Question about E-Machines EMA IMPERIAL GV (845GV) TG3 eMachines (145119) Motherboard
Replace A Hard Drive On E-Machines ?mperial motherboard glve
Pls Let Me Know What I Have To Do When I Replace A Hard Drive That Was On Hp Or Dell Computer To My E-Machines Computer
  • 1 more comment
  • akai1 Mar 14, 2008
    system drive
    I Have Try This
    Did Not Work
  • Steve Carpenter May 11, 2010
    Will it be used as a system drive (with your operating system on) or as a secondary drive?
  • 88 Answers
First, check the jumpers on the back of the drive to ensure that it's set for master. There will be a legend on the drive label explaining where the jumper needs to be to achieve this. If it has been used as a system drive previously you won't need to worry about this.
Second, physically fit the drive into the tower and connect the IDE ribbon cable. The motherboard end of the cable should connect to the primary IDE slot. To identify which one is primary look closely next to the two slots, they'll be marked IDE 0 and IDE 1. IDE 0 is primary. Connect a molex power connector to the back of the drive from the PSU.
Since this drive has been used previously you should now be able to install your chosen operating system from a CD or DVD. XP and Vista both have options for creating/deleting and formatting existing partitions during setup.
These are simplified instructions and assume that it is an IDE drive and not SATA and that no second hard drive will be installed on the same IDE bus. More detailed instructions can be found here:
http://www.helpwithpcs.com/upgrading/install-hard-drive.htm#install-new-hard-drive
Hope this helps,
erch.
Posted on Mar 14, 2008
My HP hard drive crashed,by virus. Was desperate and pulled my hard drive from Dell desktop that motherboard fried on. Of course non of product keys won't work from HP or Dell.Options?
restore the hp drive using the restore partition
restore the hp with the original disks if you have them
try to remove the viruses from hp drive
the dell drive would have all the drivers for everything on the dell
the product keys should work if you have the operating system on the sticker. download the windows version from microsoft on usb stick or burn dvd and reinstall it, if you don't have the disks
Nov 28, 2015 | Dell Computers & Internet
Sata driver download
Check your motherboard manufacturer's website. Sata drivers are not hard drive specific, they have to do with your motherboard. If your computer was pre built and you are simply upgrading it, check your pc manufacturer's website (Dell, HP etc.)
Sep 03, 2014 | Dell 2TB 7200RPM SATA 3Gbps 3.5-inch...
Imperial gl ve 20020930 SPECS
TriGem (Company) Imperial GLVE (Model)
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=bph07813&lc=en#N779
http://www.trigem.co.kr/tgservice/econsult/faqProduct04.asp?cls=0&Page=&ID=4237&C1=1&C2=68&C3=359&C_N=IMPERIAL-GLVE
Hmmm, I'm at a stalemate.
Looking at the specs for the motherboard chipset;
The Northbridge and Southbridge chip,
Intel 845GV
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
Supports CPU's with a 400MegaHertz Front Side Bus, or a
533MHz FSB.
Naturally I can't get a clear picture of those jumpers, but they look to be 3-pin.
If we are to assume that the jumper pins set the CPU FSB support, from 400MHz to 533MHz, then the jumper cap is moved from either
Pins 1 and 2, to Pins 2 and 3; on J2 jumper;
Or Pins 2 and 3, to Pins 1 and 2.
I know !O_O!
Sort of a guessing game, as to where the jumper cap goes to what pins, for 400MHz FSB support, or 533MHz FSB support.
Do you have any idea of what the FSB is for the old CPU (Processor), that was in the motherboard? (Or is)
Let's say 400MHz.
You now know if the CPU you are wanting to use, needs 533MHz Front Side Bus support, you need to move the jumper cap to the opposite pins.
What happens if it's wrong? Nothing. processor just won't work.
Change the jumper cap back.
(NOT plugged into power when you do. Also FOLLOW Anti-Static Precautions)
Yes. I'm 'out there on a limb'
I am assuming after looking at the TriGem support page, for the Imperial GLVE motherboard, that the J2 jumper is used to change the FSB support for the Processor.
