My first problem arose yesterday when, while syncing my E2 with my Desktop MAC OSX 10.4.11, the sync operation failed and the hand held Tungsten E2 could not be opened turned of and none of the prorams on the E2 could be accessed. My stored information is accessable through my MAC desktop; BUT MY E2 would not respond to attempts to turn it off,either when plugged in or not, and the screen stayed lit up for 18 hours. This morning the handheld E2 does not respond when plugged in to power or not.
    Master:
  • 377 Answers
There have been many versions of the Palm OS over time, and sometimes older applications have problems running on newer versions of the OS (operating system). The above issues are all symptoms of incompatible third-party applications.
You can always start off by checking with the software developer for an updated version of its software. Otherwise, PalmOne recommends you start by trying a soft reset. To perform a soft reset, insert an unfolded paper clip or similar-sized instrument (unscrewing the top of your stylus may reveal a reset pin on some models) into the reset hole normally located on the back of the unit (see the instruction manual for more details). This reset will not erase any data on the device.
If you’re using third-party hacks or extensions that could be causing problems, perform a system reset. Again, this will not delete any data, but it will disable any third-party hacks that are running in the background. To perform a system reset, press the Up button on the front of your PDA while performing a soft reset. Disable any third-party hacks or extensions you’re currently using.
If neither solution works, you’ll need to delete the offending the application. If it’s obvious which application is causing a problem, you can delete it by tapping the Menu icon in the Graffiti writing or while in the application launcher. Scroll through the list of installed files until you find the offending application. Tap the application and tap Delete.
If you’re not sure what file or application is causing the problem, you’ll need to perform a hard reset. Before you do this, be sure to perform a HotSync so your data is properly backed up (the hard reset will erase all data on the PDA). To perform a hard reset, press the power button while performing a soft reset. Replace the power button when you see the Palm/PalmOne logo and press the Up button when prompted.
Next, find your Backup folder on the desktop. You’ll usually find this folder located within your user folder, which is usually located in either C:\Program Files\Palm, C:\Program Files\palmOne, or C:\Program Files\Handspring. Your personal folder will resemble the user name you selected for your device. If you used your first and last name, for instance, your user folder will likely be the first six letters of your first name followed by the first letter of your last name. Rename the Backup file to Backup.old and HotSync your Palm to restore personal data. Because you renamed your Backup folder, no applications or additional files will be restored at this point. Instead, an empty new Backup folder will appear. Move applications from your Backup.old folder into the new Backup folder one at a time and HotSync your Palm. After each HotSync, try to reproduce the problem. If the problem doesn’t reappear, move on to the next file. Delete any files that cause a problem after they are moved onto your PDA.
Posted on Mar 14, 2008
  • 818 Answers
    President:
  • 1,950 Answers
Did you try taking out the batteries out for a few hours to reset the unit?
  • 689 Answers
Hi
you may perform soft reset, if issue persist perform full reset. please do not forget to backup your important data. let me know when you need further assistance so I will post the solution depend on the result.
  • ExpressFiX
    ExpressFiX Mar 14, 2008
    HARD RESET PROCEDURE
    1 Press and hold the power button.
    2 While holding the power button, use the tip of the stylus (or a similar object
    without a sharp tip) to gently press and release the reset button inside the hole
    on the back of your handheld.
    3 Wait for the Palm Powered™ logo to appear, and then release the power button.
    4 When you see the message that warns you about erasing all of the info on your
    handheld, do one of the following:
    • Press Up on the 5-way navigator to finish the reset and show the touchscreen.
    • Press any other button to do a soft reset.
  • ExpressFiX
    Please inform the outcome and rate accordingly for our quality assurance purposes.
    Good Luck
SOURCE:
I want to transfer the information from palm desktop on a PC to Mac OSX. The palm tungsten e2 is water damaged and not working.
Inside the PalmOne forlder in Program Files, find a folder that is named the same as you Hotsync ID. A flash drive would be the best idea to transfer the files over to the Mac. Some flash drives don't work on Macs, so try a few.
Jan 18, 2010 | Palm Tungsten E2 Handheld
HotSync problem:connection could not be
After you change the battery you need to do a hard reset. This will erase all the info in your pda so you want to make sure you have it all backed up on the palm desktop To do a hard reset follow these steps:
1. Hold down the power button.
2 While holding down the power button, use the tip of the stylus and inset it into the hole in the back of your pda and gently press and release the reset button in the back of your pda.
