Question about Matsonic MS8177C Motherboard
No sound I don't have a sound card, I just want sound from the motherboard. The control panel says that the multimedia audio controler is disabled. Please help me get som sound from my machine. I have windows XP
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
All you have to do is get the drivers.
  1. First go to google and type you motherboard no. and the serial no. and put + sound drivers
  2. Click search
  3. Select one of the web sites and download from one of them.
Posted on Mar 26, 2008
  • Shabbir  Dole
    Shabbir Dole Mar 26, 2008
    Don't worry all the motherboards have a in built sound card... Only you have to get the drivers to unlock them.. Don't forget it has to be the correct one.
SOURCE:
Onboard audio automaticly disabeled by video card
It sounds if it may be that you need to turn off the HDMI audio in the nVidia Control Panel. This can be accessed from either the system tray or by right clicking on the desktop. From the control panel, select "change resolution" under the "Display" heading and in the right panel select your display and you should find a drop down box under for the connecter, which will allow you to select HD audio disabled, then you can exit and save changes.
Nov 06, 2013 | Gigabyte GA-G41M-Combo Motherboard
What should i do to get my sound device and controller?
Hi riteshscorpi,
Since you have a multimedia audio controller or Sound Card installed to your motherboard, reboot your PC and enter the CMOS/BIOS setup and disable the Onboard Audio.
Save your new settings.
The PC should immediately detect your Sound Card and ask for driver.
Install the Sound Card driver completely and reboot your PC.
Finally, configure the Audio properties to your desired adjustments.
Hope this helps you a lot.
Thank you for using FixYa!
Oct 30, 2011 | MSI 945GZM3-L (7267-020(945GZM3-L))...
Does not sound
1st you check is your sound card driver install properly. OR Check your is your sound mute from sound card driver.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Double Click on Sound, video and game controller.
  • There are list where you check is the sound card driver is available.
  • If it is not available then Install the driver.
Installation of Sound Card.
  • Select the Multimedia Controller or Audio Control the yellow Question Marks sign on it.
  • Right click on Multimedia Controller and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install
  • if the problem is still exist.
  • Replace the sound card or have a local tech take a look at the sound card.
  • ASUS Motherboard Drivers
Mar 20, 2010 | ASUS P5N-E SLI Motherboard
No audio driver set
Sound Card Drivers
Mar 18, 2010 | Intel Motherboard
Way the sound card no instalation for windows xp1
Your sound card driver is not installed.
Sound Card Drivers
I don't hear any sound from my pc cause but my multimedia audio controller works perfectly.perhabs my multimedia audia controller not support. Please, help me.
You should update your sound driver. Update of Sound Card Driver.
  • Click on Sound, Video and game controller
  • Right click on sound driver from the list.
  • Click on Update Driver.
  • Update Driver Wizard start.
Sound Card Drivers
Feb 15, 2010 | MSI 865GM3-LS (MS7043020) Motherboard
After installing driver,system still don`t see soundcar,i have sound but in control panel says no audio device
Does your computer have sound on the motherboard if it does you will have to go into the bios and disable the onboard sound before installing the add on sound card then windows will find it upon the next startup.
If this answer helps you leave feedback and rating please.
Jan 31, 2010 | RME Intelligent Audio Solutions Hammerfall...
I want to install te motherboard driver, i mean te sound card
1st Download Driver from this site Fujitsu Sound Driver
  • Driver will be install.
Mar 28, 2009 | Fujitsu S26361-F2560-L1 Sound Card
Sound problem
go to bios check the sound is enable or disable pls disable that then if u receive same problem then pls check the sound card name and install drivers of that sound card
Jul 31, 2008 | Intel D915GAG Socket 775 Motherboard -...
No sound from my P4VXAS motherboard
You may havee the onboard sound disabled in the BIOS. Check to see if the onboard is currently enabled, and if so, respond back.
Sep 19, 2006 | EliteGroup P4VXAS (P4VXAS-R) Motherboard
Matsonic MS8177C Motherboard Logo
146 people viewed this question
Top Matsonic Computers & Internet Experts
Ekse
Robert Karst
Robert Karst
 Gary Gemmell
Gary Gemmell
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
