Question about Miele W1903A Front Load Washer
Miele W1903 washer skipping steps (not fully draining?)
I have a Miele W1903 front-loader that makes it to "End" but skips the standard wash and spin cycles. Pre-wash will get me a wash cycle and I manually select "spin". It drains but I don't think it's draining all the way because if I leave it unused for a week it starts to smell really bad. I've checked the pump cleanout and that's fine.
  • 1 more comment
  • Markomatic Mar 15, 2008
    The motor of the siphon pump you mean?
    Thanks,
    M
    The pump spins like a champ. All of the functions seem to function even if it's not in order through a complete cycle... and maybe it's not completely draining (hence the smelly water).
    I think what I really need here is a Miele factory repair/troubleshooting manual.
    My gut is telling me that there might be a solenoid/valve that's not functioning... therefore not tripping the next function to proceed and possibly not redirecting the flow of water at some point. Just an amateur guess though.
    There seems to be another component inside (this is where my guss comes from) that recirculates water during the wash cycle but drains it at the end. But the thing is... IT DOES DRAIN. But if it smells... something's not draining all the way. If a run a test load or two through... the smell is more or less gone. Has anyone worked on a Miele or Bosch out there? And what happened to the $20 I paid for nuthin'... where did that guy go? He's not responding to my emails and I'm pretty sure he didn't know anything that could help someone with a Miele.
  • Dane Henas Apr 20, 2014
    My Miele W1903 is doing the same thing. I only get a wash if I add prewash and it's skipping the drain and spin cycle. I can manually set it to spin and it drains and spins, so everything seems to work O.K.--just won't do it on it's own in order.
  • 105 Answers
Check the motor brushes could be worn out
Posted on Mar 15, 2008
  • william mikkelson Mar 15, 2008
    yes the drain pump
  • william mikkelson Mar 16, 2008
    yes you probably need to contact the mieli service centre as you machine is working fine in the pump out mode
    with the miele machines thre is a self diagnostics built into the controls and you need the srvice centre to access this for you
Washer won't agitate
I would start by checking the belt on the motor could be slipping when u put full load in washer. also check that pulleys are not loose.
Apr 19, 2014 | Miele W1903A Front Load Washer
Washer skips rinse cycle
Possible defective washer control panel.
Jul 13, 2017 | Zanussi Washing Machines
Neptune washer mah3000aww skips to spin cycle and wont drain
It sounds like the "repaired" main control board is still the issue with it being intermittent.
Nov 20, 2012 | Maytag Neptune Washer
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
My tub won't drain correctly, we followed the maual and still not draining fully from tub. I have a maytag front loader.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Sep 15, 2010 | Maytag Washing Machines
Frigidaire won't go through cycles...
you need to call a repair service . the control board has failed
Jan 30, 2018 | Frigidaire ATF6000ES Front Load Washer
Skipping throygh cycles
Timer ? Are you referring to the main control board ? How much extra water is being added on the first cycle ?
Jan 14, 2008 | Maytag MAH6500 Neptune Front Loading...
Machine stops and goes to end half way through a cycle
Check the filter is not blocked it sounds as if it cannot drain in the time allowd at end of wash cycle. Regards Advisor
Jan 17, 2007 | Zanussi ZWF1430W Front Load Washer
Miele W1903A Front Load Washer Logo
979 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
