Question about Xerox DocuColor 12 Printer
Not in off oil
I am having problems not to getting in off oil on the rollers
    President:
  • 2,072 Answers
I am not certain what you are specifying.
Are you trying to oil some rollers? Or is there oil getting on the prints from some of the rollers?
Posted on Mar 16, 2008
Dryer turns on but dont not turn inside
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
You will have to remove your drum.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Sep 19, 2010 | GE DBXR463GB Gas Dryer
How do I get into check rollers on drum
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Oct 14, 2009 | Maytag Dryers
Dryer is loud and seems to get louder the longer it is on
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 12, 2009 | GE Dryers
Drum doesnt spin
Sounds like your problem may be a broken belt.
If you have to replace your drum belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Oct 10, 2009 | Whirlpool Dryers
It has power but the motor wont run on the dryer
Good luck,
I hope this helps
Oct 08, 2009 | Maytag Dryers
Very loud metal vibration coming from the dryer.
Your problem could be your drum rollers.
If you plan on trying to do the repair yourself, then you will need to unplug the dryer from the electric.
Check the idler arm with the pulley, sometimes wear will cause the noise you describe.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy.
Check your drum rollers for flat spots, if they have flat spots on them this will cause noise like a thumping type noise.
Good luck,
I hope this helps
Oct 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer heats intermittently. timer does not advance on sensor side. noisy operation
Sounds like you have a timer switch problem if the timer is not advancing.
The noisy operation sounds like a drum roller problem.
If you have a front loading machine:
Unplug the power cord, remove the front of the machine, this will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check the rollers for flat spots on them, if they are flat spots on them they need to be replaced. If there are no flat spots on the rollers then you may get by with just lubrication on the shafts of the rollers. Use a good grade of machine oil on the shafts of the rollers such as 3 in one Oil.
I hope this helps.
Oct 03, 2009 | Whirlpool LGR7646E Dryer
Very noisy vibrating sound when dryer is turned on.
You problem sounds to be noisy drum rollers.
Drum rollers will get flat spots on them and over time they will need lubrication.
If you have a front load machine, then you would normally remove the front and this will expose the drum...remove the drum and this will expose the drum rollers.
If you have flat spots on the rollers replace them...if they are in need of lubrication you can use a good grade of machine oil...such as 3 in one oil. You would oil the shaft of the drum roller.
If this does not solve the problem, then you may have to replace the drum rollers
I hope this helps.
Oct 01, 2009 | Amana Dryers
Paper jam at transfer roller with no paper jammed. Have cleaned rollers with 409
Had the same problem after cleaning the rollers also. Technical help was rubish. In the end I found some clues n fixed it. There is a flag between the rollers n if it gets stuck and or in my case the spring behind it came off, then the sensor thinks there is a constant paper jam. Undo one screw and get inside n check the spring n flag. I done this. placed sping etc back in place, put it all back together n bingo. Be carefull not to drop the screw inside and make sure the cog is properly engaged or you will get a funny noise. I can provide pics etc if needed.
Jul 17, 2009 | Konica Minolta magicolor 2400 Laser...
Rollers squeak when a fax is sent
The squeek is caused by friction if you have a steady hand get a bottle of 3 in 1 oil .. apply one drop of oil to each side of the roller ( make sure you put the oil on the metal pin that hold the rollers in place)Then feed a paper through so it lubricates those areas. this will stop the squeeking sound. Be very carefull not to get any oil on the roller. You want the oil on the metal pin that holds the roller in place. If you get oil on the roller use rubbing alchohol and a cue tip to clean it off. This is the safest liquid to use its not abrasive and it evaporates.
Sep 12, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Xerox DocuColor 12 Printer Logo
37 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
