Question about Refrigerators
Fridge makes loud moaning sound
Hotpoint side by side refrigerator (# HSM25GFRE SA) 4 yrs old makes loud moaning sound when running
  • carriems2 Jun 05, 2008
    I also have this "moaning"sound from my 2yr old refrigerator. It's terrible. It's not constant but it does it for hours and hours in a 24hr period. I have emptied everything out and checked for air circulation behind. Nothing has helped.
    Also, the automatic icemaker does not shut off by itself. Even when full it keeps making more ice which pushes up the shelf above so I keep having to turn it off manually.
  • armcurry Jul 10, 2008
    My Whirlpool Conquest is only 2 and a half years old and also makes a loud roaring sound occassionally. When I unplug it and then plug it back up, it stops. I vaccuumed all the dust out of the bottom of it and that seemed to help some, but not completely.
    Problem Solver:
  • 3 Answers
It is the control board. There is a recall on certain models and serial #'s that will cover the parts, but not all are covered. do a google search for hotpoint or GE howling noise. you will find out all the info you need.
Posted on Oct 17, 2009
Hsm25gfre sa
u need to replace the water inlet value
Apr 06, 2014 | Hotpoint Refrigerators
We have a HotPoint side by side that is approximately 4 years old and the fan surges and moans and groans any idea how we can fix this?
Hi,Yes, the fan will need to be replaced...the bearings are going bad in the motor...
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Aug 05, 2011 | Hotpoint Refrigerators
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
Fridge in storage for 4 yrs, now not cooling
Good day,
After that much time, be sure the fan motor in the freezer compartment is running, as well as the fan motor on the back bottom behind the cover by the compressor. Either could well have frozen up after 4 years of storage.
As well a refrigerant leak could have developed because of the time frame. However, if it is less then 5 years old, the sealed system would still be under factory warranty.
Apr 03, 2010 | Hotpoint HSS25GFP Side by Side...
My refrigerator/freezer making a howling sound and an intermittent whirring sound. I have noticed this at night, not sure if it is doing this during the day.
I have the same model, and the exact same problem. Additionally, the compressor/fan for the freezer cycles up and then down (rising and falling noise pitch) at a frequency of about every 5 seconds. The howling is worse at night(!?). It is 4 yrs old and was in the house we just bought. Help quickly, or this is a CraigsList item.
Thanks
Jan 12, 2010 | Hotpoint HSS25GFP Side by Side...
I have a Hotpoint, model # Hsm25gfre sa, that is cooling and freezing unevenly. Everything onthe bottom half of the freezer is frozen and the top half is thawing. Also, the water in the ice maker is not...
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
Aug 26, 2017 | Hotpoint HSM25GFRSA
Ge ice marker no 120v to seloniod water valve
It sounds like the plug-in for the solenoid valve is not making contact with the terminals on the solenoid . You can either buy a new connector or cut the plug for the solenoid and crimp 1/4 inch sta-cons (insulated type) to the wires.
Sep 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our fridge/freezer is making a moaning sound. we
if the timer is making clock sound is the timer may be you have a fan making noise
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
Condensor sounds like it moans for a couple of seconds instead
Hello aeruslady1,
Do you mean the compressor? I'm sure you do. The condenser is the hot refrigerant line that comes off of the compressor.
It just sounds like you have an old compressor. I have seen them make noises for years before they take a dump. If it continues to run loud even after it starts however, then you may need to clean the condenser coil or replace the condenser fan motor. Another thing that might make it run loud is some refrigerant lines may be rubbing against something. This can be remedied by bending the lines.
Hopefully this helps.
Sincerely,
shays5415
Dec 03, 2008 | Refrigerators
Refrigerators Logo
1,651 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
