Question about Garmin GPSMAP 498
Depth reads 0.0
Unit has been working fine until today. Started with depth readout not changing. i.e.; when moving from one depth to another readout would stay the same. After turning unit off and then back on, depth would read OK.
Then it stopped reading altogether - just 0.0 all the time. Everything else appears normal. Display appears OK, temperature reads OK - just no depth reading.
  • Anonymous Apr 17, 2008
    depth reading is at 0.0. replaced transducer, still not working.
    depth finder does not work, replaced transducer, still does not work, but it works with my garmin 240 blue depth finder, same cables. has to be some setting.
SOURCE: Garmin Streetpilot 2620 Goes not go to maps
I did update to the 4.8, and worked for about 10 minutes, and then went back to the old routine of booting over and over, and will not except map. I think I might sent it back to garmin in a few days after I get to tired with it.
Posted on Feb 12, 2008
  • 638 Answers
SOURCE: unit locks out fine blue line appears have to remove batt and then turns on
Disable the WAAS on your unit. A new satellite was launched earlier this year and is causing a problem. This is why Garmin issued a new software update version 3.9.
Menu > Setup > System... scroll down to WAAS and disable it. This should get your unit working again but with less accuracy.
Update the software to version 3.9 and leave for about 20 minutes in open area (clear view of sky) so your unit can download the full almanac. This should permanently fix your problem. Once you finish upgrading, go back and enable the WAAS.
to mhotz: You can purchase serial2USB connectors at a computer store. You will have to install the drivers which come with it before it will work. That should solve your upgrade problem.
Posted on Nov 20, 2008
  • 8 Answers
SOURCE: Nuvi 760 suddenly stopped working - will not turn back on
Try holding the power slide to the left and holding it there for 8 seconds. If that doesn't work, try charging it via your PC & USB cable. If that doesn't work, try a mains charger if you have one (I had to do this with mine). Good luck!
Posted on Jan 02, 2009
jonniewalker
  • 1031 Answers
SOURCE: The voice on Garmin stopped working
Hi
Please do this and let me know results.
If your device is not providing navigational prompts the language settings on the device will need to be checked:
  1. Turn the device on
  2. Touch Tools
  3. Touch Settings
  4. Touch Language
  5. Touch the blue box under Voice
If this section has your desired voice please make sure this voice is selected which will resolve the issue.
If the above fails or the unit doesn’t list the voice/s that you require you will need to update the software and reload the voice/s back to the device via WebUpdater. To install WebUpdater please click the link below:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Once installed and the software is updated please make sure that you check for additional updates which should provide you with a number of voices to reinstall to your device.
Once reinstalled your problem should be resolved.
Let me know
Posted on Aug 24, 2009
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi 680 Touch Screen "touch" works intermittently
Recalibration has nothing to do with repairing this problem. If the touchscreen is non-responsive, how are you going to recalibrate it when it doesn't recognize the key presses?
The problem is caused by a defective touchscreen. SHARP substitued a different touchscreen into the 6xx series that fails even when the glass isn't damaged. The problem is caused by a defect in the manufacturing process where the touchscreen connections becomes detached from the tail that plugs into the board.
The touchscreen connections between the screen and the tail are made from conductive ink that can fracture, most likely caused when pressing on the screen over time.
These defective screens can be identified by a white tail cap at the end of the tail, whereas the original touchscreens have a maroon tail cap. The original touchscreens will only fail if the glass has been broken.
I only use the original touchscreens for all of my repairs.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Nov 25, 2009
Unit will show correct depth for a short time and then reset to 2.2 feet and stay at that reading for long periods of time!
I assume that when it resets to 2.2 feet that the readout is flashing. If so the it sounds like you have a bad transducer as the problem has been getting progressively worse.
The transducer needs to be replaced. Sounds like the sending crystal is fractured.
Aug 06, 2014 | Lowrance X135 Power Pro Sonar Without...