3. When you see the message that warns you about erasing all of the info on your hand held select continue.
4. When prompted follow the online directions to align the screen. After that you will want to do another hot sync. Best wishes.
Aug 10, 2009 | Palm Tungsten E2 Handheld
Is there any way to sync a palm tungsten e2 with vista 64
Yes its possible by using bluetooth as currently Palm desktop doesn't support USB sync for Vista 64 Bit You can obtain solution and the software from link below
http://kb.palm.com/wps/portal/kb/common/article/32859_en.html
Jul 16, 2009 | Palm Tungsten E2 Handheld
I want to sync my Tungsten E2 to my new Comp. windows vista
Download the Newest version of Desktop Manager/ Sync software from :
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=1568,E=0000000000263321976,K=3877,Sxi=4,case=obj(32859)
Install it and then sync your Palm.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 30, 2009 | Palm Tungsten E2 Handheld
Need to download software to sync my PalmOne Tungsten E2 to my PC
Here is the link for the Palm Desktop manager and Hotsync software for Windows. There is a link on the page for Mac if needed.
Palm Desktop 6.2
  • Palm Centro; Treo 755p , 700p, 680, 650; Palm TX, Z22; Tungsten E2
  • Windows Vista, Windows XP, Windows Media Center Edition 2005
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(32859)
Thanks, Joe
Jan 11, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Can I sync an Ipod touch with my Palm Desktop for windows?
I don't believe that the Palm desktop manager is compatible with Ipod. Unless you have your contacts associated with Microsoft Outlook, that should work.
Dec 27, 2008 | Palm Tungsten E2 Handheld
Need Hot Sync module on backup PC
Plug your E2 into your pc and when it says new hardware found, install the cd. Do not continue till you have verified sync connection between pc and pda
Dec 11, 2008 | Palm Tungsten E2 Handheld
Tungston E2
1. Upper left corner press time
2. Select delete
3. Pick program you loaded
4. press delete
Oct 07, 2008 | Palm Tungsten E2 Handheld
Appropriate software for tungsten e2 palmOne
If you said you have the software (desktop), your doing it backwards. Run the desktop software by going to my pc and running the disc. The software will then ask you to plug in your E2 so it can register it. It will then synch and your in business. Had E2 for a very long time. Can tell you things that guy can do that would surprize you. Have everything but unit now.
Mar 15, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Palm Tungsten E2
TRYING PUSHING A PIN INTO THE LITTLE HOLE IN THE BACK THIS WILL DO A HARD RESET IT MIGHT HELP YOU. GOOD LUCK
Jan 29, 2008 | Palm Tungsten E2 Handheld
Open Questions:
Amazon Prime refund#{1*845481*1722} Phone Number dmvjbka Amazon Prime is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Amazon Prime email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Amazon Prime support number When you are using the Amazon Prime for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Amazon Prime support number and ask for the help. Once you dial the Amazon Prime customer support number, you come in contact with a team of experts at the Amazon Prime customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Amazon Prime support phone number will help you with that simply and quickly. This is Amazon Prime's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon Prime agent. Features of Amazon Prime support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Amazon Prime customer support phone number. Here are some of the features of customer service: The Amazon Prime customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Amazon Prime customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Amazon Prime provides you the facility of Amazon Prime support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Amazon Prime. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Amazon Prime Customer support number team.
Oct 18, 2019 | HIS Computers & Internet
NORTON Tech sUPPort pHoNe ,,,18OO'8'O'3'1O69,,,, numbeR ktm.vc Usa NORTON USA phone number is ranked #2 out of 2 because 7,728 NORTON USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he NORTON USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, NORTON USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. NORTON USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact NORTON USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling NORTON USA Calling NORTON USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from NORTON USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with NORTON USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare NORTON USA's phone numbers against each other. Contacting NORTON USA in General While I8OO8O31O69 is NORTON USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach NORTON USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact NORTON USA.
Oct 18, 2019 | Norton Computers & Internet
Computers & Internet Logo
101 people viewed this question
Ekse
Alun Cox
