Question about Neff 24 in. S5443X2 Built-in Dishwasher
Leak of water in base of unit
HI, My dishwasher got stuck on the drain cycle.Having read a previous solution I removed the base panel which was full of water.I removed the water and the machine started to work normally until the water slowly built up again On examination the water is coming from the large clear plastic unit on the left of the machine (from a small drain hole in the base).
Is this cost effective to resolve/ can I repair it easily myself ?
THANKS MODEL S4132WOGB/14
I had to key in the incorrect model no below as it wouldnt let me proceed using my model number.
  • deborahhewso Aug 09, 2008
    Small amount of water is leaking out of vent hole bottom right of plastic water fill chamer
  • bigcrab Nov 09, 2008
    Hi There
    I have a similar problem and have not had a chance to look at it in detail yet. Was there a fix for this one?
    Sergeant:
  • 351 Answers
Is the plastic unit a salt chamber,depending where the hole is you may have to replace it or is it an over filling problem,its hard to know without seeing it hope this helps you.Thanks Ian.
Posted on Mar 14, 2008
SOURCE:
Why is my countertop dishwasher stuck in drain mode(s), and won't initiate or complete any wash cycle?
normally if a dishwasher fills then pauses it is trying to read the water level if it fills again it is trying get a reading from the pressure switch when it cant determine the water level it will drain to prevent it leaking, however you should get a error code for this kind of fault which makes me think it is the control board which is at fault by not being able to read the sensor rather than the sensor itself not working
Oct 08, 2014 | Dishwashers
My Blomberg dishwasher wont stop drain cycle
A common cause of this condition results from water in the base pan. This may result from a leak in the dishwasher or the drain hose (to the sink drain) backing up. First check the base pan (the very bottom assembly that all other components are mounted within) for any moisture - this can be difficult as there are only narrow openings between the tank and the base pan; a mirror can help or you might have to pull the unit out from the cabinet to access the sides. If there is moisture in the pan this problem must be corrected as the unit is just trying to protect against water damage from a leak. If the base pan assembly is dry, look at the float assembly (behind the water fill valve) as insects or rodents can sometimes interfere with the proper operation of this sensor. That causes the control to think there is a water leak. When this fault occurs everything is turned off and the drain pump runs continuously to eliminate any water from inside the dishwasher.
Apr 06, 2013 | Blomberg DWT14210
Dishwasher stuck on drain cycle
Hello, If your dishwasher is stuck in the drain cycle there could be two reasons for the unit doing this. The first reason is you could have something clogged in the drain line or blocking the drain pumps impellar. If the unit is not able to empty the water out of the unit the drain pump will continue to try and empty the water. The second reason would be if you had a leak condition in which if you did have a leak the drain pump would continue trying to empty the unit to prevent the unit from leaking water outside of the unit. I would first remove where the drain line connects to your drain and inspect this area first if you do not find any blockages in this area you would have to de-install the unit from under the counter and check the oppisite end of the drain line to where it attaches to the drain pump itself. If you still found no blockages you would then remove and inspect the drain pump assuring that the impellar of the drain pump is spining and that there is nothing clogging the pump as well. If you have any further questions message me back. I await your reply
Thank you
Rick
Nov 28, 2011 | Danby DDW1805W Designer Series...
Stuck in drain cycle
Welcome to FixYa.
Based on your post, the good news...I can fairly confidently tell you It is likely nothing very serious, but the "resolve" requires some investigation on your part.
What the pump running continuous means is the timer has indicated a overfill.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. There will likely be water present.
With the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base, that should restore normal operation...it should be known that if you leave the unit for a few days, the water in the base will evaporate hence appearing as everything is fine again...if any other problem/leak does exist it will return.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump...
(it could mean a faulty drain pump so you'll need to pay close attention the next few times you run it)
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit and the continuous pumping is
letting you know to service or call for service to the unit**
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary.
Good luck.
