Mother board upgrade
Need to know what maximum memory upgrade for microstar p4m 266 motherboard
  • 88 Answers
You can have a maximum of 4gb of PC100 or PC133 (DDR 200 or DDR 266).
http://www.via.com.tw/en/products/chipsets/p4-series/p4m266/
Hope this helps,
erch.
Posted on Mar 14, 2008
SOURCE:
I have 266 mhz 256MB RAM with intel D845 board. I want to upgrade it to 512mb or 1GB. Can you please tell me whether 333/400mhz will be suitable or where can I get it in hyderabad
hlo hyn you should get RAM 200/266 MHz of 512mb or 1Gb
below are the specifications your motherboard can support.
  • Two DIMM sockets supporting 2.5V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
for more info click this link http://www.intel.com/support/motherboards/desktop/d845gbv/sb/cs-012820.htm
Aug 18, 2011 | Intel D845GBV (BOXD845GBVL) Motherboard
Which RAM is suitable for Intel presscott 533 motherboard for upgradation
The Mother board only supports DDR1 333mhz or 400mhz
Maximum size of memory the board can read is 2gb in total
I would suggest upgrading to at least a DDR2 Motherboard
May 27, 2011 | Intel Motherboard
I have a P4M-800M/T2 Mother board that I need to install. Is it possible to get a wiring diagram showing the terminals for each connection.
Link to the motherboard manual:
ftp://ftp.fic.com.tw/motherboard/manual/socket478/p4m-800t/p4m-800t_a0_eng.pdf
Mar 10, 2010 | Computers & Internet
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Memory upgrade
The RAM limit depends on the OS, for example XP and vista 32-bit can only use 4GB max. you must check the current RAM you have to see if its DDR or DDR2, just take that to your local tech and then he/she/they will let you know. Then just buy some more RAM. **WARNING** you cannot use DDR2 in a DDR motherboard and vice versa
Mar 23, 2009 | Intel MicroStar MS-6166 Slot 1 Pentium III...
RAM memory: upgrade , Motherboard PCCHIPS M863 2 slot
Memory Support
• Two 184-pin, 2.5V DIMM sockets for DDR SDRAM memory modules
• Supports DDR333/266 memory bus
• Maximum installed memory is 2GB
This is what your looking for
Nov 01, 2008 | Computers & Internet
I dont know which drivers to be installed for audio .
Hi deepakbandi,
the model number you have listed is not 100% correct. If you found another site that shows two audio drivers, please list the link here in this post.
Or goto this VIA link & match the model number to the motherboard picture.
http://support.octek.com.au/Products/MainBoards/P4/VIA/mb_p4_v_08.htm
As you will see, P4M-266 is part of the model number. 8233 is part of the chipset.
VT8233 chipset. P4M266A-A4E Pentium 4 Main Board. There are two On Board Audio AC97 Drivers.
Download & install 2 channel audio (VT8233): http://support.octek.com.au/Update/VIA/V823x.htm
Mike
Oct 27, 2008 | Computers & Internet
Intel D845GBV Motherboard RAM
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
System Memory Features
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Suspend to RAM
  • CAUTION:
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Thanks
Iqbal
Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Microstar motherboard p4m 266
Hi Andy. Sorry I disappeared, it was way past my bedtime.
Your board will support 2gb of DDR266/PC3200 memory, although there are other considerations if you're using very high performance modules.
The board is still fully supported by MSI and you can find further information at the following address:
http://www.msicomputer.com/product/p_spec.asp?model=P4MAM-L
If you click on the download centre link on the left of that page you'll find drivers and updated BIOS if you need them.
Hope this helps,
erch.
