Question about Canon LaserBase MF5750 All-In-One Printer
Jarry cannon open printer cover rec.paper jam but no paper jammed??
  • Anonymous Apr 10, 2009
    Same here. I have no visible paper jammed in machine. I've rotated all rollers looking for bits. Nothing. I remove toner cartridge, paper tray, reload, close cover, same thing. Removal of power cable during this process also reboots it to the same condition. This POS is just FUBAR. Pretyy useless for a piece of Chinese plastic with the name of Canon on it.
Open printer cover, pull out toner cartridge, re-install cartridge, close door, it should re-boot the machine.
Posted on Sep 25, 2008
Cannon IR 1600 Rec paper jam message.no any paper find. how can i solve this problem?
Yes, often it is not a paper jam but a fail of paper to feed out of the tray which the machine thinks it has a jam. Clean feed rollers with Windex, or alcohol. Check the paper tray to see if paper size panels are set to the correct position. portrait, landscape, width length ect.. Good luck.
Jan 08, 2016 | Cannon Office Equipment & Supplies
Rec. paper jam open right cover
Obviously you have a paper jam somewhere. Probably one the right side, open all the covers and pull the paper out.
Oct 20, 2013 | Canon FAX-L400 All-In-One Laser Printer
My Printer is Laser, Cannon LBP3000, while printing paper jammed into the roller, computer gave instruction that "open the top cover of the printer and remove the paper by pulling". But after...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 12, 2010 | Canon LASER SHOT LBP-3000 Printer
Paper jam /Message says Rec. Paper jam Open right cover
From right side of fax, open the toner door, remove the crg.unit, and look for paper, if not also from left side open the door and check for paper or broken parts in fixing unit.
May 21, 2009 | Canon FAX-L400 All-In-One Laser Printer
Message paper jam and open left drawer cover
Delay Jam in Delivery Assembly (Paper Leading Edge Jam at Delivery Sensor/Wound Paper Jam at Fixing
Assembly
Mar 19, 2009 | Canon iR 2020i Laser Printer
Paper jam message, but no paper visible
Are there any traces of paper in the printer? Have you tried by restarting printer?
Mar 18, 2009 | Canon PC-D340 All-In-One Laser Printer
Cannot find paper jam ...
We have a D780, which is probably very similar to your unit. Have you removed your toner cartridge and inspected to see if any paper is in the paper path? 95% of the time that is where the paper jam is.
Oct 21, 2008 | Canon ImageClass D880 Copier
MF-8170C REC. PAPER JAM and Open Cover
Get a thick piece of paper and feed it in to the printer following the paper path the best you can until you get the piece of paper you can't see out of it.
Oct 16, 2007 | Canon imageCLASS MF8170C All-In-One Laser...
Canon mf5650
Check the paper setting in your software. Paper size should be A4 in all instances. Hope it helps
Oct 04, 2007 | Canon LaserBase MF5650 All-In-One Printer
Canon LaserBase MF5750 All-In-One Printer Logo
304 people viewed this question
old marine
old marine
