Question about Hotpoint RB787 Electric Kitchen Range
Storage drawer - design flaw?
The bottom storage drawer of my new Hotpoint RB787 does not slide in-out properly. It comes off-track every time I open or close it whether it has contents or not. Now it is stuck open and off-track. Any suggestions? Lynne
This was installed by contractors for the apartment complex and they say ALL of these models have the same problem. How can this be?
  • duncanleaf Mar 14, 2008
    drawer in current STUCK off-track position
    President:
  • Hotpoint Master
  • 2,651 Answers
Yea find it hard to believe that a product would be built this way!!, without looking at it would imagine that the tracks going back on both sides are too close together, which usually happens when the unit is mishandled upon delivery, a quick call to an authorized servicer will correct problem( it is a warr issue any way, and from the sound of it hell have a lot of warr work in your development
Posted on Mar 20, 2008
My stove drawer is stuck and it won't close or come out , what to do ?
drawer is stuck Anon, Pick up on drawer as far back as possible with some force,shake it up and down, this should allow you to lift drawer from track/slides. Clean and lubricate all wheels, bearings and track/slides and reinstall drawer.
HELP bottom oven drawer stuck on new GE range
How to Open an Oven Drawer That Is Stuck eHow
How to Unstick Oven Drawer
Stove Drawer Stuck or Jams DIY fix
Apr 02, 2016 | Kitchen Ranges
I have a 1976 Gaffers & Sattlers slide in range I want to replace. Any idea how to remove it? Thanks
this taken from ehow site:
Slide-in ranges and freestanding ranges use the same installation techniques, with one minor difference: the slide-in range rests on the edge of your counter top. Removing a slide-in range is not difficult but will require a friend to assist. Removing the storage drawer from the slide-in range first will give you access to the power cord and gas shut-off valve, if your unit uses gas
Instructions
    • 1 Pull the bottom storage drawer out as far as it will slide. Lift up the front of the drawer and unhook the back of the drawer from the drawer guide. Pull the drawer away from the range.
    • 2 Reach under the slide-in range and unplug the power cord from the wall outlet. Turn the gas valve to the off position on the house line coming from the wall.
  • 3 Lift the top of the slide-in range with the assistance of your helper, and pull the range forward enough that you can access the back of the range.
  • 4 Go behind the range and locate the connection between the house gas line and the range gas line. Disconnect the flexible gas line from the house gas line with a pair of channel lock pliers or a pipe wrench.
  • 5 Lift up on the rear of the slide-in range while your partner lifts the front. Slide the range out of the cabinet opening and out of the house. Lifting the unit will prevent unnecessary damage to your counter tops.
  • Read more : http://www.ehow.com/how_5959888_remove-slide-range.html
    Jan 03, 2015 | Kitchen Ranges
    Kitchenaid French door refrigerator with freezer drawer in the bottom. Has been in storage for over a year. We plug in and the upper part works fine but we can't open the freezer drawer... Strong tension...
    If any moisture was left in the unit prior to storage with the doors closed, it has caused the door tracks to become rusty and non functional. Refrigerator units should always be left ajar for many days following removal of power to allow the interior to fully defrost, and dry out. Extended periods of trapped moisture inside the unit will also cause corrosion on the aluminum coil, and cooling failure. Pleazer Appliance...
    May 06, 2014 | Refrigerators
    I want to reinstall a oven storage drawer on a electric LG oven
    I don't think you need to remove a slide rail. They should slide out by hand and then set drawer back into it. usually have to tile drawer up some to start.
    Nov 06, 2013 | Kitchen Ranges
    Storage drawer wont open
    Yes,but try this. Slide a clipboard into the opening whee the blockage is and then work the board back and forth to see if you can settle the utensils down. Shake the drawer at the same time. This should do it. A little time with and the extra racket should work.
    Feb 24, 2013 | Kenmore 30464 / 30465 / 30469 Gas Single...
    The bottom draw on my oven range is not lined up
    Has a round track bearing come off? That just happened to me the other day, and I found it under the drawer. Just poped it back in.
    Jan 24, 2013 | Whirlpool WFC130M0AW 30" Freestanding...
    The storage drawer on my range won't slide properly.
    Enter your model # at www.appliancehelponline.com for diagrams and illustrations. The plastic pieces are under the body parts diagram on the left hand side.
    May 03, 2010 | GE Kitchen Ranges
    Whirlpool electrice stove storage drawer
    There is a screw in the bottom of the two back corners that holds the drawer glide in place. Remove the glide and then you'll be able put it back the way it belongs.
    Nov 22, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
    Sliding drawer in the top refrigerator section
    hi i have the 700tc as well,,ok the best way to place the drawer,,,extend the 2 sliders all the way out,,there is one pin at the end of each slider and 1 hole on each side of the drawer lip which lays on the track ,,,the holes on the drawer must fall into the pins otherwise it will not close,,,so place the drawer on top of the slider ,,,what usually happens is the sliders tend to roll back into the housing of the fridge,,,so while the drawer is resting on the sliders reach under the lip of the drawer and pull each slider until the the holes of the drawer falls into the pins,,,when the drawer is seated in the pins it will close smooth,,,hope this helps
    Feb 10, 2008 | Sub-Zero 700TC Bottom Freezer Refrigerator
    Hotpoint RB787 Electric Kitchen Range Logo
    432 people viewed this question
    Top Hotpoint Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Justin Duby
    Justin Duby
    Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
