Question about Lexmark X9350 All-In-One InkJet Printer
My laxmark x9350 and vista
I have a lexmark all in one printer x9350. I have trouble going wireless. I can not get it to connect to my laptop which I have windows vista. Can you help? Thanks Diane Two lap tops both dell. One on vista, one on xp. have intermittent wireless connection to printer, works fine for a day or so. Sometimes one lap-top
works and one not. Have re-installed drivers many times. now in situation where installation cannot find the printer to configure it. Have used vista and xp drivers as appropriate.
  • 818 Answers
  • 73 Answers
Have used the latest drivers from webite for yours and did u have older printe ron it before this thx nick
Posted on Mar 14, 2008
  • 6 more comments
  • djnick989payments jones
    hers the link read this do this u have to rest it to 0 so it reloads it self eash time your settings are mesed up read this folow it close ok give me sec ill send u link to read hold on
    http://wiki.answers.com/Q/Why_does_'Error_1068_The_Dependency_Service_or_Group_Failed_To_Start'_appear_when_starting_the_remote_access_auto_connection_manager_or_print_spooler_in_Windows_XP
    thats why ok please follow this close read it it will be fixed thx agai nick
    u gotta chage the dependietes in to 0 so it resets itself for vista ok
    ****If it is a LEXMARK or DELL printer make sure that:
    1. Go to Start > Run and type in services.msc then press Enter. 2. Click on Lexbces > Right click - Properties, Change recovery to automatic instead of disabled.
    Quick and easy.
    Error 1068
    One Reason for the error "Error 1068: The Dependency Service or Group Failed To Start" can be: Changed in the path of service exe in harddisk.
    Example: if service exe location is (service properties shows) :: c:\Program files\xyz\abc\my_service.exe and if we change "xyz" to "wxy" folder and try to restart the service. it will give the above error.
    Fixing this issue is quite simple. I had the same issue myself and after a LOT of research, I found the following steps extremely simple and it fixes the issue immediately.
    2. In the window that opens find "Print Spooler" on the right
    3. Right-click "Print Spooler" and select "Properties".
    4. Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
    5. Make sure the 2 text boxes underneath say "1" in them.
    6. Click Ok until you are back at the Services window, close it and you're good to go.
    7. Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
    You're all set! Now when ever your Print Spooler craps out, it will automatically reset itself.
    More input and advice:
    • There is another cuase for this error. If you have ever had a lexmark printer driver (which may also have been installed with a non-Lexmark printer, like a Dell) then you will find a small program called LexBce. This is usually a service and can be found under Control Panel->Services. LexBce needs to also be running before Print Spooler will run. I hopethis helps someone else. It tooks me hours to resolve this problem :-)
    • Guys there is a simple answer if your looking out for Lexmark printer causing these issues, do START > RUN >Services.msc , thn Open Print Spooler, Restart the service n keep the startup type as Automatic, if u still get the error msg, thn chk the dependencies tab n thn chk for the services under it, and thn enable services namely, "Remote Procedure Call" Fax "LexBce Server", If one of this svc doesn't start, chk their dependencies list n try to enable as much as possible, it has to work, has always worked for me as a DELL TECHNICIAN. (From another: Thanks, Dell technician, this worked for me. It allowed me to enable the print spooler. However when tried to print job it gave error "printer not found" so I did a restart spooler from the services.msc window and it worked.)
    • Thanks Dell Tech Dude! Everything you had mentioned got me on my way. I had deleted the lexbces.exe since I removed the lexmark printer.After that I was unable to get it started again. If you delete this you will have to re-install it in windows/system32/.
    How to remove the old Lexmark Driver http://support.lexmark.com/cgi-perl/know...
    1. At the command prompt type lexbces -u and press ENTER. You will receive confirmation that the file has been removed and that you have to delete one other lexbces.exe file manually.
    2. Use the Search option to find the lexbces.exe file and then delete it from C:\Windows\System32.
      Windows 2000: Delete the file lexbces.exe from C:\WINNT\system32.
    3. Go to Start, Control Panel, Administrative Tools, Services.
      Windows 2000: Go to Start, Settings, Control Panel, Administrative Tools, Services.
    4. Right click on the Print Spooler.
    5. Go to Properties and click on Start.
    6. Click on Apply and then on OK.
    dont forget to rate what one help u most
    please vote on one of us so we get paid thx nick
    olcodger u have to vote fix ya on me or we dont get paid now ok new site policy so please do
    if u dont vote website keeps our money so please vote
My Lexmark X9350 "can't associate with wireless
Even though the printer says it supports WPA encryption, it does not. It will work if configured for the far less secure WEP.
This is the only answer that I have, unfortunately. The X9350 is a terrible machine.
Dec 09, 2010 | Lexmark X9350 All-In-One InkJet Printer
The drivers are sadly meant for XP. As of now, I don't think there are Vista drivers that can actually work.
I'm sorry!
Please let me know if this helps. Good luck!
Mar 01, 2008 | Lexmark X9350 All-In-One InkJet Printer
I need to print from laptop to wireless lexmark 9350. how do i do it
Check the following steps:
1. Scan for the available wireless networks on laptop.
2. Check the network and select the desired wireless ssid which is for printer
3. If is it password protected than proviode the password.
4. Connect to the network.
5. Then print.
**If this works please rate else let me know in case of further help.**
Jul 05, 2010 | Lexmark X9350 All-In-One InkJet Printer
How do i turn my wifi on, on my lexmark x9350
Hi there
fi yopu go to internet connections and look for the wireless connection right click on it and see if you see enable this device than click on it if not you will need to make sure that there are no other connectons the computer is using for the internet ie dsl ok
Feb 28, 2009 | Lexmark X9350 All-In-One InkJet Printer
Install Lexmark 9350 printer on laptop
please follow the link below to download the driver for your printer directly from Lexmark.
For Lexmark http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
use the product selector to select your exact model and operating system.
Sep 28, 2008 | Lexmark X9350 All-In-One InkJet Printer
Installation
Hi Levi - if you're looking for drivers/software follow the link below. Just choose your operating syetem and you'll be able to download what you need. If you're having some other kind of problem, just add a comment to this post letting me know the details of the problem and I'll be glad to assist you. Thanks.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:0:0:0
Apr 30, 2008 | Lexmark X9350 All-In-One InkJet Printer
I talked to DEll and they walked me thrugh it . Thanks, Diane
Feb 26, 2008 | Lexmark X9350 All-In-One InkJet Printer
Error Scanning from All-In-One to Vista
This appears to be a Vista driver software issue- check out Lexmark for any updates
You can also try the followng.
go to--- Start/Programs/Accessories/system Tools/Compatibility Wizard and try resetting the machine to run as XP
Jan 25, 2008 | Lexmark X9350 All-In-One InkJet Printer
Not compatible with windows vista
You can download the Vista drivers from the Lexmark website...www.lexmark.com / support.lexmark.com
Else you can contact Lexmark and they will ship a cd with the drivers to your door.
Dec 22, 2007 | Lexmark X9350 All-In-One InkJet Printer
Lexmark X9350 All-In-One InkJet Printer Logo
140 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
