Question about Lakewood LAKQTV22 Utility Heater
Power light comes on but it doesn't run
I bought this heater at the beginning of winter. We have used it in our basement regularly. I went to turn it on the other night and nothing happened.
The elements didn't heat up, the fan didn't come on. Its just dead. The power light comes on. I have no idea what to do. I threw away the box and can't find the information/direction guides. I no longer have the receipt any more either. I'm frustrated because it should of lasted longer than this. Any suggestions?
  • lingla Feb 02, 2009
    I have the same problem, how can I fix it?
    Sergeant:
  • 288 Answers
You need to trace the path of electricity. With it unplugged, remove the cover and look at the wiring from the power light on, Its possible that a wire burnt off, you will be able to see it easily if so. If its an internal short, like inside the thermostat or power switch, then you need a meter to accurately find the problem, or change parts and hope to get lucky.
Posted on Mar 20, 2008
The heater won't stay powered on
Locate the flame sensor (connected only to one wire) and remove it. Some people use fine sandpaper, I use WD-40 to clean it. And I do this every year at the beginning of Winter. Good luck!
Jan 22, 2013 | Heating & Cooling
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 06, 2012 | Rheem Water Heaters
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
Two winters ago i had to change out my thermostat. Then last summer my AC wouldn't turn on. So i thought it was the thermostat i had so i just went and bought a better one. but still the Fan on the AC...
If the compressors running and the fan is not you should check the fan motor capacitor and check for power at fan motor if power is there you have bad fan motor
Jun 21, 2011 | Heating & Cooling
I have a 3 year old ge smartwater gas water heater. in our ontario winters, the gravity vented unit spills exhaust into the basement because the pipe and chimney get too cold after the heater is off for...
Id try raising the chimney until you can get the smoke from a piece of paper to get sucked up under the draft hood. I believe theres a different problem then a cold pipe.raising the chim.might not be the answer.
Jan 17, 2011 | General Electric GE SmartWater Household...
I have a Rheem 80 gallon electric water heater in our new house. It's been in use about 6 months. When we first moved in this past summer, at least two lengthy showers could be taken back to back and still...
To check to see if it is a bad element - turn the power off again and use a multimeter to check continuity (Ohms) in each element. It is not uncommon to have one element fail. Replacing an element is "elementary" :), if you have some mechanical aptitude. Just be sure and drain the tank to below the level of the failed element. Easier if it is the upper element of course. Again - be sure the power is OFF - check it with your meter before you begin and you may even want to lock out the breaker if there is any possibility of someone mistakenly turning it back on.
Dec 18, 2010 | Rheem Water Heaters
This will be our third winter in our home, and for some reason this years when we run the heater it smells. The smell is similar to a stinky bathroom odor (that's the best way I can describe it). I...
Contact your Gas company tell them you have a foul smell coming in when you turn on the heater. They typically wont charge for a technician to come out and inspect the heater for you.
Nov 15, 2010 | Heating & Cooling
I was sitting at my computer, with my space heater running, and suddenly both of them went out. Assuming that I had drawn too much power, I went to the fuse box to flip the switch back. Much to my...
The service to your basement needs to be upgraded if you are going to run the heater and other electrical units. I would guess that you have a 15 amp line and need to upgrade it up to at least a 20 amp and with a 12 gauge grounded line. In the short term you may be able to get by using a heater that draws fewer amps.
This definitely sounds like your need to consult an electrician.
Feb 21, 2010 | Kitchen Appliances - Others
2006 Dodge Durango Oil light comes on
It might be faulty oil pressure sensor or bad oil pump, but might be adressed to recent oil change. Sometimes oil get viscouse in winter and cause oil light to come on. For winter the recommended one is 5W-30
Oil light should come on for less then a second during starting the car. If it comes longer or when you push the brake it might be the sign of bad oil (sometimes), faulty oil pressure sensor (mosty), bad oil pump (often) or internal engine problem (very rare).
Good Luck
Feb 24, 2009 | 2003 Dodge Durango
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Lakewood LAKQTV22 Utility Heater Logo
144 people viewed this question
Top Lakewood Heating & Cooling Experts
Mack Baxter
paulcarew
Jay Finke
Jay Finke
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
