Question about GE WDSR2080D Top Load Washer
Water will not turn off
Sounds like the water level switch is broken. Where is it and how do I replace it?
  • 1 more comment
  • mket Mar 18, 2008
    Thank you very much. Had trouble with the screws, had to get a special tool. The tube seams fine. It connects to the tub and does not appear to have holes or cracks. I blew into it. Running a test load right now and the water stopped running and started to agitate as expected. Could a bad switch cause inconsistent behavior, where it will work a few times and then not?
  • mket Mar 18, 2008
    Second test run, water stopped and is working fine. The little box on the tub where the tube attaches to has water in it. Is that normal?
  • tara12 Mar 31, 2008
    i have the same washer and is doing the same thing it has overflowed 5 times we had to call someone in to clean the water out this last time. so what do i do. some times water wont even pour in or wont spin or not do anything. need help fast
    President:
  • GE Master
  • 2,651 Answers
Washer will not turn off at any load size and overfills out the top of machine??? or water continues to fill into machine even after unit is done operating?
the first of the issues sounds like a water level issue, it located behind the console which is access by 3 screws across top of panel. before replacing switch check the clear plastic tubing going to it for any cracks or holes, and make sure its attached to the rear of tub properly. air pressure goes up that tube tripping off switch so check it first.
If the problem is the other scenario then you have a bad water inlet valve, in which case theres no servicing the part just replace it with a new inlet valve
Posted on Mar 15, 2008
  • Ron Coons
    Ron Coons Mar 19, 2008
    yea toally normal, it fills the tube w/air pressure to trip switch so a little water inthere is normal its creating the pressure. its possible that residual soap and debris caould intermittenly screw with the switches accuracy
4 Suggested Answers
wagdom
  • 64 Answers
SOURCE: Unable to control water level
Some water may have got into the pressure switch. Remove the pressure switch and see if you can shake any water out. Make sure the cables go back on the correct terminals. make sure the tub is empty when you refit the pressure switch, so no water is allowed to enter the pressure tube
Posted on Oct 29, 2007
beltronic205
  • 1474 Answers
SOURCE: replace the water level switch
The water level swith is normally near top of machine ..It has a HOSE connected to it and wiring...
Posted on Sep 27, 2009
tbirdfan1
  • 3051 Answers
SOURCE: water level switch won't turn
HELLO THERE AND WELCOME TO FIXYA:
tHERE ARE A FEW THINGS THAT YOU WILL WANT TO FIRST ENSURE
FIRST ENSURE THAT THE WATER IS ACTUALLY TURNING OFF AT THE INLET VALVES ON THE MACHINE IF THESE VALVES LEAK THE WATER WILL CONTINUE TO ENTER THE MACHINE AFTER IT IS FILING THIS IS THE MOST COMMON PROBLEM ON THESE
HOWEVER IF YOU HAVE ALREADY PINPOINTED THE WATER LEVEL SWITCH AS BEING FAULTY THEN YOU CAN REPLACE IT HERE IS WHAT IT LOOKS LIKE IN THE IMAGE BELOW BE ADVISED THAT THEPART MAY BE A LITTLE BIT DIFFERENT THAN THE ACTUAL ONE ON YOUR UNIT SO I WILL POST A FEW OF THEM
TO REMOVE THE PART YOU WILL NEED TO REMOVE THE COVER ON THE CONTROLE PANEL AND IT SHOULD EXPOSE THE TUBE THAT GOES FROM THE CONTROLE PANEL TO THE TUB WHERE THE PART IS
12_15_2011_3_26_45_am.jpg12_15_2011_3_27_09_am.jpg12_15_2011_3_27_20_am.jpg12_15_2011_3_27_32_am.jpg12_15_2011_3_27_44_am.jpg12_15_2011_3_27_56_am.jpg
Posted on Dec 15, 2011
Water level knob won't turn
Karen, can I get the model number of your washer? If this is a top loading model with the water level switch on the left side of the console, there is probably a plastic piece inside the switch that has broken and it will need to be replaced.
Dec 22, 2014 | Washing Machines
Basket does not stop far enoght back water spills over top when filling
see the causes and fix it. use the common sense. God bless you
If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Sep 22, 2012 | Washing Machines
Water fill is not accurate sounds like water level switch. Would this also cause the rinse cycle to not fill?
Yes, the water level switch is likely faulty and not calling for water when it needs to. Replace the water level switch and blow backwards through the hose to be sure it is clear.
Kelly
Mar 24, 2011 | GE WJSR1070A Top Load Washer
Water level does not turn off. pressure switch
Feb 15, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Flood!
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It need replacing.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tube. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Sep 07, 2009 | Washing Machines
Washer didnt fill when turned on, but filled when holding "reset"
sounds like your water level switch is bad OR the small hose that goes from the waterlevel switch to the bottom of the tank has a hole in it.Try replacing this small hose first.you can go to an auto parts store and match it up.it's usually about 3' long and about 1/4" inside diameter and about 99cents a foot.
Aug 26, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
My Kenmore 70 is also overfilling...
Sounds like it could be a faulty water level switch. A defect or an obstruction can mean that it can't tell the water to shut off. This switch raises the water level in the clothes tub. It's usually a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises, the pressure increases on the air in the plastic tube. When the pressure reaches a certain level, it activates the switch and turns off the water. It also signals the washer to begin the wash cycle. Clean out any obstruction in the plastic tube or replace the water level switch. Hope this helped.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
Kenmore dishwasher is not washing properly and leaving dirty water in the bottom when it is finished, Can i fix it?
Water-inlet valve
Water-level switch
Jun 02, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
No water gets in to the machine
ou should turn the dial to spin with lid closed for a full minuite, or blow on the tube at the water level switch. If problem persist replace water valve, if machine is agitating w/o water replace water level switch.
Mar 12, 2009 | Washing Machines
Water will not shut off
it sounds like you have a water level switch failure..
also check your water level switch pressure hose that connects to water level, alot of times it is pinched of off the water level switch or tub..
Dec 10, 2007 | Roper RAX7244KQ Top Load Washer
GE WDSR2080D Top Load Washer Logo
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
