Question about Compaq Evo N610C Notebook
Mainboard Problems Dear all, any of you have Compaq Evo N610c Mainboard, coz mine is broken in the power cord (the hole for adaptor) which cannot charge the battrey. if the price not to expensive, maybe i will buy it. thanks.
Mine broke also, so off i went to ebay and bought one. about $6.00 including shipping.
Posted on Mar 15, 2008
  • 55 Answers
Check ebay.
Posted on Mar 14, 2008
SOURCE:
My compaq Evo n610c my battery wont charge when on ac power.The light for when the battery wont go on.
sounds like your DC coonector came loose from the system board.it is a common problem with laptops,
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
here is how to repair:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 26, 2010 | HP Compaq Evo n610c Notebook
I have an old compaq evn n610c. I had some problems with it for a while where I had to wiggle the power cord a little to get it to power on with the cable. That worked for a while and then one day it...
Hello,If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack((DC jack)) is broken or loose.
If the power jack is broken you can replace it if you know few things about soldering;)
If the power jack is not broken but loose (not making good contact with the motherboard) you can re solder the old jack without replacing it with a new one.
Jan 20, 2010 | Compaq Evo N610C Notebook
Compaq Evo doesnt turn on.
When you plug the laptop to the power adapter, you should see the indicator led lit up telling that it has good connection to the ac adaptor. It wont turn on because either there is a loose connection to the power adaptor and hasn't been charging the battery, or the power adaptor itself is bad. Check the power plug with a miltimeter, it should be around 19 Volts.
Jul 02, 2009 | Compaq Evo N610C Notebook
LOSSING CD DRIVER COMPAQ EVO N610C
The problem with your system is that the Battery you are using is Faulty is either the current voltage spoilt it or may be is an old age battery
What you will have to do is to get another Battery that you will first of all Charge it well before usage ok. nice
Sep 23, 2008 | Compaq Evo N610C Notebook
Battery installer
My compaq evo n610c have the following problem: "103 circuit charge failure" and use power AC only.
best regards
Sep 19, 2008 | Compaq Evo N610C Notebook
Compaq EVO 610 startup
replaced mainboard solved.....
May 06, 2008 | Compaq Evo N610C Notebook
Compaq evo n610c battery not charging
Hello All;
I used to have these same problems. I replace my BIOS battery, which I know was dead, because all settings get reset when I unplug the power and remove main battery. You might not have to replace it if its still good. Back to the main battery problem, You have a good change of solving this by going into BIOS, and under Tools there is a Battery Calibration option. Do the calibration for the main battery and-or other optional batteries attach and it will most likely solve the problems. This calibration process will take a long time; 1-charge, 2-discharge, 3-recharge, so leave it over night or however.
There was a mention of updating BIOS. This could solve the problem too, because BIOS controls the charging unit. Also, make sure you have Compaq Power Management install on your OS, (download at hp.com).
One note: it will not charge if the battery is about 93% or higher. 93 is not exact, but close to 90%. so test by discharging to below 90% and it will start charging again.
If anyone tries this, leave a post of your success or failure.
Nov 20, 2007 | HP Compaq Evo n610c Notebook
Laptop not charging
Unfortunately on most Compaq/HP mobile devices the AC pin is soldered directly onto the motherboard. If the pin is severely bent of broken off then a service is required, usually to replace the motherboard. Having the broken off like then can actually create a minor crack in the PCB. Sorry for the bad news.
Nov 17, 2007 | Compaq Evo N610C Notebook
Power failuer
First off it?s a fairly risky proposition to plug a power adaptor from one device into another without making absolutely sure it supplies the correct voltage, amperage and has the correct polarity. Your laptop needs 18.5 volts, 3.5 amps, and approximately 65 watts to charge the battery. If you power adaptor is less that 3.5 amps it will shut down to prevent any damage so that?s probably what is happening. I would suggest going to the HP (now owns Compaq) or Ebay web sites and purchasing a replacement there.
Jul 24, 2007 | Compaq Evo N610C Notebook
Compaq Evo N610C Notebook Logo
73 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
