Question about Akai PT4298HD Rear Projection Television
Fuzzy blue is that a practicle fix for me, or should I just get a new lamp?
    Genius:
  • 1,030 Answers
Are u a tech? if you going to replace the tube i dont feel there much difference. both involve remove tube and puting back in and adjusting...just that glycol change is cheaper than the whole tube replacement. a little more work. have u evere changed a tube
Posted on Mar 14, 2008
Dlp tv color goes fuzzy and green
Its probably unrelated to lamp, take the lamp out, try it again and look into the lens, if its still very green the projectors electronics are failing. The projector generates pictures as 3 streams of info Red Green and Blue. It looks like the projectors red and blue electronics are failing, but the green is working.
Dec 14, 2013 | Samsung Televison & Video
A colour bar blue on the bottom and green on top of42" LCD
it sounds like a lamp problem, did the support guys say anything about lamp possibly failing?
Apr 10, 2008 | Zenith E44W46LCD 44" Rear Projection...
Fuzzy ink
probably dirty or broken print head. suggest you replace it or get new blue cartridge if your machine has seperate colour cartridges.
Jun 17, 2009 | Brother MFC-5440CN All-In-One InkJet...
Fuzzy Picture
Fuzzy is a funny word. I never use it to describe a picture problem. That because fuzzy can go too many different ways. There is snowy fuzzy, blurry fuzzy, grainy fuzzy, and demodulated fuzzy. If the set goes out of focus intermittently that has something to do with the focus ciruitry. If it goes grainy that is a front end problem, usually tuner related. The other types of fuzzy are generally associated with problems in video processing some where. So, which is it?
Oh, and BTW that unit has three small picture tubes in it, one red, one blue, and one green. It doesn't have a 'bulb'.
Feb 24, 2009 | Mitsubishi WS-65869 65" Rear Projection...
RCA projection tv is blue and fuzzy
may be convegence try turning down the blue screen and see that that does see if the picture clears...
Feb 04, 2009 | RCA Televison & Video
I have a Panasonic model # PT-44LCX65 TV and have just replaced the lamp, as it was time to do so. A pink dot, that appeared before the old lamp needed replaced, remains on the picture. How is this fixed?
There are a few other threads on this board with the same issue, some say green spots, some say red spots, in my case it was blue/purple spots, but the solution is the same for all of them. Contact Panasonic and tell them that you read online that they are offering a warranty repair for this known "fuzzy spots" issue. They will send out a local repairman who will perform an EEPROM update to one of the computer chips inside of your TV, and viola good as new.
That is what others on this site suggested to me, and I did it and got all repairs covered under warranty by Panasonic even though my TV is 2+ out of the warranty period.
Jan 16, 2009 | Panasonic PT-44LCX65 Television
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
Repair on problem blue dot
Good Day, flavrlen;
This is your fix it is not costly and if you handle a screwdriver you can do this in 30 minutes:
PANASONIC:
MODELS: PT-44LCX65, PT52LCX15, PT-52LCX65, PT-52LCX35, PT-61LCX65,
PT-61LCX35.
SYMPTOMS: 1. FUZZY SPOTS
2. FUZZY SPOTS
3. FUZZY SPOTS WITH STAINS
4. FUZZY SPOTS & UPSIDE DOWN
5. FUZZY SPOTS WITH LINES
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM
CORRECTION TOOL; (LSUQ0100).
Good Luck, big IRISH.
Jul 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Fuzzy Blue...?
these set are bad about the blue tube messing up.. what happens is the convergence board witch generates alot of heat cooks the blue glycol.... basically growing algea in the blue tube... it is possible to remove the tube.. and remove glycol and clean the tube then replace and adjust..i have done a few here at the shop
Mar 14, 2008 | Akai PT4298HD Rear Projection Television
Sony Wega KDF-55WF655 blue ghost problem after replacing lamp
It is a defective light engine and it must be replaced. I hope you have a warranty because Sony will not help you.
Apr 06, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Akai PT4298HD Rear Projection Television Logo
27 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
