Question about Samsung HCM5525W 55" Rear Projection Television
Samsung HCM 653
I am a TV tech but can,t get into right service mode (replaced STK's, fuses, resistors etc.) I need to get into sud menu to set RH,BH,RV,GV,BV, to 200 so I can get back to basic settings. Have trier MUTE, 1-8-3, POWER, and then MUTE 1-8-3, but it gets me to a grid area (all curved bad) but not to the 200 settings(buddy told me it would) any help??????? Jerry
    President:
  • 4,402 Answers
This is all i got
With set off...mute + 1 + 8 + 2 + power.
Arrow down to "Options" push enter.
Lamp reset and lamp hours should be in there.
Power off 2 minutes or until fan kicks off to exit.
Posted on Mar 14, 2008
  • a b Jan 21, 2011
    It may not need an adjustment but rather further repairs on the power supply. check for 20v going to the convergence board. if the supply is missing there is a burnt resistor on the supply side. just a thought.
SOURCE:
My picture has a red and blue seoaration that looks like an old 3d film
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Feb 25, 2011 | Sony KP-51WS500 51" Rear Projection...
Sony model #kp51ws500. Common problems for screen appearing warped
Need more details about how the screen is appearing warped.
if you have color separation and distorted image (warped,bowed, etc), then your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless.
Note: The STK chips are black about 3 inches long and will be mounted against a large aluminum heat sink (metal fins). They have about 20 pins on them. I believe they are STK392-560s in that set.
The picture is warped red & blues distorted
Your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Note if one STK chip fails, you replace both regardless. They will be right next to each other.
Feb 20, 2011 | Toshiba 57H81 57" Rear Projection...
I have what appears to be shadowing of the words.. and picture.. blue wave across the top of picture..
Your Convergence ICs are likely failing. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Feb 20, 2011 | Hitachi 57SWX20B 57" Rear Projection...
When my 65 inch Mitsubishi tv is on for about 10 minutes the colors get al blury and almost looks like 3D without the glasses.It is nine years old Model number WS-65819.It doesn't clear up
Your Convergence ICs are likely failing or it is a bad solder joint related to that area. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Note if one STK chip fails, you replace both regardless. There may only be one STK chip in this set. If there are two, they will be right next to each other.
Feb 20, 2011 | Mitsubishi WS-55819 55" Rear Projection...
There are 3 distinct images for each object, one for each color. The colors are red, blue and yellow. The images are bowed or warped.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 22, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence will not line up after replacing ic & resistors
Did you replace the resistors when you replaced the convgence chips? If one of them was bad you would still have the problem.
Here are some of the most common symptoms and example photos.
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 03, 2009 | Philips 51PW9303 51" Rear Projection...
Sony kp 51ws510 convergence problem
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 19, 2008 | Sony KP-51WS510 51" Rear Projection...
Colors separated
You need change STK392-560(can use STK392-570)
I guess it happend when holding bolts weaken to radiator.(Check other STK on next radiator)
You have to change STK on right radiator.
Disconnect small connectors. You can l leave Hi Voltage two lines(RED). unscrew board.
Pool board out.
Unscrew STK. Set board verticaly. Just pool STK bu pincet and heatup solder. One by one...
Clean halles.
Set new STK with thermopasta on board in to hallsradiator. Screw up.
Wet contacts by liquid fluse. And sosler them.
Clean up by alcohol...Check for short by lense...
Apr 28, 2007 | Sony KP-57WS500 57" Rear Projection...
Samsung HCM5525W 55" Rear Projection Television Logo
105 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