Mar 18, 2008 | Computers & Internet
Open Questions:
SolutiOn**_++l~855-892-OO6O } ITuNES SuPpOrT NumBer usa NEw york***? Welcome to Apple Support in Sweden! We are here to help you with any problem you face with your Apple device. We have a team of Apple certified engineers who can provide the exact solution to your problem. Dial our toll-free Apple Customer care number Sweden and talk to our support executives. Wondering about the service we offer? Moving forward, we are not going to just babble on about the service we offer, like any other company out there. Better, have a look at our services... Apple Customer Support Sweden: Our Featured Services Apple has a wide range of products. With such high-end products, the amount of complexities also increases. Thus, we have a dedicated team of experts who can assist you with any issue on any Apple device. Here, is what you can get from us. Apple Mac Support Are you having a problem with your MacBook? Then you can come to our professional computer engineers available at Apple Support in Sweden. These are the most common issues Apple users face at least once: Can't install software from iTunes Unable to update MacBook to the latest version Not being able to perform disk partition on MacBook Pro Can't Connect MacBook to the Wireless Internet Connection There are lots of other issues as well with which we can help you. Call our Apple Support in Sweden and get the experts' assistance in no time.apple iphone tech support phone number iphone support number apple iphone phone number customer service iphone phone number customer service apple mac air support number apple mac air technical support apple mac air tech support ipad tech support number ipad technical support number apple ipad tech support number
Oct 15, 2019 | Apple Computers & Internet
SolutiOn**_++l~855-892-OO6O } ITuNES customer service [email protected]? Welcome to Apple Support in Sweden! We are here to help you with any problem you face with your Apple device. We have a team of Apple certified engineers who can provide the exact solution to your problem. Dial our toll-free Apple Customer care number Sweden and talk to our support executives. Wondering about the service we offer? Moving forward, we are not going to just babble on about the service we offer, like any other company out there. Better, have a look at our services... Apple Customer Support Sweden: Our Featured Services Apple has a wide range of products. With such high-end products, the amount of complexities also increases. Thus, we have a dedicated team of experts who can assist you with any issue on any Apple device. Here, is what you can get from us. Apple Mac Support Are you having a problem with your MacBook? Then you can come to our professional computer engineers available at Apple Support in Sweden. These are the most common issues Apple users face at least once: Can't install software from iTunes Unable to update MacBook to the latest version Not being able to perform disk partition on MacBook Pro Can't Connect MacBook to the Wireless Internet Connection There are lots of other issues as well with which we can help you. Call our Apple Support in Sweden and get the experts' assistance in no time.apple iphone tech support phone number iphone support number apple iphone phone number customer service iphone phone number customer service apple mac air support number apple mac air technical support apple mac air tech support ipad tech support number ipad technical support number apple ipad tech support number
SolutiOn**_++l~855-892-OO6O } ITuNES SuPpOrT phone [email protected][email protected] Welcome to Apple Support in Sweden! We are here to help you with any problem you face with your Apple device. We have a team of Apple certified engineers who can provide the exact solution to your problem. Dial our toll-free Apple Customer care number Sweden and talk to our support executives. Wondering about the service we offer? Moving forward, we are not going to just babble on about the service we offer, like any other company out there. Better, have a look at our services... Apple Customer Support Sweden: Our Featured Services Apple has a wide range of products. With such high-end products, the amount of complexities also increases. Thus, we have a dedicated team of experts who can assist you with any issue on any Apple device. Here, is what you can get from us. Apple Mac Support Are you having a problem with your MacBook? Then you can come to our professional computer engineers available at Apple Support in Sweden. These are the most common issues Apple users face at least once: Can't install software from iTunes Unable to update MacBook to the latest version Not being able to perform disk partition on MacBook Pro Can't Connect MacBook to the Wireless Internet Connection There are lots of other issues as well with which we can help you. Call our Apple Support in Sweden and get the experts' assistance in no time.apple iphone tech support phone number iphone support number apple iphone phone number customer service iphone phone number customer service apple mac air support number apple mac air technical support apple mac air tech support ipad tech support number ipad technical support number apple ipad tech support number
Computers & Internet Logo
69 people viewed this question
Ekse
Alun Cox
