Question about Casio EXILIM EX-Z1000 Digital Camera
I dropped my Casio EX-Z1000 on a tile floor. The camera turns on and the lens goes out and quickly retracts and camera shuts off. I can still view pictures on my card and can enter info on date, time, etc. Thanks for any help.
  • 477 Answers
Unfortunitly when ever a digital camera is dropped it can cause the lens to come out of alignment this is what causes the error or problem. The len has several moving parts and can be replace most of the time it knocks the focus motor and zoom motor out of sync thust causing the lens to go out to try and post and sience the camera can tell the alignment is off then the lens goes back in. The repair for this should be around 100.00 I just got through fixing 2 of these for the same problem. Sorry but I hope this helps.
Posted on Apr 07, 2008
SOURCE:
I own a casio exilim ex-z850. it has been showing a lens error, every time i try to take switch it on. the memory card is fine, i view the pictures. but the lens wont open up or anything. please reply...
This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Sep 11, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
I dropped my camera while the lens was open and now the lens will not close and the camera will not turn on
The drop has likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. These problems cause the camera to power down quickly to prevent more serious damage, and there is no DIY fix. Sorry, but your camera is in need of professional repair.
Oct 30, 2009 | Casio EXILIM EX-Z1000 Digital Camera
My casio EX-Z250 as been accidently dropped onto a soft floor from a small height this as caused the camera to disable itself and will not turn on but the lens as stayed out. I hope you can help....
Sounds like the lens could have been slightly tweaked, making it out of alignment just enough to not fully retract. You can try to GENTLY push it in the opposite direction to see if you can "reseat" it. If not, a service center is probably your best bet at this point...
Oct 21, 2009 | Casio Exilim Zoom EX-Z250 Digital Camera
When I turn on the camera the lens comes out then closes and shuts off. I can view pictures, but the camera mode doesn't work at all. I upgraded the firmware to the latest version, but the problem...
Possible broken spring mount in lens. This spring holds the focus lens. I had the same problem on an EX S600 and was able to fix it by taking the lens assembly out and taking it apart and making a spring mount out of a small piece of wire and glueing it in. This is not an easy job as everything is very tiny. It takes time and patience. Seems the camera tries to autofocus but can't because the spring is not connected. It then just shuts off.
Aug 17, 2009 | Casio EXILIM EX-Z1000 Digital Camera
Casio Exilim EX-Z60 won't turn on
This happened to me too, fiddle with the lens as its obviously stuck. Don't be too rough but try to figure out if it is slightly bent.
You will only be able to this if the lens is sticking out a little, enough to get a grip.
Good luck
Apr 12, 2009 | Casio Exilim EX-S600 Digital Camera
Casio Exilim EX-Z3 not working (accidentally dropped on carpet)
Does the lens retract when you shut the camera off? Or at least press the On/Off button?
It doesn't sound like there is a problem with the lens if your buttons aren't working, it sounds mostly to me that a cable got dislodged and that has disabled your buttons and zoom switch.
You can try sending it to this guy - www.darntoothysam.com he might beable to help you.
Nov 18, 2007 | Casio Exilim EX-Z3 Digital Camera
A Dropped Camara. Please Read
That is what casio calls a lens error. You will have to send it in and have it fixed. The cameras don't do well even when dropped from that short distance. Call repairs at 800-706-2534 and keep choosing option 1. Tell them that you talked to tech support already otherwise they will try and transfer you to their tech support.
Apr 29, 2007 | Casio Exilim EX-Z55 Digital Camera
Casio EXILIM EX-Z1000 Digital Camera Logo
190 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
