KENWOOD LVD-K9100 CD, CDV, LD, LASER KARAOKE PLAYER Original owner, in superb cosmetic condition, this unit was just professionally cleaned and serviced, all parts function correctly, except the laser is weak and will not read Karaoke LD’s. Do I need a new Laser, and if so where do i get it?
  • 2 more comments
  • R_Schemenaur Mar 14, 2008
    When inserting a LD, the player ramps up and the Track number display shows”00”. When play is selected, nothing happens. When disk side “B” is selected the track display goes blank. Again nothing happens when play is selected. I have used several LD’s with the same results. The AV service Tech that just cleaned the unit said the laser is too weak to read the LD’s.
    When inserting a LD, the player ramps up and the Track number display shows?00?. When play is selected, nothing happens. When disk side ?B? is selected the track display goes blank. Again nothing happens when play is selected. I have used several LD?s with the same results. The AV service Tech that just cleaned the unit said the laser is too weak to read the LD?s.
    When I press the play button, nothing happens, how would I get the unit to read the CD cleaner kits?
    Also I have searched for other Kenwood CD,CDV,LD players and found none. Did Kenwood make this product or is it a Pioneer? The unit has made in 1993.
    My AV tech, said the lens are clean, he also told me that because I?m a smoker, that he feels that smoke has gotten into the laser assembly. The only correction would be to replace the laser. He said he would charge me to open up the case and try to find a part number, he also thinks the laser might be from pioneer.
  • 549 Answers
If the laser diode inside the optical pickup is dead or weak it will do exactly as you have described. It is a very common problem with cd and dvd players.
Things You’ll Need:
  • Lukwarm water
  • Soft, clean cloth
  • Karaoke machine cover
Maintain Your Karaoke Machine With Regular Cleaning Step 1:
Clean the exterior of your karaoke machine regularly. Use a soft clean cloth to wipe down the karaoke machine housing. You can use warm water to help clean the unit, but it should be applied to the cloth, not the machine casing.
Step 2:
Avoid using cleaning solvents to maintain the karaoke machine. These can tarnish the surface of the machine. Solvents can also affect how the machine functions if they get inside the housing or into the buttons.
Step 3:
Clean the CD laser lens occasionally. Use a CD lens cleaning disc for the best results. Place the disc into the karaoke machine and run it according to the enclosed instructions.
Step 4:
Try cleaning the CD laser lens manually. Open the CD player and locate the CD laser lens. Wipe it off gently with a clean cotton cloth. Do not use any solvents.
Properly Store Your Karaoke Machine Step 1:
Turn off the power to your karaoke machine after each use. This will help the machine from overheating.
Step 2:
Store your karaoke machine in a cool, dry place. Moist conditions can cause the machine's cabinet to warp and could cause rust on interior electrical components.
Step 3:
Keep your karaoke machine away from direct sunlight. Direct sunlight can warp plastic buttons and screens on your karaoke player.
Step 4:
Consider covering your karaoke machine while not in use. This will help prevent dust from accumulating inside the buttons.
Handle Your Karaoke CDs With Care Step 1:
Store your karaoke CDs in their original cases to reduce the risk of dirt accumulation. Dirty CDs can cause tracking problems when put in your karaoke player.
Step 2:
Keep your karaoke CDs away from direct sunlight. Even while in their cases, CDs can easily warp when exposed to direct sunlight. Warped CDs may get stuck inside the karaoke machine.
Step 3:
Pick up karaoke CDs only by the very edges of the disc. This will help keep the discs free of dirt and fingerprints.
Here are some generic things to try.
Posted on Mar 14, 2008
  • Hjalmer Lamminen
    Hjalmer Lamminen Mar 16, 2008
    Considering the age of the player, it may not pay to fix it.
    If the unit needs the laser, you may not even be able to get it.
  • 4,889 Answers
Your problem is pretty straight forward..The lens is damaged or needs to be cleaned.. You can get a lens cleaner CD with liquid(costs about 5-10$) insert it in you player and press play. THen take it out put the liquid on the brushes and clean it once again.. Then check if it works.. If it doesn't work then you will have to replace the laser( Lens mechanism).. Let me know if it worked so that we can proceed further
  • eagle338
    eagle338 Mar 14, 2008
    People who dont want to follow are not fit for posting on this site.. GO HOME AND SLEEP!
  • 2,326 Answers
If you can open the KENWOOD LVD-K9100 CD, CDV, LD, LASER KARAOKE PLAYER unit and check on the laser assembly part number.
If you find any numbers there you can check this site to see if they can help you.
This site as well.
    Master:
  • 788 Answers
Probably your best bet is eBay, you may be able to find a LVD-K9100 or K9200 that is not working but has a good laser.
