Question about Nintendo DS Console
It turns off if moved
Hi
i have had my ds for 3 months now and it was working fine until recently it turns off if moved even slightly.i've tried playing it while staying almost motionless but it's pretty irritating.i wonder what's wrong with it and if i can fix it?
  • 52 Answers
Sounds like you damaged the battery or the logic board. get it serviced
Posted on Mar 17, 2008
Onn Wireless Mouse has stopped working. What do I do?
Mine would work fine until I turned on my wireless headphones...then the mouse would move a little stop.....move a little....then stop.
I made sure my headphones were on.
I turned off the mouse, moved the mouse reciver to a USB port on the front of my computer (the mouse reciver and the headphone receivers were next to each other on the back of the computer). I turned the mouse back on.
The computer imediately gave me the "installing USB driver" notification.
When it was complete....both played nicely together...no more problems.
Jun 28, 2012 | Computers & Internet
Nintendo ds lite keeps shutting off
you probably have a power shortage when you move the screen. the only way to fix this is to open the ds, make sure everything is in the right place, and put it back together. i cant promise this will work, but it should.
Jan 13, 2010 | Nintendo DS Lite Console
I have a usb mouse that recently has stopped moving correctly
hi frnd... Mouse works fine only on plain surfaces.. mattress are not straight so they might create problem...
Sep 29, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
The slide to turn on the phone will not move.
Try using the stylus located bottom right. Use finger nail to flick out. Once you've done this select settings and select pen calibration until Done appears on screen this sets the sensor according to your touch!
All the best.
Aug 12, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Nintendo ds lite problem
Is there a slight or faint image still in the background?
Aug 15, 2008 | Video Game Consoles & Games
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Power problems with DS Lite
Really sounds like a dead battery. The DS will not work if the battery is bad even when it's plugged in. You get the quick flash of the power light and that's it.
Mar 29, 2008 | Nintendo DS Console
Sound cuts out when you touch the cord???
bad cable shorted out in it can u get new cable or under warenty for 1 yr ?
Jan 09, 2008 | Logitech Z-5500 Computer Speakers
Nintendo DS Lite shuts off randomly.
I'm a certified electronic technician and I must say NDS internal screen ribbon connectors are junk! Basically The ribbon connectors are so sketchy that it is not recommended to ever unclip them, if you do there's a good chance it will ever work again once reconnected due to how the connector pins slightly crimp into the ribbon pads.
When a NDS boots up the the onboard firmware constantly tests the LCD screen connections, if there is a break in the connection the NDS will shut down. If your NDS randomly turns off, fails to boot, or powers of when you move the hinge it is most likely the ribbon (flex film) or ribbon connector has failed. The only option to to replace the affected LCD screen.
Jan 08, 2008 | Nintendo DS Lite Console
Nintendo DS Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
