Question about Polaroid FLM-2601 Television
Polariod FLM2601 Power Problem
Hi. I saw your post about the problem with the unit not turning on. I have a red light but no picture. Pressing remote power button or unit power button does nothing. Went to Radio Shack and got (2) 1000uF 35wvdc capacitors. Removed bulged ones in unit and replaced. Still no picture. Any suggestions?
I don't know why it isn't working, but I did feel I should say that if you do get it fixed I would change those capacitors out. The original capacitors that you replaced were high temperature electrolytics, rated to 105 degrees Celsius. the radio shack capacitors are rated at 85 degrees Fahrenheit maximum. As I believe that this common problem with these units is caused by those capacitors overheating, I would highly recommend you use replacements with an equivalent or higher temperature rating.
Posted on May 03, 2008
Westinghouse ew32s5kw tv red light shows power is going to unit pressing power turns indicator light from red to blue for a brief moment then back to red.
I had the same problem on my Westinghouse 32 inch TV. The internal main power supply went bad and had to be replaced. I had a TV repair shop do it. It was about 8 years ago. Haven't had a problem since. I think it cost about $70 for parts and labor. Nowadays TVs are pretty much a throw away item if they go bad. TV repair shops are getting hard to find plus the cost of TVs has come down so much sometimes you can get a new set for what the repair would cost!
Oct 25, 2017 | Westinghouse Televison & Video
The remote will not turn the TV on. When I turn it on with the button on the front, the power light on the TV starts blinking (no sound or picture). The red light will blink forever, and the TV will n
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Nov 01, 2014 | Toshiba Televison & Video
Red led blinking. tv wont turn on model number
Hi Rick,
First of all, thank you for posting your question here at Fixya.
My first advice is to unplug the unit from the outlet at least 30 minutes to reset itself and check if the symptoms still persists. If yes, may I know if it encountered before then there's some instances that the unit will power up after a few minutes of pressing the power button key?
Also, please double check the model number of your unit, if I'm not mistaken, it is 50H81 not 50H87.
Jdvillanueva
Jan 21, 2012 | Toshiba Televison & Video
Polariod LCD FLM3732 does not show picture but has power
Its possible that you have some bad Electrolitic Capacitors. They are a very easy fix and very easy to see if they are bad. I have some vids posted on youtube on the fix for this. It only costs a few dollars to do. Just search on youtube for flm3732 repair or go right to my channel youtube.com/raider2845 and watch the 5 short vids I had posted.
May 26, 2009 | Polaroid FLM-3732 Television
FLM2601 powers up and works for about 5 mins and then powers off
have you checked out your power supply? if the caps are going bad then that may be the problem
Feb 28, 2009 | Polaroid FLM-2601 Television
Camera Trouble
Check your batteries. If it is not the batteries then it is the power board of the camera
Dec 31, 2008 | Polaroid i735 Digital Camera
Needmod.flm2601 power suply fora polarold tv
Hi
what happen to your unit?
Thanks!
Aug 22, 2008 | Televison & Video
Flm-3201
I would replace the control box assembly that is the most common issue with those TVs
May 22, 2008 | Televison & Video
Polaroid FLM-2601 Television Logo
71 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