Have you tried cleaning the lens with compressed air?
You could ask on alt.video.laserdisc on Google groups, you may get better results as they would be Laserdisc enthusiasts and may be able to help better.
It was seem that the Internet has forgotten about the LVD-K9100, the K9200 seems a little more popular, and they maybe use the same laser/lens???
  • Dean Joly
    Dean Joly Mar 14, 2008
    Here is a link to where you can purchase the service manual for the LVD-K9200: http://www.user-manuals.com/advanced_sea...
    Unfortunately there are no resources for the LVD-K9100 on the Internet.
    You may be interested in the DVDTalk.com forums
  • Dean Joly
    Dean Joly Mar 15, 2008
    That makes sense, it would be easier to look at the laser for a part number as there is nothing on the Net. Unfortunately you don't have many other options. And it isn't a guarantee to find a replacement even once you have the part number.
  • 689 Answers
Perform disk cleaning process. You can obtain disk clean up kit in most IT stores . Choose the one with liquid. inform the outcome after cleaning. So I can post possible next step solution.
Good Luck
  • 818 Answers
You can prove with a cd that can clean the laser of your cd. if not work with him. you must change the laser
Sergio
    President:
  • 1,944 Answers
It can't read one disc or all discs?
    Master:
  • 377 Answers
Try to send it a service man, and see if it really the lens..
  • pincer
    pincer Mar 14, 2008
    it can only be the rubber belt is the problem.
DVD hook up
Yes- LD means Laser Disc.
Jul 22, 2013 | Kenwood Audio Players & Recorders
CLD3380 LD player can't read CD properly
Try a CD cleaning kit and follow instructions, if no change, the laser pickup is near the end of life, far cheaper to replace the player.
May 14, 2012 | Televison & Video
I have a Pioneer LCV-300 Laser Karaoke player; but without the "receiver" or "commander" unit. Is this unit necessary for the disc changer portion to operate or power on?
I may have a CD-V300 commander Auto changer if you can supply me with an owners manual for a LC-V300 laser changer. I also have an auto changer CD-V2000 if you can use it. If you can please contact me. Thanks.
roga@rochester.rr.com
Dec 29, 2010 | Pioneer Audio Players & Recorders
My receiver is reading NO DISC it is a vocopro karaoke player/receiver model # DKP-10G
First, the player does not support DVDs or MP3 discs.
Try two things:
#1:
Unplug from outlet and Turn ON player (while unplugged).
Plug back in and try to use the CD.
#2:
Obtain a CD laser lens cleaner from Radio Shack ($13). It is an audio CD with a row of brushes and does not use chemicals
Oct 16, 2009 | Vocopro DKP-10G
How to remove radio faceplate on 2003 Toyota Camry?
U don't have to remove anything, just get a laser lens cleaning disk from any store that carries music CD's Walmart has them for about $6
Mar 22, 2009 | 2003 Toyota Camry
Professional new karaoke system skipping and lyric problems
your disc is scrath or maybe the lens of your player is already weak,or have dust,if you can do the job,clean it with a soft cotton..wipe carefully with only one direction..try also the lens cleaner.
Feb 23, 2008 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Toc code keeps comeing up on my kenwood kdc x5589
Hi, toc error means that the laser is struggling to read the Table of Contents which tells the unit where all the information is on the disc, it may be something as simple as the lens needs cleaning or something as complicated as the laser needs replacing, but you could try running a cd disc cleaner through it first. Good luck......
Jan 24, 2008 | Kenwood eXcelon KDC-X559 CD Player
Kenwood Car Audio system model no. KDC-X8529
Mnay things can stop a CD player from reading.... Try cleaning the LASER LENS in the unit(you may have to remove it from the car) with a cotton wool bud soaked in Windex glass cleaner. Then use a second (fresh, dry, and clean) cotton bud to remove any residue film(left from your cleaning procedure). If this does not work, then the unit may need some detailed diagnostic work done to determine what is wrong, or if a laser replacement is needed. REMEMBER Repairs are worthwhile, only if yo have a good tech!!
Dec 27, 2007 | Kenwood eXcelon KDC-X759 CD Player
TOC Error
I had the same problem with my KDC-M7024 CD player. All I done was put a cleaning disc into the player and let it play for 2-3minutes. The disc has a small cleaning brush on it which spins around like a normal CD would and as the bristles pass over the laser it removes any dust.After that it worked fine but i still have to run the disc through every 3-4 months or the problem persists.
Dec 07, 2006 | Kenwood KDC-M7024 CD Player
629 people viewed this question
 Grubhead
Grubhead