The unit worked fine for 3-4 months.Now,it just gives a reading of 0 ft. with the water temperature. Once in a while while i'm drifting it will give me a depth for a few seconds and go back to a 0...
It sounds like your transducer has gone bad. You may be able to find a replacement on Craigslist or eBay, since this is an older model. Transducers are pretty sensitive to bumps and drops because of the crystal inside.
Aug 23, 2011 | Humminbird Piranhamax 170
I have a mitutoyo dial depth gauge. How do I use and read this?
A dial depth gage should have a set of depth stems. they are in 1" increments. to change the stem, first using a scale, measure the depth of the hole you are checking. Find the stem that falls in that range. remove the cap on the top of the unit, pull the existing stem out and replace it with the stem you need to reach the bottom of the hole. replace the screw-on cap. Set the cross bar of the body on the face of the part. Gently turn the barrel until the stem touches the bottom. the barrel has a 1" range. The numbers represent .1". The lines between the numbers represent .025". One turn of the dial equals .025" Add the length of the stem, the number on the barrel, the number on the dial and the number diall. Example, If the hole measures between 3" and 4" i.e. (3-1/8")start by installing the 3 to 4" stem. Turn the barrel so it reads "0". place the cross bar of the body so it touches the face perpendicular to the hole. Gently turn the barrel of the unit until it stops at the bottom of the hole. Add 3" plus the number on the barrel (.1"), the number of graduations on the barrel, and the number on the dial (.023"). The reading is 3.123". If you know your decimal equivalents, you will know that the hole is .002" short of 3.125" (or 3-1/8" deep.
Feb 21, 2011 | Mitutoyo 0-6"X.001" DIAL TYPE MITUTOYO...
When at speed i tend to lose sight of the bottom it becomes very broken. Also the depth reading takes a while to record depth.
What you are experiencing sounds like air bubbles crossing the face of the transducer. If you have a transom mount transducer check the face of the transducer. Make sure that it is clean. Also make sure the front of the transducer is a tiny bit lower than the back. The digital readout on the screen will only happen when you have a strong signal of the bottom.
Jun 28, 2010 | Lowrance Dual Frequency Transducer
Pentair MasterTemp 400 Heater Will Not Fire
Long story but bingo just at the end. The thermistor is generaly the problem with what you describe. it is an inexpensive part and easy to replace. You will not generaly find this in your book. Your E5 code is just because the unit hasn't started yet. Good luck.
Jan 25, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Lowrance x96 does not function after 20 feet depth
Your transducer needs to be adjusted so the return signal can be picked up. Some of these have to be super tuned to receive the signal. Also the transducer may be moving ever so slightly when the boat is traveling at speed. You may have some water turbulence interference all contibute to signal return.
May 26, 2009 | Lowrance X96 200khz Fishfinder
Eagle 640c Fish Finder dosen't read corectly.
I had the same problem and got the transducer changed. It now works perfectly. That could be the problem you are having... bad transducer.
May 17, 2009 | Eagle Intellimap 640c Marine GPS GPS...
Eagle Cuda 128 does not read water depth
Hi Chris, Did you get a fix for this issue? My Dad's Eagle Cuda 128 is also having the same problem - constant reading of 60ft. I'd love to hear if you have a solution. Many thanks,
Mar 14, 2009 | Eagle Boating
PELOUZE 4010 SCALE READOUT FAILED
my pelouse when i turn it on it stays on 0.0 when i put weight on it stays on 0.0 it then goes of i need help to get it to work
Jan 28, 2009 | Office Equipment & Supplies
Printer carriage not working properly in 5510 'all-in-one'
Does your carriage just move to the right side and get stuck? That's what mine does. I just fiddle with it and wiggle stuff until it's starts working and it'll work until I shut it down but when I turn it back on it starts all over again.
Dec 18, 2007 | HP Officejet 5510 All-In-One Thermal...
Garmin GPSMAP 498 Logo
55 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
