Question about Toshiba Satellite A105-S4004 Notebook
Faulty lcd - how to replace
I have a faulty lcd and need to replace. Is there anyplace to find detailed replacement procedures?
  • 55 Answers
What kind of laptop do you have?
Posted on Mar 14, 2008
SHARP TV MODEL LC-46LE830U WILL NOT TURN ON. I HAVE REPLACED THE POWER SUPPLY BOARD WITH NO HELP. IT HAS 2 BLINKING LED LIGHTS FOLLOWED BY 5 BLINKING AND REPEATING AGAIN. WHAT IS MY NEXT STEP?
It sounds that the main board fitted with your Sharp television is of Philips. Those blinks are fault indications, and you should follow the procedure of counting the number of blinks, as you do with Philips brand LCD TVs.
From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
May 11, 2017 | Sharp Televison & Video
I replace the lamp and now the tv powers on and after a few min turns it self off and power button blinks red
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Mar 30, 2016 | Sony Grand WEGA KFE50A10 50" SDTV LCD...
Philips 40inch LCD 40PFL7705DV/F7 When connected to power, it tries to crank for 15 sec and turn off by itself. This repeats. Back light is on while it tries to turn on.
Blinking codes details of many popular brand TVs are given. Surf the site with patience.If blinks continue without any pause, the main board is faulty.
  • Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Feb 29, 2016 | Philips Televison & Video
My TV was damaged due to lighting. The standby light is flashing red and the screen won't come on. What parts must I replace to fix it again? I replaced the power supply board but that didn't help
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Jul 14, 2015 | LG 47 47LK530 LCD TV
I have a LC-37GB5u, the unit comes on for one second then off then the OPC red LED flashes two times per second. I have replaced the 82uf caps and all four MosFETs. with no change.
Dec 03, 2014 | Sharp AQUOS LC-37GB5U 37" HDTV LCD TV
50PF9630A/37 Phillips 52" plasma clicks on, 20 seconds later blinking red light syndrome. No pattern, just on/off. Replaced power supply board. Same thing. What other boards should i replace? Than
Nov 12, 2014 | Televison & Video
PHILIPS 52" HDTV BLINKING BLUE POWER LIGHT
Oct 14, 2014 | Philips 52 In. LCD HDTV
The lcd of my compaq 610 laptop cannot display
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) Ide/Sata make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust
hope this helps
Aug 19, 2011 | Computers & Internet
Nothing on the screen of my Gateway NX570S model MA7. Backlight works but no display. Works fine with monitor plugged in. Replaced motherboard, screen, inverter, lcd power cable. What else could it...
hope this helps
Aug 08, 2011 | Computers & Internet
Looking for a lcd screen replacement procedure for Toshiba Satellite L305-S5957.
If the screen is not physically broken then the fault is most likely a back-light problem. A back-light problem is usually caused by a faulty inverter or a faulty CCFL lamp. These components are a lot cheaper to replace than the whole LCD screen.
For service, parts and DIY info. check out LCD parts' WEB site - click on this link to their site :-
www.lcdparts.net
Jan 15, 2010 | Toshiba L305-S5957 (PSLB8U-14F025) PC...
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
