Question about Casio Exilim EX-Z750 Digital Camera
Cracked display can display be replace ? i fell on it :-(
I did the same, I got a replacement as-is camera on ebay with a functioning display (its lens was out).  It was fiddly, but you need to go in from the display side of the camera (ignore the lens) and you likely just need outside half of the display - take note of a couple of places where the connection ribbons attach as you detach - in each case there is a black plastic bar that rotates to unlock and lock the ribbon.  You can get away with just swapping the outside half of the display (leaving the 'white' back half inplace) and so avoid any soldering - just the ribbon insertions.  I.e. the part I swapped was the outside half of the display (you need to lift some black edge tapes to do this) with the ribbon that comes out of the bottom edge.  You need to unscrew the metal panel the display sits in so you can deal with the ribbon.  I've never done anything like this before, I used the as-is camera to figure out what went where and played around until knew what i had to do.  On reattaching, if the screen is white it means the bottom edge ribbon is no attached right - remember to use the black 'locker bar' on reattaching to unlock for insertion and then lock again and take care on reassembling not to pull it out.  The outside frame also has a ribbon to attach in a similar way but it is easier to connect.
Posted on Mar 22, 2008
  • 477 Answers
Yes you have to disasimble the camera and remove the lens first. but it is fairly easy.
Posted on Mar 17, 2008
SOURCE:
My screen has a crack the phone fell , no display on screen
obviously you have to get it fixed or replace it it
Jul 19, 2018 | Cell Phones
My TV fell and the screen is cracked. The light comes on but no pictures
SORRY, if the panel (it is called a display panel) is damaged this is the end of this set- fatal from a cost point of view as the part if available will cost more than the set did when brand new.
The display panel in all these sets is fragile as you have discovered--even a minor hit can destroy the panel.
SD TECH
Apr 29, 2012 | Televison & Video
I have a LG Chocolate BL 40. It fell down and cracked its display screen from several loactions. So I got a the cracked display screen replaced with a new one. All seems to be working fine except that when...
I guess that is not causing due to the replaced touch screen. But make sure all the areas can be touched and responsive for touches.
If all of the above is OK, this could be a hardware problem since you have mentioned that you did a hard reset too..
Jun 18, 2017 | LG Chocolate 3 Cell Phone
Lg chocolate touch screen not working
I have a LG Chocolate BL 40. It fell down and cracked its display screen from several loactions. So I got a the cracked display screen replaced with a new one. All seems to be working fine except that when the call comes the answer button which used to display as green gets greyed out and does not lets you answer the call. I have tried upgrading the software as well as a factory reset bit it has not helped. C
Can somebody advise how/if it can be fixed?
Aug 28, 2010 | LG Chocolate 3 Cell Phone
Broken how can i fix it?
you will need to get a replacement screen for you to fix the problem. Once you get the replacement screen, remove the cracked one and replace it.
Take care.
Jul 21, 2010 | Garmin n?vi 265WT Car GPS Receiver
Screen is cracked
http://www.ownta.com/original-htc-g1-cell-phone-reparing-lcd-display-screen-replacement.html
This is what you need, just fix it by yourself, if you know how to repair.
May 27, 2010 | HTC G1
LCD television
The inside of the display panel is broken.
The cost of the replacement display would probably exceed the cost of a new set!
Jerry G.
Nov 08, 2008 | Vizio L32 32 in. LCD HDTV
Cracked camrea Samsung S1030
I don't know the replacement cost, but I can bet it is nearly the cost of your camera. You might be better to find one on ebay that has a good LCD and transplant it. It may be a little difficult, but not impossible.
May 03, 2008 | Samsung S1030 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
43 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
