problem lies within the power distribution from the battery.as your sub pulles a long low note it draws a lot of power and sometimes the battery cant supply the power fast enough and the amp cuts out. useing a power cap is one way to solve the problem,but the best option for you to use becouse your running high powered amps is to have a sepparate battery for your audio using a split charging system.when your car battery is fully charged a relay swiches the power so that it charges the audio battery,so your auio system will have constant power without putting stress on your car battery. you can get thes from all good audio shops. hope this helps you.
Feb 25, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
