Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WS55513 Hello again.... Starting on this project again. I have the chassis, slider board assy completely removed from the wood housing...and am attempting to start my quest of finding a faulty component or a few. Like I said before, I did the DM board repair several months ago and put it all back together but got no power, no LEDS, nada. Perhaps I overlooked something, but while I have this boards assy fully removed from the chassis, I want to check every possible component that I can before I attempt to put it all back together. FYI.. I got a PDF of the entire service manual and schematic of that model but the schematic is so small I am having trouble reading it (my eyes arent what they once where) Any thoughts were I might pay strict attention to? Thank you in advance... -Richard (MetalDad)
  • Angered Apr 19, 2008
    Metal Dad-
    We have the service manual, but not the schematics. Is there a way you can send them to us at [email protected] ? Appreciate it.
Hello I have a wd-52825 mitsubishi 2004.. it was working fine until last week.. I did replace the lamp and now I have new problems . green light came on, then a sound like weeeeeeeeeeeeeee for maybe 2minutes . here we go .. green light go off..
Help please
Posted on Mar 27, 2008
SOURCE:
Dnm board on 52 in dlp is bad
Hello.
Mitsubishi had class action because of this issue. The right way to fix this and several upcoming problems is to rebuild chassis. Chassis is a "sandwich" of 5 boards and they all have bad components. Unfortunately recall is expired by now.
Mitsubishi does rebuild it for $320 plus you have to pay technician for removal/installation (minimum $150). Add shipping (around $60) and fact that this TV need lamp replacement on regular basis (another $180-$220).
Common sense is to just stop investing money for repair of this bottomless pit and invest in new TV.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a 60" rear projection Mitsubishi Tv with a "wavy" picture in the vertical direction. What may be the problem?
Hello.
You have dreaded model that build around so called V-26 chassis. It's an epic story of Mitsubishi's bad engineering several years ago. They even faced class action about it and issued recall that (of course) already expired by now. You can search web for info on court case against Mitsubishi. This particular issue is caused by faulty components in Format board that is part of the chassis. The only right way to fix it - is to remove whole chassis (sandwich of several boards in metal enclosure) and send it to Mitsubishi to get rebuilt. If you will pay someone for repair of just this board - soon others will fail as well, one of another associated issue - after unplugging TV from the wall outlet you have green blinking light forever (reboot does not come to complete).
Right now Mitsubishi lowered price for rebuilding from $640 to $320 for authorized Repair Centers nationwide. Add to it labor charge for removal/installation (at least $150) and shipping (Mitsubishi assign number for repair and send special padded box that fits chassis) at least another $50.
Also take into consideration that lamp inside of your TV sooner or later have to be replaced. It is another $150-$225.
Calculate all of this together - that's how much you have to spend to watch your TV for another 2-3 years.
Common sense would be to cut you losses and invest in new one.
As for my experience - I've removed/installed those V-26 chassis about 1000 times or so while working for Mitsubishi Authorized Center.
Hope my knowledge of this issue would help you save some money.
Regards.
Russ.
Aug 18, 2010 | Mitsubishi WD-62525 62" Rear Projection...
WS55513 image permanently burnt in
Need a complete set of CRTs we would do it for $120 for each one -Installed
Jan 02, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Blinking green light of death on Mit WS55513. Changed the four 1000uf (35) capacitors on the DM board and it still won't work. Nothing has changed. Any help? Thankyou, [email protected]
THEY are green and look like 1/2 watt resistor but will have amperage marked on them and the board--there at least 2 of them near the caps--if you need a photo of what they look like [email protected] chips will not cause the set to not boot up (the green light blinks and does not stop)
I do this here for free so if this information was helpful give me a vote here--good luck---if you cannot fix the receiver the only choice is to contact PTS electronics--you can ship it to them for repair/rebuild---part no longer is available from MITSUBISHI.
REGARDS, SD TECH
Sep 13, 2009 | Mitsubishi WS-55513 55" Rear Projection...
My Mitsubishi WD-52525 is only showing black and white rectangles on the screen. I hear sound, but there is no picture.
Check the white rectangular ceramic fuses on the FMT board. You blew one of them so there's power missing to some of the circuitry.
Jun 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
65" mitsubishi with green blinking lite
Probly yes. Not knowing the exact model #
i can not tell you whether or not the chassi assy would have to be sent to Mitsubishi for
refurbishing or not. If it is a 7 year old crt based projection, there is a DM assy that is no longer supported by Mitsubishi. If it is the last series of crt the DM is repaiable.
Otherwise the chassi would have to be sent
to Mitsubishi for refurb. You will need to contact a service facilty for Mitsubishi to
do this. A average cost of referb. is around
800.00 plus labor of uninstalling and reinstalling.
Good Luck,
Hope this helped,
Skyassoc
Jun 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Red lamp light stays light
I doubt that it is the optical assy. it sounds more like a chassis problem either on the DM or the FMT board.
check out www.tv-techs.com
if it is a chassis problem it will cost about $250.00 plus shipping one way to fix the chassis
Dec 30, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Need replacement DM Board ASAP
Go to this site and leave an email with the model number of your set and which board youre looking for they will be able to help you out, and they respond quickly
http://servicemanuals.vstore.ca/
May 03, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Used / Refurbed / Remanufactured PCB's?
sure...you can find them online..most of them are coming from China now...just enter that phrase into google.
Apr 29, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS55513 ---Flashing Green LEDs...and now NO POWER.. Hi...got the entire board / chassis out of the TV shell. Going to start checking individual components, starting with the mail power supply...
start by pulling the DM board (looking from the back it is standing upright on the left side in a metal chassis) and you'll probably find 4 bad capacitors (bulging on the tops is a good indication, If i remember correctly they are near the top right corner)
you can buy replacements here..
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=P13119-ND
Fixed mine this way several months ago..still working like new.
Good luck
Mar 17, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
