Question about Hoover F5837-900 SteamVac Supreme Wet/Dry Vacuum
Upholstery attachment The nozzle doesn't spray properly, the water just pours out (not alot) instead of spraying. It also has very low suction. The upright part seems to be working fine. I cannot figure out how to take it apart so I can look for a clog, when I look into the hose I don't see anything.
    President:
  • 1,673 Answers
May have a problem in the noozle asm on the hose. Hose part #90001335.
Posted on Mar 21, 2008
I can't get the solution to spray or suction from the floor . the hand attachment will spray somewhat and suction, but not from the floor. i have the blue 9200
If it is only a problem with the floor sprayer, this suggests that the nozzles or tubes to the floor unit are clogged. Take off the water storage part, and you'll see two red clips (these are the floor nozzles). Squeeze and pop these out, and see if they are clogged.
If that is not the issue, open the unit up and see if the tubing supplying the front (floor) nozzles are clogged.
Please let me know if this was the issue or not.
- Matt
Dec 22, 2009 | Bissell 9200 Upright Vacuum
I have used my Steam Vac for carpeting, but until today, had never tried cleaning upholstery with the spin-scrub brush. I spent a miserable afternoon trying to control the spray, which seemed to go...
I can sympathize. My vac came with two handheld attachments. I have better luck with the handheld attachment that doesn't have the spin-scrub pads. To keep the water from going all over the place, you need to keep the part the you hold only about 1 inch from the surface of the upholstery; if you hold it higher it gets everywhere; if you hold it lower the spray doesn't spread out wide enough and it just makes big water droplets that roll down the upholstry.
If the vac isn't sucking up the water, it is likely you have it set up wrong. Take off the attachment; if you put your hand over the open end of the tube, do you feel suction? When you are using the handheld attachments there is a rectangular piece you remove (attached to the dirty water tank) and you stick the rectangular part from the hose in there. If you are getting suction but it's just not sucking up any water try these 1) maybe you aren't laying down enough water, spray it more heavily OR 2) you need to **** up the water right after you lay it down. Don't let it soak in for more than a few seconds.
good luck!
Aug 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No suction on either vac or upholstery attachment...does spray
check to see if the red lint filter in the clean dirty water tank is clean and free from fluff if this is glogged this will resticted the suction ,check to see if the tank is seated corretly
May 24, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Hoover SteamVac Model F5887-920 - hand attachment won't spray
I have a model I got in 2001. I found that the water sprayer on the hand tool is driven by a little turbine that relies on suction from the main vacuum motor. I eventually found that the spindle inside the turbine had separated and hence the hand-tool wouldn't spray. I glued it together but that only fixed the problem until it broke again. I am going to buy another (about $23).
Jul 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell 9400 ProHeat Upright Upholstery Hose
Set Ready Tools Dial to the Hose
Setting. This will allow spray and
suction from the hose.
Set Custom Clean Dial for Heavy Traffic, Normal
Clean, Light Clean
, or Rinse, as desired
Attach the cleaning tool to the end of the hose.
Plug in and turn on the Power Switch and Heater
(if desired).
Clean by pressing the trigger to spray solution
onto the area to be cleaned. Slowly move the tool
back and forth over the soiled surface. Release
the trigger to suction soiled water. Continue to
clean in the area, working in small sections, until
no more dirt can be removed. Rinse (optional)
and suction as needed.
May 26, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Eureka Atlantis 2591A Extractor - Won't spray
Hard to say without seeing it, is there a function type knob that you would switch from carpet to hose? Did the hose attachment lid close ok? Other then take, if this is new, it has a years warranty on it, just take it to a waranty shop for repair.
Apr 20, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Steamvac
You might try running a solution of vinegar and water thru it to clean out the lines and spray nozzles. Also are the brushes turning when you are using it, that could also be the problem.
Mar 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Can't get water to spray out of the hand tool nozzle
When you attach the main suction hose to the front of the machine, you also have to connect the soultion hose to a valve located on the side of the machine. When the machine is running, take a small screwdriver and depress the centre of this valve. You should get a spray of water out of the valve which will confirm the valve and pump is working. Now, connect the small solution hose, making sure you push it on all the way. When you pull the trigger on the handle of the hose, you should get spray. If it does not, you may have a plugged nozzle sprayer.
Feb 16, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F5837-900 SteamVac Supreme Wet/Dry Vacuum Logo
136 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
