Question about Sharp R-340 Microwave Oven
Sharp undercounter unit
I can`t get the door open ,to repair.The push to open button is free with no resistance to it. Any suggestions
  • Sharp Master
  • 9,086 Answers
You probably have a broken "door open lever".
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
You can order Sharp parts there or from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
How can I replace/fix the button spring?
remove the outer case and look for the button spring inside / OR take it to a repair shop .
May 09, 2014 | In Cuisine MM800FS Microwave Oven
Sharp Carousel Microwave door won't open, button broke
Take it to a Discount Appliance or Used Appliance store and have them repair it. There they will have the parts that are used and cheaper to repair than hiring an Appliance Service Technician.
Option 2
Take the microwave apart and go to www.searpartsdirect.com and type in your model number and find the broken part and part number. Then order the part through ApplianceZone.com or ApliancePartsPro.com. Later when parts arrive at your door... install theparts yourself and save money!
Mar 27, 2014 | Sharp R-1480 Microwave Oven
How do I repair the door latch for a Sharp Carousel R-530ESF microwave oven? The push button won't open the door. I had to use a putty knife to push the latch up and open the door.
The service manuals are at our site here and here.
You can order parts from the Sears Parts Direct Web site image-4235112-10659157 or Encompass here.
Jul 07, 2011 | Microwave Ovens
The push button that opens the door on our Sharp Carousel R-1406F over the range microwave, is broken. We can push it in but it gets stuck. I cleaned it out because it was kind of dirty but it didn't...
It may be the door open button or the door button lever. Sometimes grease is the culprit, other times the surfaces where these two meet get worn, making the door harder to open.
You can find the full service manual free at our site here.
You can find Sharp part at the Sears Parts Direct Web site hereimage-4235112-10659157 or Encompass here.
You can find links to helpful exploded view diagrams and part ordering help for other brands here.
Jan 01, 2011 | Sharp R-1405 / R-140 Microwave Oven
I opened the door on my sharp microwave and now it wont latch. it sounded like something snapped off where the door latches to the microwave, not the door itself . Even if the door is held shut the light...
It may be the latch head spring or the door open lever or button.
DOOR SPRING LATCH HEAD HOOK
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
you have to separate the door panels (as shown in the attached photo) and then you'll see how it goes together.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
DOOR OPENING BUTTON LEVER
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find exploded views and part numbers for Sharp models by entering your model number at the Sears parts site.
If not, let me know. We have many Sharp manuals and if we have yours, we can link you to it at no charge.
The best place to order Sharp parts is
Encompass (formerly Tritronics).
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Oct 10, 2009 | Sharp R-1480 Microwave Oven
He's Dead, Jim! Died when door opened, but Usual Suspects clear?
May 13, 2009 | GE JE2160 Microwave Oven
Sharp Microwave model R-1850A door won't open
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
May 10, 2009 | Sharp R-930AK Convection/Microwave Oven
R-9H56 microwave convection motor class B
What usually breaks is the door open lever.
The outer cover will need to be removed to diagnose and repair this. Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
Aug 29, 2008 | Sharp R-510HW Microwave Oven
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Jan 14, 2008 | Sharp R-1850A Convection/Microwave Oven
Sharp R-340 Microwave Oven Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
