Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Copier does blanks, moves paper, nothing on it.
Copier spits out paper, nothing on it.
  • 15 more comments
  • cespinoza30 Apr 14, 2008
    Print blank page, imageclass MF 6530 conan, new tuner, less then 1 year old, please help my Church, if you can provide me a number to call
  • Jaime Pagan
    Jaime Pagan Sep 05, 2008
    Blank copie, error light on, no error code
  • Anonymous Sep 11, 2008
    I try to copie, print but the Copier spits out paper, nothing on it
  • Anonymous Sep 12, 2008
    The machine acts like it's copying, but when the paper comes out there is nothing on it. There is no error light on the machine.
  • Anonymous Oct 06, 2008
    prints blank page. no error light. replaced toner. same problem.
  • lkdlaw Oct 08, 2008
    Canon MF 6500 new (expensive) toner but copier still spits out blank pages.
  • hollyl001 Oct 24, 2008
    no error code or light, acts like it's working - blank page is printed. Changed toner twice still same problem
  • Anonymous Dec 29, 2008
    same problem several times.
  • Anonymous Jan 05, 2009
    I see that some of the solutions were well ranked but how do i view the solutions
    my copier spits out blank sheets of paper
  • makinyouwell Jan 05, 2009
    The copier sounds as if it is working but the papers come out blank, no copies
  • Anonymous Jan 07, 2009
    thank uuuuu dy23 u saved us with this information and i cant thank u enough
  • Anonymous Jan 11, 2009
    My copier won't put the image on the paper, the paper runs through just fine, but spits out blanks. How do I fix this?
  • reedii Jan 17, 2009
    I have to believe this is a manufacturing defect and I will check with canon to see whether they have a fix for these at their expense. I was able to get temporary relief by moving the lever located on the right side of the shutter area. It did not want to move initially but later freed itself. Unfortunately, it is now repeating this behavior and I am going to try to remove the entire shutter.
  • didy_1021 Jan 22, 2009
    Printer or copier mode spits out blanks only
  • Anonymous Mar 02, 2009
    I had the same problem. dy23 thanks for the quick fix.
  • Anonymous Mar 27, 2009
    I had the same problem - dy23, thank you for the easy fix. Lisa
  • Anonymous Apr 28, 2009
    Thanks for the fix. this works.
  • 4 Answers
Reason : the shutter of the laser is not opened by the cartridge. (I had same problem, and solved it)
Open the door and remove the toner. look inside and you will see in the upper part a rectangular window in the metal bar. This window is shut by a metal plate behind when the door is open. Try to raise it with a knife. This is the problem. Now, this shutter is here only for legal reasons (security to prevent the laser beam going out when door open, but when the door is opened the power is shut so...). Cut a piece of plastic just the width of the opening, fold it at angle in the form or an L, then place it on the left side of the opening, so that the shutter can no longer go down. A piece of scotch to fix it in place and you are done.
Now, if it works and you are grateful, I am interested in empty cartridges.If you have some tell me. Thanks.
Posted on Dec 16, 2008
  • cars4riko May 24, 2011
    Very helpful, thanks. Its working now!!!
  • 3 Answers
I had this same problem with my Canon Image Class 6550 where blank sheets were coming out of the copier. I noted that it was the metal shutter that was staying closed. The shutter is in the metal bar (about 1/4 inch by 4 inches long)when you open the copier and removing the toner cartridge. It moves up and down to cover the laser. To keep the shutter in an open position, what I did was grabbed the middle of this shutter with a hemostat (or long thin pliers), pulled on it a little bit to distort the shutter. Then I moved the shutter up to the open position. By distorting the shutter when I pulled it, it created a situation where friction will hold the shutter in an open position all the time. This way, you do not have to put any foreign substances into the copier to hold open the shutter.
PS: When I called Canon tech support, their solution was for me to buy another original CANON toner cartridge. These suckers cost $150 to $180. I was using a knockoff cartridge for $40, which now works fine.
Posted on Mar 16, 2009
Thank you dy23. Canon product support was useless resolving this known issue. Without your helpful solution, I would have been throwing this otherwise fine piece of machinery in the trash. What a waste that would have been. I will send you cartridges if you send me an e-mail: don.mckinnon@yahoo.com
Posted on Dec 03, 2009
Dy23 You're a genius! Thanks for putting the time into figuring this out. Saved me a lot of time and trouble. had it fixed in about 2 minutes!
Posted on Feb 26, 2009
  • Scurby Feb 26, 2009
    dy23 You're a genius! Thanks for putting the time into figuring this out. Saved me a lot of time and trouble. had it fixed in about 2 minutes!
    Must have put this in the wrong field... sorry
    dy23 I work for a company looking for someone to take used toner cartridges. If intrested email me at tmeast@cellarlab.com
It prints but its comes out blank
Posted on Oct 07, 2008
Yes print black page MF 6530
Posted on Apr 14, 2008
Sharp Al1631 unit won't copy; just spits out blank papers
check for empty toner... and if the laser lamp is dim or out... the laser lamp is the lamp that comes on when you copy from the glass table or through the document feeder
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 09, 2009 | Sharp AL 1631 Copier
No image on copies
Hello sir; The problem in the cartridge which you just replace, get the receipt with cartridge go back to the store wherever you bought make a exchange.
Jun 08, 2009 | Xerox DocuColor 12 Color Copier
PRINTS BLANK(NOTHING APPEARS ON THE PAPER)
I don't know you talking about color printer or black/white or copier that is all difference, if copier, you have go to check the charge&discharge corona wire if black/white printer you have check the image roller both end contact is clean,
Dec 11, 2008 | Sharp AR-5320 Black and White Copier
Sharp copier al1631 , putin new toner sometimes shows CH
the drum might not be rotating due to either the drum gear is wornout or the drum drive gear on the machine main drive unitis wornout.
Nov 26, 2008 | Sharp AL 1631 Copier
Won't copy spits out blank paper occasionally CH will flash
Go to www.sharpusa.com. Type in the model number in the copier section to get a new owners manual.
Is there any errror codes?
ayou have a problem to charge and transfer/separator coronas unit.
Oct 28, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
524 people viewed this question
old marine
old marine
