Question about ASUS A8N-SLI Deluxe Motherboard
Ram problems I currently own a asus a8n- sli deluxe board with a socket 939 chip. i was recently using corsair value select 512 ram in one slot. when i was able to afford another matching stick of ram i followed the specs to run in parralel wich the specs say either ram in the blue slots or black. But when i goto start up my pc i get a blue screen and my pc beeps every 5 seconds like an error msg. once i remove one stick of ram my O/S (xp) loads up no problems. i want to add more ram but am frustrated due to this problem. any suggestions.
  • Michael Ansnes
    Michael Ansnes May 11, 2010
    have you tried both sticks individually? Have you tried using both sticks together in both of the two color-coordinated slots (both in black or both in blue)? Have you tried one in each color slot - this will negate the doubling up of the RAM, so the realized speed will be the same as if there were only one stick of twich the capacity. Are both sticks the same speed and CAS latency?
    President:
  • 2,351 Answers
Your memory should be in slots A-1 & B-1
You Asus board uses the Award bios. The link posted below will tell you what your beeps are saying.
http://www.bioscentral.com/beepcodes/awardbeep.htm
In your case do as I suggested above. I have two working
A8N-SLI Deluxe boards & the memory works fine in A-1 & B-1 slots.
Good luck & best wishes!
please vote.............................
Posted on Mar 14, 2008
My old mother board a 939 socket took a dump i have gtx 285 evga video cards and x-fi fatality sound card im looking for a good bundle for this to go in to would like to stick with a asus board and...
Socket 939 Motherboards are pretty rare. Basically, if you find any socket 939 motherboard, the parts you have now should all fit precisely since there are only a few socket 939 motherboards right now on the market.
Here is one i found.
Mar 07, 2011 | ASUS A8N32-SLI Deluxe Motherboard
Is there a serial number on a the motherboard itself? I have asus A8N-SLI deluxe that is not putting out any display. And need S/N and dont have the box it came in.
You do not need the serial number to download the video driver, but you need the motherboard number, this is printed on the motherboard.
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Dec 16, 2010 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
What amd cpus does this mobo support? are there any that I can get off newegg for this mobo? and which sli connector should i get from Asus? like what length?
939 pin Athlon 64 X2 / Athlon 64 FX / Athlon 64 are the supported CPU's.
For the SLI connector, it's a 2 1/2 inch connector. (63.5mm).
Oct 26, 2009 | ASUS A8N-SLI Deluxe Motherboard
How do you install 4 sticks of ram? I have 2x 512mb and 2x 1gb. Do I put the pairs in the same color slots?
Yes, there are 4 slots, two colors....put the same ram configuration in the same color. RE: 1 GB sticks go in one color, 512 MB sticks go in the other.
Oct 25, 2009 | ASUS A8N-SLI Deluxe Motherboard
Problem adding Additional Ram to my Asus A8N SLI DELUXE system
Just because BIOS is recognizing the RAM doesn't necessarily mean it is usable. Also, ASUS recommends that you have the same amount of RAM in each bank. Another point they make is that your motherboard does not support double-sided DIMM chips.
I would refer to the manual for their specific instructions on proper RAM configuration:
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI%20Premium/e2435_a8n-sli_premium.pdf
If you are concerned that the memory stick might be bad, swap it out with one of your older ones, and see if your system boots and performs as it should. If not, then you know it is bad. My guess is that if you populate the memory slots with 4 gb, the system will recognize and make all of it available to you.
Cheers
Nick
Jan 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
2 x UltraDMA 133/100
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
ASUS A8N-SLI memory issues
imondeau, do you still have you're manual for the ASUS A8N-SLI Premium? Please turn to page 2-12 & 2-13.
Need the manual? Click the link below & download it.
http://support.asus.com/download/download.aspx?modelname=A8N-SLI%20Premium&SLanguage=en-us
The QVL; Qualified Venders List, shows all the tested memory for this board. Edge memory is not supported. This is why the Edge memory only runs by it's self. Once you add the corsair memory they clash because they are not compatible working together in this Asus board. Both sets of memory could work in another board. (Maybe)! What is also needed is if the corsair & edge DIMMs are SS = Single sided or DS = Double sided. How many chips on the corsair? How many chips on the Edge?
They must have the same total chips each each DIMM.
Edge does not sell memory compatible for the
Asus A8N-SLI Premium.
See this for you're self. Click on this link:
http://www.edgetechcorp.com/memory/
Mike
Jun 17, 2008 | ASUS A8N-SLI Premium Motherboard
Describe your ASUS A8N-SLI Deluxe nVidia video card
Yes, you do. Your board was built with the idea to use 2 graphic boards to get great video
NVIDIA® SLI™technology revolutionizes PC performance by combining multiple PCI Express GPUs in a single and scalable system! Gamers and hardcore enthusiasts know that dual GPUs mean increased, supercharged 3D graphics and performance
Dec 09, 2007 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
ASUS A8N-SLI Deluxe Motherboard Logo
112 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
