Vacuums
Problem for Vacuums
Generic problem for all Vacuums
Bissell Pro Heat 2x steam cleaner, pro...
By slwood62 on Mar 14, 2008
I have a Bissell Pro Heat 2x steam cleaner. The belts both appear to be okay, yet the brushes won't rotate. Is there anything else I can try to see if I can fix it?
Same Problem
Nov 13, 2008
-   it seems like the contact that stop the brushes in the handle up mode are not working-   Guest
Jun 02, 2008
-   I have the same problem. The belts both appear to be okay. The machine will work for 4 or 5 minutes and then there is a little beep noise (I believe this is the circuit breaker kicking) and the belts will stop. I unplug the machine and plug it back in and it will go again for another 4 or 5 minutes and do the same thing. In your previous answer to someone you suggested the brush motor might be bad #35 in picture, would mine go on and off like this or do you think it might be something else? It is out of warranty, and with shop repairs being so high, not sure if I should fix it. I would appreciate any advise you can give.
Thanks,
Linda -   Guest
Best Solution
posted on Jun 25, 2008
Helpful)
ddoiron
Rank: Apprentice
Rating: 83%, 3 votes
I took the side plastic protectors off because my brushes stopped working. I found one belt almost broken (held together by the fiber to the interior) and when I moved the brush rollers, I found mucho dog hair on the ends. Your rollers might be removed and see if you have the same problem. IT just takes two screws on each end to do this, so if your belts are good, take a look at each end where the metal post goes into it. I have two dogs and their hair is just everywhere!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 15, 2008
Somewhat Helpful)
reddevil6
Rank: Guru
Rating: 88%, 1792 votes
Must likely the brush motor is bad. The top cover has to come off to check it, this is where the tank sits on. Part # 2036757 and is #35 in the pix.
Was this helpful?
Yes
No
Popular Solutions for Vacuums
Questions and Unsolved Problems for Vacuums
Answer
what type of battery does this vacum have. Also what is the voltage.
Answer
vacuum for mohawk smartstrand carpet, what is the best vacuum to use? We need a new vacuum any way.... (More)
Answer
Electrolux Oxygen Z5530 stopped working and the Filter light and face light are flashing, but both... (More)
Answer
Dog hair gets caught all the time in the belt drive spool, is there a fix for this other than having... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
