Can you help me find the dip stick for transmission
Not sure where the dip stick for transmision is.
might be mising dip stick, I think I know where refill is but need to check level of fluid.
how long should dip stick be?
  • Anonymous May 11, 2010
    LOL
    Please specify the year / make / model of car.
  • 979 Answers
Depending on make, you may not even have a dipstick. Some models use engine mgmnt to determine level and usage. consult your manual...accordianman
Posted on Mar 15, 2008
  • 30 Answers
Go to Start, Programs, Accessories, Dipstick. Then reboot computer and uninstall windows. After finishing, take computer to car, drive to salvation army and donate to relieve bad karma for hideous joke.
SOURCE:
Do a 2010 Jeep Liberty Have a Automatic transmission dip stick?
Alot of the newer vehicles have maintenance free transmisions so they dont have dip sticks. And if it is maintenance free it will tell you under the hood.
Jun 17, 2016 | 2010 Jeep Liberty
Cant find the dip stick for transmission on 2006 Suzuki forenza has automatic transmision
Would you believe the car does not have a trans dipstick? This is becoming more common on the basis that it does not have to be checked often (they think). See here for a good explanation
http://www.ehow.com/how_8725779_check-fluid-2006-suzuki-forenza.html
Sep 23, 2013 | 2004 Volvo XC90
How do you know that you need transmission fluid on a honda accord ex. I looked at the dip stick and saw nothing.
If you looked at the dip stick and saw nothing that is probably a bad sign. Most dip stick have markers on them in order to gauge how much fluid is in the transmission. Look at your dipstick closely and make sure you fill your transmission until it is between these markers. The markers are usually down by the end or tip of the dip stick. Be sure you do not over fill the transmission. I hope this helps you out at least a little.
Aug 27, 2011 | Honda Accord Cars & Trucks
Don't know where the dipstickis i see everything else but the transmision stick. it's a 96
The transmission dip stick is on the left side of the engine toward the rear and has a red snap clip on it . Transmissions are always red and engine oil is always yellow so you don't put the wrong oil in the wrong place . However you didn't say what make or model but it will have a red dip stick pull out handle and every chevy i have ever seen for a 96 is in this area . Look around for it because its there and red
May 14, 2011 | Chevrolet Celebrity Cars & Trucks
Where do I check the transmission fluid?
Look under your hood, and look for your Transmission Dip stick.Simalar to your Oil Dip Stick, But will be Labeled Transmision Fluid.It will be towards the Back Closer to fire-wall on Drivers Side.
Thanks For Using FixYa Please let me knowe that you found it by my Solution by Voting.
Sep 29, 2010 | 2005 Pontiac Grand Am
Where do i put transmision fluid i a kis sadona automatic
Remove the Transmission dip stick and use a funnel to add fluid in the same tube the dip stick comes out of. With the vehicle running on level ground and warm, remove the dipstick and see where the fluid level is at before you add anything. If it is between the 2 marks on the dip stick, normally marked Hot and Cold, then your fluid level is good. If it is at the bottom mark add fluid, about a pint will do, to bring the fluid between the marks. Then see if you can get it to shift.
Jul 22, 2010 | 2002 Kia Sedona
Where to find transmision dip stick
there is no dipstick, you can access the transaxle by lifting the car up. It is located on the drivers side right by the wheel. Remove the bolt at the top of the pan, if the fluid dribbles out there is enough, if not you need to fill it.
Apr 14, 2010 | 1999 Pontiac Grand Am GT
2005 pontiac problem/?
The newer Pontiacs (& Chevy Malibus) have a sealed transmission, which means that there is no dipstick for the transmission. Consult your owner manual.
Aug 05, 2009 | 2007 Pontiac G6 GT Convertible
I cannot find the dip stick to check the transmission fluid level on a Daewoo Nubira
TO CHECK TRANMISION OIL YOU NEED TO OPEN A PLUG AT THE LEFT AXEL AT THE TRANSMISION THE TOP PLUG TO VERIFIED LEVEL AND THE LOWER PLUG TO DRAIN TRANSMISION OIL.
Apr 14, 2009 | 2000 Daewoo Nubira
Transmision level fluid Baleno esteem 2002 susuki
The proper fluid level is marked on the dip stick. With the engine running and in park, raise the hood and remove the dip stick from the autotrans filler tube. With a clean rag, wipe down the stick and then place the dip stick all the way back in the tube again, and then pull it out once more.
Holding the stick level, you can now read what the fluid level is.
If you add any fluid, do so in small amounts, such as a half a pint at a time.
Do not add fluid with engine running.
Thank you for adding your comment
Bill, ASE Master Technician
Nov 23, 2008 | 2002 Suzuki Esteem
Open Questions:
AOL HELP SUPPORT PHONE NUMBER 18OO8O31O69 There are two circumstances that can cause someone to want to change his/her AOL password: 1 forgetting the AOL password and needing to recover it and 2 to change the AOL password. The latter can be because the AOL password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's AOL password at least once in a month. Contact Aol Mail Password Reset. For your convenience to contact Aol Mail Password Reset We have provided all possible information of Aol Mail Password Reset. You can contact Aol Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an AOL Password The following steps show in detail how to change an AOL password when the current password is known: Sign into the AOL Mail Account from AOL Do you want to recover/reset your AOL email password? So you'll be do the some steps to recover your AOL password. We'll help you to fix your problem and we'll guiding the some steps to recover your AOL password. Follow and do the below steps to recover your AOL email password- Go to the AOL - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your AOL mail message on your Gmail account. AOL is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While AOL's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, AOL has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your AOL password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your AOL password.
Oct 22, 2019 | AOL Computers & Internet
Computers & Internet Logo
74 people viewed this question
Ekse
Marvin
Marvin
