Question about HP Pavilion ze4220 Notebook
Installing Wireless Antenna HP ZE4210
I have an older HP laptop. Looking for instruction on how to install the antenna for minipci wireless card
    Genius:
  • 1,019 Answers
The information you require Should be here:-
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=us&product=242218&dlc=en&lang=en&
Mike @ compurepair.
Posted on Mar 14, 2008
SOURCE:
Installing wifi card 319468-002 in ze 5185
hi
thank you for using Fixya
in your laptop has a no antenna there will be wifi radio only
There is no hard switch for the wifi radio in your laptop model. Look at the Function Keys and tap the key that enables wifi radio
May 15, 2010 | HP (319468-002) (319468002) 802.11b...
No Wireless signal on Presario 2170US Model #DK587AOptions I added a wireless card to my Presario. However when checking the service manual it states "CAUTION: Be careful when connecting and disconnecting...
My 2170US does not have built in wireless like some of the other HP or Compaq models of the same vintage. Buying a mini pci wireless card wont make the wireless work. You will need a wireless card for the pcmcia slot on the left side of the laptop then your wireless will work. If there is an issue with the pcmcia slot a cheap work around is to buy a usb. based wireless card and use one of the two usb.slots in the back. It's not high speed usb.2.0 so it may run a little slower. As long as your pcmcia slot works just install the the card that you can buy even at walmart install the software and your wireless should be up and running. Its an old laptop and not worth spending a bunch of money on when new or used much better machines are out there.
Mar 19, 2010 | Compaq Presario 2170US Notebook
How to reple wifi 5610
It is underneath the unit you will see removable flaps, unscrew the biggest one, usually it is there, the WiFi card is a small card with Antenna wires coming out of it, it slots into a MiniPCI slot. Check this also check your WiFi isn't turned OFF via the switch.
Mar 04, 2010 | Acer Aspire 5610-4648 Notebook
Have 2wire gateway wireless internet device. I want to setup HP Media center PC M1160N for wireless operation.
according to amazon your system doesn't have a wireless card in it. You will need to purchase a PCI Card or USB Wireless antenna. The USB will be easier to install. Once this is installed using the instructions that come with the antenna, use the 2wire's instructions on setting up a wireless network. This usually involves using the code on the bottom of the 2wire as a key.
Dec 18, 2009 | Computers & Internet
How do I get my Balance Laptop model A535 to be wireless?
There are three possible ways. 1. If the notebook has an available miniPCI socket in a compartment on the bottom of the PC, a wireless card can be installed there. However, the antenna wires are nearly impossible to connect. I would pick one of the following: 2. Get a wireless PC Card for notebooks, or 3. Get a USB wireless device (works on notebooks and desktops. This option is easiest, and usually cheapest. Follow the instructions that come with it, and you're all set. I use a USB wireless device when I work on PCs, to get out to the Internet and download drivers and such.
Mar 04, 2009 | Computers & Internet
Mini pci wifi for toshiba 1405 s-171 laptop winxp
As long as you have an open minipci slot, they should work. The antenna pigtails should plug into the card as well.
Oct 02, 2008 | Toshiba Satellite 1405-S151 Notebook
Installing a wireless card in my presario 2200
The easyest way would be to buy a USB wireless adapter.
You just plug it in install the software and thats it.
I'm useing a TPLINK USB adapter, it cost me 20 €
You can also use a internal card, Mini pci most likely. very simple to install also but you might have signal - antenna problems. But this tplink has worked very well in my home and in the city.
May 17, 2008 | HP Compaq Presario 2200 Notebook
Wireless will not fully activate
Well, your wireless adapter most likely isnt the same brand as the router you are using. I have a simple suggestion. Go to a local reatiler like Office Depot, and buy a wireless notebook card matching the brand of your router. If the problem continues, then simply return the wireless card for a full refund.
Mar 23, 2008 | Computers & Internet
Wireless conection
That depends. What is the make of the LT?
Jan 14, 2008 | Acer Aspire 3690-2196 Notebook
HP Pavilion ze4220 Notebook Logo
204 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
