Question about Brother MFC-5840CN All-In-One InkJet Printer
Unable to print message on Printer LCD
I tried the steps you suggested for the same problem I'm having with my MFC 640CW, but nothing happened when i went through the steps, Can you help me fix my printer. Thanks
  • 832 Answers
Please press menu then start bk-copy (blue-button) then fourtimes arrow-up quickly one after another. machine will be in maintnenace press start bk copy again. What two digit error code does the machine display? Post again here.
(There are more than 20 diffrent errors for unable to print behind ;-))
Posted on Mar 15, 2008
Mfc 640cw has a message unable to clean
This usually means the cartridge itself has developed a problem.
Try removing the cartridge and wiping the print head of the with a clean non-lint rag and alcohol. Then replace the cartridge, sith the printer off if possible. Turn on printer and attempt to have the printer software clean the head again. If negative you may need to replace the cartridge but use an OEM recommended cartridge replacement. After market brands tend to create more issues.
My name is Ed Pinero I am a 10 year veteran in IT and a field service technician.
Dec 29, 2012 | Brother MFC-640CW All-In-One InkJet...
Unable to clean print heads
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 24, 2009 | Brother MFC-640CW All-In-One InkJet...
MFC-640CW Switch on error message: "Unable to Init! - User Guide says this is a mechanical fault or jam - not a jam all clear. There is an empty Cyan ink cartridge message as well which is correct. Also...
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Nov 09, 2009 | Brother MFC-640CW All-In-One InkJet...
Unable to print when the machine was receiving the fax, phone call rang then it stoped to receive the fax and I got a message "unable to print" I checked everything by user's guide but couldn't fix. Please...
OK ill help you A faxmachine has a buffer on it what it does is fasimilate the data into a text or message that can be printed what happens here is you have fax/printer the buffer for the printer should be on your computer and not be sent until your ready to print (also known as the print que) all print jobs should be saved when a fax comes in but when a fax comes in and you dont have print que software your printjob is lost. But this brand is familiar to me so the software you install for this hardware should have a print que or buffer so you dont have this problem maybe you need the new BROTHER MFC software at the following link http://www.pronto.com/user/search.do?displayQuery=brother%20mfc%2Fsoftware&SEM=true&query=brother%20mfc%2Fsoftware&adid=1196541613-6635448d-0_mes&ref=brother%20mfc%20software&creativeid={creative}&site={placement}&loadingComplete=true
Oct 19, 2009 | Brother MFC-640CW All-In-One InkJet...
Unable to print 30
the encoder strip is out of position. The strip is the foil which runs paralell to ph direction (and gives the ph the position info).
You have to open the printer and set it back into the ph carrier.
http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c
(use google for translation)
Apr 04, 2008 | Brother MFC-640CW All-In-One InkJet...
The print head is defective and needs replacement.
BTW the sparepart costs quite a lot of money.
Its better to buy a new mfc!
Sorry!
Mar 17, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
115 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
