Question about Kitchen Ranges
Whirlpool free standing range model RF272LXTD / help with oven message
I have a brand new whirlpool range and the burners all work great but I get a message "f3" when i turn on the oven, it happens about a miniute or so after i turn on the oven and the burners in the oven do not turn on
    President:
  • 1,314 Answers
If its brand new call for service its the code for an oven probe anything you do will void your warrenty
Posted on Mar 14, 2008
Kenmore model 66575775890 oven. broiler and bake burners don't work. the igniters do work, they both glow VERY bright and hot
Hello Malibro,
You converted it to LPG. Did you also convert the oven nozzles?.
Because they need to be converted too.
Kind regards, Dik
Mar 27, 2018 | Kenmore Kitchen Ranges
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
My whirlpool SF265LXTS oven turns on properly, but the oven itself isn't getting hot. The gas stove top and broiler both work fine.
It sounds like you might have a clogged burner plate or manifold. You should call a certified gas repair service. This could be very dangerous, even deadly.
Dec 15, 2013 | Whirlpool SF265LXTS Kitchen Range
Kenmore free standing gas oven. Burners will
It sounds like the erc electronic range control has failed. Try this link it will walk you thru checking and replacing the erc http://appliancehelponline.com/ovenerc.html
Jul 16, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Burners indicators say they are on but no heat
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#%RW
Feb 26, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Loc error message
I unplugged the appliance for an hour and after re-plugging, the problem went away.
Nov 05, 2008 | Whirlpool SB160PEE Gas Single Oven
Both ovens do not heat max heat is 150 to 200
good luck.  We have the same range and have had issues with the ovens since the range was installed.  The overn does not heat evenly on convenction or bake.  Thermadore doesn't stand behind the product and neither does the distributor.  They tell us that Thermador isn't standing behind the product so there isn't anything that can be done.  We spent $8000 for an oven that burns the back corners of everything we bake.
Mar 21, 2007 | Thermador PG484GGEBS Stainless Steel...
Not a 965 problem but a 956 problem...
shogan, Most likely, the problem is with the circuit breaker. It became too weak for regular load. Replace the circuit breaker and I believe it will solve the problem. Gendos....post back
Jan 05, 2007 | Kenmore 96532 / 96534 / 96539 Electric...
Kitchen Ranges Logo
254 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