It MAY be that J2 has Nothing to do with CPU Support.
It may be that there is no jumper for changing CPU FSB support.
(Cleared that right up, huh? Geez!)
For additional questions please post in a Comment.
Regards,
joecoolvette
[J1 = FDD. Floppy Disk Drive
J2 = CPU FSB jumper
J3 = CMOS Setup
J4 = CMOS,
IMHO ]
Feb 19, 2013 | Computers & Internet
I have a Dell Optiplex PC and I am having some problem with it. After switching it on for the first time and after 15-20 mins, it switches off by itself. After switching it on again, after 2-3 mins, it...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 12, 2011 | Dell (24048) Motherboard
I plug my hard drive in my pc then its like..beeep beeep beeeep the whole time.it is the hard drive i know it for a fact.pls help.cant loose the data.its 500gb sea gate.
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 24, 2011 | ASUS P4P800E Deluxe (90M8LCW0G0EAY)...
Dell 2.4 ghz , 30g hard drive crashed. new one gives plug and play error and won't boot off the hard drive
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 15, 2010 | Dell (2336V) Motherboard
I need a motherboard for "hp pavillion desktop mod.#a335w, but I have no idea about how to find a p/n or description.........Help
should be this one TriGem Imperial-GLVE
http://h10025.www1.hp.com/ewfrf/wc/g...cname=bph07813
pity it does not have agp. any m-atx or uATX whatever you like to call it should fit.
Quote: Glendale/Imperial TriGem Imperial-GLVE (31891.HPD.0000.D.0310140908) used in HP Pavilion models:-
503a, 503n, 503w, 513a, 513c, 513n, 513w, 522 cfg-PC, 522a, 523a, 532w, 533a, 533c, 533w (serno KR or CH), 542x, 563w, 712a, 742c, 752 cfg-PC, 752c, 752n, a200y, a400y, a210n, a200n, a376x, a347x, a342n, a340a, a335w, a320a, a317x, a310n, a305w, a302x, a300y
NOTE: It has been documented for the Echo GL Asus P4G533-LA/P4G533-GL (10/16/2003-I845G/ICH4/IT8708-P4G533LA )that it was also used for the pavilion a305w and in the following models:-
354n (US/CAN), 525w, 533w (serno MX IT8708F), a210n, a206x, a345w, a336n, a335w, a328d, a320d, a318d, a316n, a312d, a307i, a305wm, a305w, a305i, a300n, a424x, a422n, a412n
Sep 16, 2010 | Computers & Internet
My laptop had a ''smart failure predicted on hard disk 0: toshiba mk4025gas-(pm) Warning: immediately back up your data and replace youre hard disk drive. A failure may be imminent'' what does this...
This means that your laptop's motherboard has detected that the hard drive (where all of your data and operating system live) is operating outside of normal parameters. Hard drives are supposed to read/write/respond within specific parameters. If the drive stops operating within these parameters, it usually means that the drive is failing, and therefore your information should be backed up, and your drive should be replaced. Once you back up your data, you can contact HP support to get the hard drive replaced.
Mar 03, 2010 | HP Computers & Internet
Where do i find motherboard settings for my dell xps 400?
Ok i'm not sure exactly what you mean by motherboard settings, but i'm guessing your talking about the BIOS settigs where you get to setup a new hard drive, or check the memory settings, etc. If so, then you just need to press a specific key at startup before the whole windows thing starts. In most cases it will be the Delete button, but i've also seen F2, F12, F10, Insert and Escape. In most cases it will tell you which button for maybe a second at startup, but i know that most dell, hp and the like hide those screens at startup on their machine so the clients don't screw around with their machines and then have the company fix the problem under warranty cause they don't know how to bring back the settings to normal. In any case, if you do not see that button it tells you to press for the BIOS settings, then go to the dell website in the support section, you should be able to find the answer in the FAQs for your laptop model.
Jul 08, 2009 | Dell Computers & Internet
Monitor comes off and on
MOTHERBOARD MAY BE FAULTY CHECK  AND REPLACE IT
Oct 22, 2007 | Compaq (252608-001) Motherboard
Computers & Internet Logo
336 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
