Question about Husqvarna Viking 1
Bobbin Winder won't release
My Viking Rose has a bobbin winder that wont release the bobbin. How can I get it to release?
  • 1 more comment
  • Anonymous Mar 22, 2014
    I filled the bobbin on my Bernette E66. When I finished the bobbin would not come off. It is stuck fast and I don't want to force it. What is the problem?
  • Anonymous Mar 28, 2014
    How do I replace the bobbin winder on my 807 bernina
  • Anonymous Mar 31, 2014
    how do you turn the bobbin winder off a Bernina 1090?
I have a husqvarna rose, i has the same problem when i started using my machine. i was suggested to not wind the bobbin so fast. the reason it gets stuck is because the thread is so tight on the bobbin it actually makes the bobbin a tiny bit smaller, making it hard to get off again. if you dont wind it so fast, it doesn't get so tight.
kylee
Posted on Mar 25, 2008
Husqvarna viking 300 sewing machine bobbin winder will not stop spinning. machine will not sew when foot pedal depressed. bobbin winder just keeps spinning.
The bobbin winder moves a plate next to the handwheel that disengages the needle from moving If you can't push it back to the left you will have to take the machine apart to fix it.
Jun 10, 2017 | Husqvarna Sewing Machines
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Bobbin filled -won't shut off
The bobbin sits on a bobbin holder for winding. To initiate winding, the winder leaver should be pushed toward the bobbin on the holder.
If the bobbin is over-winding, the winder leaver needs to be rotated so that the section pointing towards the bobbin is closer. This can be done by gently rotating the winding leaver by hand, remember gently. It will not need much rotation, so do not overturn ... most of all be gentle. If it does not budge, the screw in the middle of the winder lever may be loosened and the winder leaver rotated. Make sure to tighten the screw when finished.
This should get the bobbin comfortably full. If the bobbin still continues to over-wind then the sensor underneath may need attention by you local technician. Do not attempt to open your Viking 1 as it may cause extensive damage and.will also null all warranties
Let me know how you go. Cheers.
Aug 24, 2014 | Husqvarna Viking 1
How to fix viking designer 1 broken bobbin winder
If you mean the bobbin winder mechanism where the bobbin slips on to the spindle is loose, the pin that holds it in place has come out. It's an easy fix but requires that all the covers be removed. Suggest taking it to an authorized Viking dealer for repair. You can find your local dealer by going to the Viking website - http://www.husqvarnaviking.com/us and click on Locate a Dealer.
Jun 09, 2014 | Husqvarna Viking 1
Hand wheel won't disengage so that bobbin can be wound
The bobbin winder may need a new bobbin tire. Does the bobbin winder move over like normal?
Nov 13, 2013 | Husqvarna Rose
My bobbin won't catch on the bobbin winder, the metal post spins but the plastic singer style bobbin won't spin with it. What's wrong?
The bobbin may be stripped, or the bobbin winder might be stripped; try it with a different bobbin, to rule out the bobbin being the issue; if that doesn't work, look closely at the bobbin winder to see if it has been damaged. You may be able to adjust it's shape with a pliers
Apr 02, 2012 | Singer 3116 Simple
I have a Viking Husqvarna and it seems that the bobbin winder won't disengage. when you press the pedal down the needle doesn't move but you can hear the bobbin spinning but when you put a bobbin on the...
If the winder is not moving either there is a worn part on the winder rubber, or, the winder iteself may have seized up becuae a lot of people do not realise that the spindle has to be oiled because of its high speed.
Nov 05, 2009 | Husqvarna Viking 1
Viking sewing machine 545 bobbin stuck on rewind
It should just pull off of the winder shaft. There is a small spring that sticks out from the shaft to hold the bobbin in place (at least on my wife's Viking which is a different model number than yours). Is there a release button somewhere near?
Jul 17, 2009 | Singer CE-100 Futura Computerized Sewing...
I have a designer 1 that won't release the bobbin.
Winding too tight;
Whenever your bobbin won’t come off any Viking, Designer 1 included, it’s because it wound too tight. This is how you know. It went on easy! To get it off, don’t pry, slowly unwind all thread, it will change shapes and let go of the bobbin winder. My favorite way to wind a bobbin on a Viking is to thread the machine through the needle and go under the foot then up to the bobbin winder (it has to be under the foot or it winds too tight. If it still winds too tight, lay your thread down instead of standing it up, the weight of the thread can increase tension on the winding process also check that you use a spool cap as large as or slightly larger than your spool. If it still winds tight. I’ll explain what bad thread can do.
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test (tip: always check your thread this way when you thread your machine)
Mar 12, 2009 | Husqvarna Designer I
My Viking Rose bobbin winder wont release my bobbin. This is the second time this has happened with the same bobbin, and I got it off the first time by gently manipulating the bobbin. It was full of thread so I decided to use it and then dispose of the empty bobbin. Well, you can imagine what happened! When it was empty, I, of course, forgot and put it right back on the winder. What do I do?
Feb 29, 2008 | Husqvarna Viking 1
Sewing Machines Logo
633 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