Regards,
Macmarkus :)
Apr 26, 2011 | Viking DFUD042 Built-in Dishwasher
Bosh SHU66C06
YOUR UNIT IS STUCKIN DRAIN MODE YOU HAVE TO CLEAR THE WATER FROM THE BASE AND DE ACTIVATE THE FLOAT .you can remove the side panel an use a flshlight to see water in base. you probably have a leak in your hose.
Mar 03, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher: BOSCH SHE43 - pump keeps draining
Your dishwasher is stuck in flood mode. Bosch dishwashers are built with flood switches located in the bottom base pan of the dishwasher. The flood switch is connected to a rod that activates a small interlock switch. When water enters the base pan on a Bosch dishwasher, a Styrofoam puck lifts the rod, activating the flood switch.
When the flood switch is activated, the dishwasher will go into a no-fill, only-drain mode. The drain motor may also run with the door open to the unit. This is definitely a sign there is water in the base pan. This can be caused by the drain being clogged. There are two ways to fix:
1. You can uninstall the dishwasher and tip it forward to about a 45 degree angle to drain the water out of the base pan. (This is probably why Ian Bint's solution fixed the problem.) Be sure to put a towel under the dishwasher first so that the water is soaked up in the towel instead of going all over the floor. Once you've drained all the water out of the base pan, reinstall the dishwasher and begin a cycle. If it fills and runs, you are good to go.
2. You can also unplug the unit, then remove the kick panel at the bottom in the front. (It's attached with two screws.) Then get some old washcloths or small towels and reach into the base pan below the dishwasher to soak up the water. The pan is directly behind the plastic base panel rim. Once the pan is empty and dry, your dishwasher will no longer be in "flood mode" and will run properly.
If the base pan keeps refilling with water and the no-fill problem returns, there is definitely another issue, such as a clogged drain. At this point, you need to decide whether to invest in an expert evaluation by a certified Bosch repairman and make the necessary repairs, or buy a new dishwasher.
Jun 28, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Not starting wash cycle
Typically this means that there has been a water leak of some sort and there is water in the lower base pan. This is the large white plastic base that the dishwasher sits on.
If you remove the toe kick and look back past the fill valve on the extreme left side of the dishwasher about 6 to 8 inches from the front you will see a red stick that goes straight up and down. This is a mechanical linkage that activates the drain feature. Be careful as there are live connections here.
This stick rests on a round piece of Styrofoam that acts as a float. If there is water present it will cause the stick to lift and the dishwasher will go into drain. The source of the leak will have to be isolated and corrected. Most likely it is the fill float assembly as referenced at the end of this post.
If the stick is not in the upright position then there is possibly an issue with the switch mechanism itself.
You will have to pull the dishwasher out from beneath the cabinet and remove the panel covering the left hand side. If it is a full panel then there are a couple of screws holding it on from the front through side trim as viewed when the door is open if it is a half panel then it can be removed by removing the large torx screw on the lower right as seen when facing the panel.
If there is a problem with the switch then the entire mechanism should be replaced.
Try the following link to a picture for reference. It is upside down as compared to the installed one:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=935595&PPStack=1
Sep 17, 2008 | Siemens 24 in. SL34A006UC Built-in...
Indesit DV620 Dishwasher
You have a internal leak in the dishwasher...there is a safety float system in the base (below where you put the dishes in!) of the unit, which in the event of water in the base will stop the cycle and activate the drain pump continiously.... You will have to open the unit and find the leak. Don't know these models, but usually you have to remove side panels and front panel, drain water from the base and re-start....then check with flashlight where the leak is. Oshie
Jun 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwasher stuck on "drain"
not easy to fix - it has a leak. the tray at the base is full of water which ooperates a float which switches drain pump on. remove front panel at bottom front and mop out water or tilt backwards 45deg and water will run out. leak is usually main pump
Mar 18, 2007 | Neff 24 in. S5543X2 Built-in Dishwasher
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Neff 24 in. S5443X2 Built-in Dishwasher Logo
137 people viewed this question
Top Neff Dishwashers Experts
Ekse
Marvin
Marvin
vince
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
