No sound from front panel of GIGABYTE GA-MA69G-S3H
Case: A-Top Gladiator AT878BK-C
Motherboard: GIGABYTE GA-MA69G-S3H
As per the manual, in the Realtec HD Audio supports both rear and front panel audio ports simultaneously. However, I hear sound from rear panel only. I have connected the Case front panel connector to the MB front panel pins.
In fact the key connector matches with the MB pin layout.
There is no documentation for the Case.
I could not find any settings in the BIOS or the Realtec control panel.
Can you please advise what seems to be problem.
Thanks in advance.
-Aloke
  • AlokeKumar Mar 28, 2008
    Thanks for the advice and great help.
    Actually, the problem worked out by itself and I did not have to make any emails to either manufacturer. The connection was fine and the case connector was also fine.
    After I did fully connect the 5.1 speakers to the rear port. (I did not do that while I had the problem) and the gigabyte realtek audio control panel properly recognized them and after the speakers were playing audio properly, I reconnected the headphones to the front panel. Lo! Behold they were working just fine.
    Sorry I taking quite some time to post this response.
    For now, I am a happy camper wrt this issue.
    Thanks and take care.
    -Aloke
    President:
  • 2,351 Answers
Aloke,
It does mention in your manual (top of pg. 28 -notes), that in order to use the HD Front Panel Audio connector the pin configuration are different than the AC97 connections. Your current case is set up for AC97. You will have to contact Mfg. for the case click the link for Gladiator support:
http://www.a-top.com/jsp/info.jsp?number=3
You can try this, open up your control panel, look for an icon that's named Sound Effects Manager. Open it. Click speaker configuration.
This is part of Realtec's software. This is where you can setup & check both front & back ports (Audio & Mic).
If this part of Realtec did not install goto Gigabyte & down load your audio software & re-install it. (Just a suggestion).
http://www.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2554
Hope this helps. If you make the call it will be a fix.
Good luck.
Posted on Mar 14, 2008
I need the front panel connections location, which ones go where for the ga-73pvm-s2h motherboard
Gigabyte has the manual for the GA-73PVM-S2H on the product support site: http://www.gigabyte.com/products/product-page.aspx?pid=2691#manual . The full manual is near the bottom of the list. The direct link to the English version of the manual is http://download1.gigabyte.us/Files/Manual/motherboard_manual_ga-73pvm-s2h_e.pdf . The Motherboard Installation Guide at the top of the list is a generic manual for all motherboards.
The front panel connections are shown on page 28 of the manual. There are two lines of pins. From left to right, the inside line of pins are the Power LED +, Power LED -, Power Switch +, Power Switch -, then the Case Speaker +, Case Speaker -. (The speaker - is next to a Case Fan connector; so there are a couple of blank spots between the speaker + and - pins.) On the line of pins at the edge of the board, again from left to right: HD LED +, HD LED -, Reset Switch -, Reset Switch + . There is no contact on the last pin in this group.
I hope this helps.
Jun 06, 2016 | Gigabyte Computers & Internet
I just purchased a new blank case to start over with my system. The front USB connectors for the case are individual-pin and Only have 4 connectors per usb (which I'm not used to). My motherboard is a...
Looking at your MB with the processor on top. In the lower right hand corner are two connectors, F_USB1 and F_USB2. This should be what you are looking for. nblady.jpg
Hope this helps.
Jan 26, 2011 | Gigabyte GA-M68MT-D3 & Athlon II X4 630...
Download Gigabyte GA-945GZM-S2 sound Driver for Windows XP
Please click on the link below
http://www.gigabyte.com/support-downloads/download-center.aspx?kw=GA-945GZM-S2
and click on the driver as per your Rev Version (you can find it on the motherboard or the motherboard box.
You can choose the operating system - XP and download the driver.
