Question about Motorola Mobility RAZR V3
Text messaging how do you spell words when text messaging (T9)
You push the # and then select the latter or letters you want with the arrow pad.
Posted on Mar 14, 2008
How to add words to the t9 dictionary.
Adding words to your phone's T9 dictionary is quite simple.
If you have a newer model phone with newer versions of T9 when you try to enter a word that isn't recognized you should be presented with a prompt that says "Add word" or "Spell".
If you have an older version of T9 don't despair you can still add words. All you have to do in this case is: switch from T9 mode to "abc" mode and spell the word one letter at a time, hit the space key, then switch back to T9 mode. Whatever word you just spelled has now been added to your T9 dictionary.
Jul 24, 2011 | Cell Phones
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
How do you take t9 off phone
Hi!
I have a D900i & the way to change from T9 in a text message is to press the button on the top right hand side. It looks like 3 dots, one on top of the other. You can use this button to switch between T9, Symbols, Numbers & manual spell modes.
There's no way of removing T9 all together but your phone should remember your preference & default to manual spell each time you need to type something.
Hope this helps!
Nov 16, 2009 | Samsung SGH-D900 Cellular Phone
How to take t9 off boost mobile i570?
There is no option on the i570 to actually " Turn off " T9, but there is the option to switch from "Word" to "Alpha" with eliminates the annoying T9 from interrupting your text message. The way you do this is by creating a new SMS text message or "Reply" to an existing message in you inbox. Either way works. Once in the new message window you want to press the "menu" key you will see "Entry Method", you then just want to select "Alpha" instead of "word" and the T9 will no longer be active.
Nov 16, 2009 | Cell Phones
I'm old and not very with it,I can't work out how to delete letters when wrong, etc etc. is there information about texting?
The information on texting is very simple
to delete press the clear buttion or maybe say CLR
to text there is two different options the ABC or the T9. The easiest is the T9 because when you press the letters it makes the word come out but you have to spell the word with the keyboard
For example if you would like to spell "Kite"
it would be like this 5483
Oct 19, 2009 | Cell Phones
T9 Dictionary on Samsung SGH-A707
The only way to fix this is to completely reset your message memory. To do this, go to Menu -> Settings -> Memory Settings -> Clear Memory -> then click Messaging and OK. You will be prompted to enter your password. Enter it, confirm and you should have no problems.
Feb 24, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Predictive Text
To get predictive text on or off on the LG Shine go to:
>Menu
>Messaging
>New Message
>Text
>Options
>T9 languages
>T9 on/off
Sep 01, 2008 | LG Shine KE970 Cellular Phone
Text Messaging
You need to go to options and take the setting of T9 out. T9 is the setting that will spell out words for you as you go through typing the word.
Aug 28, 2008 | Samsung SYNC SGH-A707 Cellular Phone
The text dictionary keeps giving me the wrong words and i cant change, how do you knock it off. the phones a samsung d900i
Using T9 mode
T9 is a predictive text input mode that allows you to
key in any character using single keystrokes.
Entering a word in T9 mode
1. Press [2] to [9] to start entering a word. Press
each key once for each letter.
For example, press [4], [3], [5], [5], and [6] to
enter HELLO in T9 mode.
T9 predicts the word that you are typing, and it
may change with each key that you press.
2. Enter the whole word before editing or deleting
characters.
3. When the word displays correctly, go to step 4.
Otherwise, press [0] to display alternative word
choices for the keys that you have pressed.
For example, OF and ME use [6] and [3].
4. Press [ ] to insert a space and enter the next
word.
Other T9 mode operations
• Press [1] to enter periods or apostrophes
automatically.
• Press [ ] to change case. Lower case (No
indicator), Initial capital ( ), and Capital lock ( )
are available.
• Press [ ] to insert a space.
• Press the Navigation keys to move the cursor.
• Press [C] to delete characters one by one. Press
and hold [C] to clear the display.
Adding a new word to the T9 dictionary
This feature may not be available for some languages.
1. Enter the word that you want to add.
2. Press [0] to display alternative words for your key
presses. When there are no more alternative
words, Spell displays on the bottom line.
3. Press <Spell>.
4. Enter the word you want using ABC mode and
press <OK>.
"The faulty interface lies between the chair and the keyboard"
Apr 21, 2008 | Sony Ericsson w580i Cellular Phone
T9.
To activate T9, undertake the following steps:
Messages
New text Message
Press the first button from the right on the last row
Go in the option T9.
Choose 'On'
Nov 21, 2007 | LG Prada KE850 Cellular Phone
Motorola Mobility RAZR V3 Logo
211 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
