Question about Vacuums
Red light won't turn off
The red indicator light is on and won't turn off. I've changed the bag so it's a brand new bag but the light is still on. I also looked to see if the filter was dirty or clogged and it's not. When I turn on the vacuum it looks like smoke is coming out but nothing smells like it's burning. I don't know if it is just dust or what. What else could be the problem? I have the Simplicity 6 series vacuum
  • ssnoonan Oct 11, 2008
    I must have a clogged hose or a clogged dirt inlet. How do I fix it?
    President:
  • 1,673 Answers
You probably have a clog in either the hose, or the dirt inlet by the brush roll. That red light is telling you that either the bag is full or a clog is not allowing suction.
Posted on Mar 15, 2008
SOURCE:
Red light indicates bag is full when it is not
you could have vacuumed up a fine powder that is clogging the bag.
Oct 08, 2014 | Vacuums
Bag light wont turn off
Hi there! The vacuum may be still sensing dirt in the cleaner. Try wiping the area down in and around the bag port. Be sure you are replacing the bag with a genuine Hoover Type Q bag. Also, when assembling the bag remember to slide the red bag door lock to the right to lock it on. If the check bag indicator light still comes on there may be an issue with the sensor on the vacuum. We would recommend taking your vacuum in to a Hoover authorized service center for repair. Hope this helps! Service Center Locator
Sep 13, 2014 | Hoover Platinum Collection Upright Vacuum
Get red light off after changing filter
Depends on which model you have. If it's a red light it might be your full bag indicator. If it's glowing red you might have a clog somewhere .
Jan 07, 2014 | Riccar Vacuums
Riccar 8850 red light is on and won't go off, I changed the bag but do not know what the light indicates
The light indicates a restriction, a full bag or clog or something restricting the airflow
Dec 15, 2013 | Riccar Vacuums
I just changed my bag and now it is squealing and the red bar is in window?
It would seem that your vacuum is clogged, hence the change bag indicator. Pull the hose out and and remove at the swivel connection at the base of the hose.You can use a small flashlight to check the hose, lay the hose on the floor with the light at one end and look for light at the other end. I know the grip end is curved but you should be able to see some light. Check the rear port by removing the cover located near the base, on the rear side, close to the hose swivel. Unscrew the 2 plastic screws and lift out the cover; check for a clog here. Next lay the vacuum flat on it's front and shine the light behind the brush roll and up the short black internal hose. Facing the metal sole plate, the hose should be near the right corner. Good luck.
Jun 03, 2012 | Miele S7210 Bagged Upright Vacuum
The vacuum won't turn on. plugged in, all lights flashing. no power
When switched on the vacuum goes through a self diagnosis test. Lights will come on for a while, then go out. If everything is okay, then the blue "Optimum" light will come on and stay on. If it turns of, a red indicator light should come on providing information on what's needed; i.e., filter or bag change needed.
Aug 22, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The red light on my electrolux vacuum comes on and cuts power.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 26, 2010 | Electrolux Guardian Bagged Canister Vacuum
Red "bag is full" indicator shows even though new bag has been put in and vacuum cleaner wont pick up. Also floor adjustment does not adjust. This is for a powerforce model 3522 series
The red light tell you that it is sensing a full bag. But a clog in the hose or the inlet down by the brush roll will also do this.
Apr 17, 2008 | Vacuums
Red light stays on
Most likely the hose or the inlet down by the brush roll has a clog in it. The red light indicates a full bag, but if there is a clog, then it thinks it has a full bag.
Dec 07, 2007 | Lindhaus Activa 30-38 Bagged Upright...
I changed the bag and my vacuum won't turn on!!!
Try vacuuming the inside of the tank out, and see if that helps clear off the sensors.... If not call (570)326-1731 and ask for Liz adn I will be happy to try and help you aout.
Sep 06, 2007 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
491 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
