I have a maytag top loading washer Model LAT9900AAW. I ordered a replacement pressure switch and the new switch looks nothing like the old one. The factory insists that the part is correct but can't tell me how it goes on. the old switch had individual wire connectors and the new onw has a modular plug connector and none of the contacts are numered the same as the old one. I need a wiring diagram for the new part. Help! thanks, Bryan
    President:
  • Washing Mach... Master
  • 2,651 Answers
Jsut for curiosity i looked up the part with your model and this is what i got 208751 which changed from a 207213. doesnt give me picture of part, but i would imagine that ifyour cant connect correctly with what was in box you got the wrong part, even if they chnged part that dramactially it woulda come as a kit w/instuctions
Posted on Mar 15, 2008
How to install presure switch
Hi.
The pressure switch is located behind the control panel. Its unction is determining the level of water in the washer.The switch looks like a round shaped plastic switch connected to wires and to a long thin rubber hose. To replace the switch disconnect power. Undo the screws holding the control assembly. Remove control assembly cover. Disconnect wires from switch and undo the screw holding the switch. Pull out the rubber hose from the tub and perform operations in reverse order to install the new part.
The switch is part nr.4 in diagram below. Click on the picture to enlarge:
Jul 07, 2011 | Maytag MTW5700TQ Top Load Washer
Not getting water to washing machine hot or cold
Hello, Thank You for using FixYa. I will be helping you today.We see allot of issues with this. If the water is on and filters where hose is hooked up are not blocked then you will have to replace the pressure switch temp selector switch. It is a combo switch. When you look it up by your model number order the temperature switch.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer comes on but does not fill with water
Your pressure switch is bad. Th eserial number will dictate which one you need. Look at serial number before ordering switch!
Kelly
Mar 23, 2011 | Maytag Atlantis MAV6451 Top Load Washer
My maytag washer leakes, all the water runs out on the floor.
Remove the rear access panel to check the source of the leak. The drain pump is most probably broken or the sump hose is damaged or detached from the tub.
Drain Pump Removal/Replacement Procedure (Maytag Neptune MAH5500B)
  1. Safety first. Unplug the machine.
  2. Remove the hose clamps and hoses from the pump.
  3. Disconnect the wiring harness from the pump and the pressure switch terminals.
  4. Rotate the pump assembly counterclockwise and remove it from the base of the washer.
  5. Remove the plastic bag covering the pressure switch.
  6. Press in the locking tabs on the back of the pressure switch and pivot the pressure switch off the pump bracket.
  7. Grasp the pressure switch and lift the nipple off the pump cap.
  8. Install the pressure switch on the new pump in reverse order of the removal steps.
  9. Install the new pump in reverse of the removal steps above.
Jan 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
May 20, 2009 | Maytag SAV571EEWW Washer
Water will not stop filling tub.
the problem is that your pressure switch is not working properly. if you take the screws out of the back of the head you will find the pressure switch. first unplug the washer then undo the hose from pressure switch. blow trew the hose, then blow into the pressure switch if you hear the pressure switch click then re assemble and try again put on small load and watch if fills almost to the top or over flows replace pressure switch
Feb 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water won't cut off
if you have to shut the water off at the source you need a new water inlet valve. If not then you need to replace the pressure switch.
Jan 29, 2009 | Maytag MAT13MN Top Load Washer
Maytag washing machine model PAV3360AWW won't stop water on selected water level.
It sound like you have a bad float switch and it is not reading the water level right.If it is filling and wont stop then a possible new water valve is in order:) The float switch is locatted under the top panel of washer
Dec 30, 2008 | Maytag PAV2300 Top Load Washer
Washer filling up with to much water
is your printer front loading or top loading?
the prob is in the pressure switch or in the pressure hose, usually the hose is clogged up and fails to produce enough presure to activate the switch to shutdown all solenoid to stop the water from overflowing.
if you can open up you unit you can see a small hose 1/2 " trace the bottom hose until you find the clogged part, you can remove and clean this if not you can order a new one for immediate replacement.
if this is a top loading this is much simplier
Aug 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag top load neptune washer error code od
I own a maytag neptune, top load washer with electronic board or lcd screen, od code display, those are the door switches locates on the side of the door, the switches are electronic, an after opening the washer an opening the switches I discovered that the wire that sends the signal from the switches to the board were broken an rotted from the mold an soap that got accumulated in the switch, I took the switch an cleaned all the electric contacts, an stripped the wire back to were the wire was in good shape an re-solder the wire back to the switch, assembled back together an had the error went away ( no need to do anything else), the switches are attach to the machine with a 1/4 in screws , if you are not handy with soldering wires, you can order the part, ask for the lid switch give them your model number an I think they run about 75 dollars each, time to change em if ur a newbie, maybe an hour , I can do it in maybe 20 mins tops!
try it hope it works for you!,,,,,,
new washer 600
new parts 150
making a wife happy...............priceless!
good luck! let me know.
Apr 19, 2008 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