Dec 12, 2010 | Gigabyte GA-945GZM-S2 Motherboard
I want all the pin details of motherboard diagram for GA- 8i845GV
Download the manual from Gigabyte;
http://download.gigabyte.eu/FileList/Manual/motherboard_manual_8i845gv_e.pdf
In order to view the manual you'll also need to download and install Adobe reader; http://www.adobe.com/products/reader/
With Adobe you can zoom in on any page. The manual is put together in such a way that you'll be able to connect everything. Most people have trouble connecting the, chassis front panel. Since wire colors vary from case to case you'll find each two pin jumper will share a specific wire color. Normally this common wire color is white and is used as negative.
(Except for the MB speaker). Common wire color for the speaker is, "red for positive and black for negative".
Take you're time and follow the manual.
Mike
Apr 28, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
GA-8S650GXM FOR USB FRONT AUDIO PANEL
You will need the motherboards manual to help you with connecting USB_1, USB_2 and F_PANEL audio to you're case. If you do not have you're manual for the GA-8S650GXM you can download it from Gigabyte; http://america.giga-byte.com/FileList/Manual/motherboard_manual_8s650gxm_series_e.pdf
You will also need Adobe reader installed to view the manual.
Gigabyte GA-8S650GXM main web site; http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1658
Turn to page 18. Number 17, F_USB1/F_USB2. Use the link provided below to help you connect you're front case USB wires to the motherboard; http://www.directron.com/installusb.html
Turn to page 24, for front audio connections. Keep in mind once you configure you're audio to function from you're cases front audio port you will not be able to use the rear audio port. Caution, most people find bumping any front case USB or audio cords break far too easely. To avoid breaking the front audio port, consider using a Y splitter for the rear audio port as shown in the next link; http://shopping.yahoo.com/p:StarTech.com%20MUY1MFF%20Audio%20Video%20Cable:1991733360;_ylt=Ah94ikZN9zDbTi2.arc45BkbFt0A
Hope you find this helpful.
Mike
Jan 22, 2010 | Gigabyte 8S651MP-RZ (GA-8S651MP-RZ)...
Schemat audio front panel conekt
Here is the link for the manual. It will show the jumpers and pins for sending to the back and front. USB, sound, etc.
http://english.gigabyte.ru/products/mb/manual/ga-ma69vm-s2_10.html
Good Luck
Dec 17, 2009 | Gigabyte GA-MA69VM-S2 (rev. 1.0)...
I need the front panel pin layout for a Gigabyte 8S648FX-RZ motherboard. (that is the power switch, reset switch, LED etc.)
Open the link for your Gigabyte MB 8S648FX-l;
http://america.giga-byte.com/FileList/Manual/motherboard_manual_8s648fx_rz(c)_c.pdf
This is your manual. Go to page 15. You can enlarge the image if needed.
You will need Adobe Reader to view the manual. If you need Adobe it is a free download;
To view the main link for the Gigabyte 8S648FX-RZ click below;
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1775
Case front panel wire colors can be confusing. Most cases use colored wires as their +positive. White is commonly used as the -ground wire. Except when connecting an internal speaker. Black colored wire is ground.
Cheers!
Mike
Oct 13, 2009 | Gigabyte GA-8S648FX-L Motherboard
How to connect usb cables inthe front panel to motherboard Gigabyte GA-6VM7A+
look in manual for the computer case ..will identify which cables are for which front panel source..then in manual (online or paper) you route to your motherboard for USB/sound etc.... good luck
Nov 10, 2008 | Intel Motherboard
Modem issues
If you are using wireless, make sure that the password is correct...
Then:
start>control panel>administrative tools>services
Make sure your DHCP client and wireless zero client are started and set to startup type automatic.
If not wireless.Unplug your router and modem for a few minutes.Then restart your computer, and plug the router and modem back in...
Jan 11, 2008 | Intel Motherboard
Computers & Internet Logo
3,067 people viewed this question
Alun Cox
David Payne
David Payne
