Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung hc-p4752w my samsung has messed up. my blue has bowed down from the top of the screen. i have heard it is the ic convergence. if this is so how many do i order and what is the part number for them i have a samsung hc-p4752w any help would be great.
    President:
  • 4,402 Answers
Sounds like convergence amp ic's
i dont have any part number for that model.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Posted on Mar 14, 2008
I have a Samsung Rear Projection TV with an HDTV 1080i Monitor. I know the convergence is messed up because the blue would not move when I tried to adjust it on the menu. So, then I tried to make it
You will need to replace both convergence Ics and the pico fuses that blow when the Ics fail. You can get the replacement Ics and pico fuses from www.tvreairworld.com they also provide free tech support to help you install them
Oct 27, 2012 | Samsung HC-P4752W 47" Rear Projection...
Hour glass bowing on the top and bottom of my HCP4752W Samsung
Check the resistors near the ic, and the fuses to the ic's, i bet you will find an open fuse. the fuse will look similar to a resistor without color bands. use a dvm and set it on ohms, with the tv turned off.
Sep 02, 2009 | Samsung HC-P4752W 47" Rear Projection...
RED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T ADJUST
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
Convergence problem Mitsubishi 6043
DOES IT AUTOMATIC CONVERGENCE,,TRY THAT,,IN THE MENU,,TRY NEW JACKS
Mar 27, 2009 | Samsung HC-P4752W 47" Rear Projection...
Sam Sung Rear Projection HC-P4752W
I would quess that its most likely a resistor that opened when the origional IC went out. I dont have the specifics on your set. But rule of thumb is to run the set for a minute then shut it off and the affected IC will be much hotter than the one thats not having difficulty. I will try and locate a service manual for your model and look it up for you. I will repost if I find out which IC controls RED.
Mar 21, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4752w
Not sure of the part number most use STK392-110 or 120s . You will need to look at the ics in your set they will have the IC numbers stamped on them they will have STKxxx-xxx whatever that number is thats the sanyo part number for those ICs
Mar 14, 2008 | Samsung HC-P4752W 47" Rear Projection...
Blue color is out of position
sure sounds like convergance problem
http://www.partstore.com/Part/Samsung/
Jan 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W Ghosting, seeing yellow, bowed lower left
What might be happening is that your convergence is out of adjustment. Before removing the Convergence ICs try to adjust your convergence either from the onscreen adjustment (see your owners manual) or by using a signal generator (if you have one). I am against this "lets start swapping parts out" craze that has become the norm because you never fix the cause of your problem just the symptoms. I would suggest trying to adjust the convergence first. Thank you, Shuttle83,
Oct 08, 2007 | Samsung HC-P4752W 47" Rear Projection...
HC-P4752W Blue Convergence??
You can replace the whole board, or opt to replace just the 2 IC's and a resistor or 2 that has probably failed. Lift the chassis & inspect the pins of the 2 IC convergence chips for hair line cracks around them. Inspect the small resistors out in front of the IC's for discoloring or burnt look compared to other similar resistors. The convergence board will cost much more than having the above repaced. Chips about fifeteen a piece, resisters .50 cents each plus shipping. Convergence board $100 plus.
Jul 22, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
79 people viewed this question
Henry  Thomas
Henry Thomas
