Question about Minolta magicolor 2300W Laser Printer
Cant get the toner replace promt to hightlight so I can replace it. Tried restarting
    Champion:
  • 214 Answers
Install status monitor to computer and from there you can choose change toner X and printer turns the cartridges in right place. or if you cant change that way, then under the front cover there is a switch, look the knobs on front cover and find it, it should be upper left corner, then you can rotate the cartridge manually.
Posted on May 27, 2008
My trio stealth will not go pass the trio screen. How do I fix this?
hold your power and volume up at the same time when it comes on release power button wait 5 sec release volume button you will see sevral ways to restart i had to clear data and ues factory restart just follow promts worked for me
Dec 11, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
I appreciate your quick response, but you wrote replace the hightlight switch, did you mean the headlight switch??????
As I have never heard of a hightlight switch I'm guessing yes, headlight switch.
Nov 14, 2014 | Cars & Trucks
My 14month old Daughter walked over and pounded on the keyboard in the space bar window key area....now my screen has power but no picture. I have tried reconnecting everything and restarting the comp. ...
connect the new keyboard and power on the computer and press f8 and
keep pressing upto safe mode will appear then hightlight on enable vga mode
and press enter your problem will be solved if not then explain the problem
in detail step by step
Oct 21, 2011 | Samsung SyncMaster 203B LCD Monitor
Replaced toner cartridge in MFC 9120cn still says "replace toner" and will not print. Tried the cartidge in another MFC 9120cn in our office and it works fine
Remove the cartridge, shake it then re-install it. You could also need to restart the printer after you install the cartridge. Just be careful not to shake any toner onto yourself or the floor.
Jun 20, 2011 | Office Equipment & Supplies
Hallo how to safe mode my hp pavilion dv4 1120us pc?
Hi kemisha, to get to the "Safe Mode" program.
You have to "retstart the computer."
Once you "hear to computer - Hard Drive {Hum}, and the "Fan" spinning!"
"This is the (Time you want to 'press the F8 button) several times quickly.
"It is important to do this before the "Prompt Screen" show up.
The {Prompt Screen} gives you the 'option' to go to the BIOS / CMOS setup.
The 'message at the bottom of the screen will read:
Press F2... or Press F12... for?
"Press the [F8] before this 'screen' appear!"
If you do this; the "window below will be 'present."
"Use the {Arrow Keys} to move, and "hightlight" the [Advance Options].
Once you have selected the "Safe Mode" option; press the "Enter" tab.
Now, the computer will "Boot into Safe Mode!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 16, 2011 | HP Pavilion dv4-1120us Notebook
Hi, just replaced my toner on the MFC-7220 and a message Toner Life End is displayed and will not print. I have tried 2 brand new toner cartridges. Thanks, Linda
Hi there !
Try this solution if it works, the memory of your printer still programs that your toner is end.
Try to make hard reset of your printer by turning off your printer for 5-10 mins, unplug the power cord as well and remove the cartridge toner. Then return back the cartridge, plug the power cord and then restart your printer. Then try to print again.
If displaying still this message, just press stop button to remove the message.
Also, if there is wiper for cleaning the toner cartridge everytime your put new toner, please do it.
This is what we do in your bother MFC printer when this message appears. Just restart the printer and keep pressing stop button when the printer starts.
I hope it helps you. Regards.
Jan 31, 2011 | Brother MFC-7220 All-In-One Laser Printer
Tried to clean off download,now it will not boot. a blue screen appear
try to boot on SAFE mode menu :
Restart, press and release the F8 key twice till a new menu promt select the option START UP SYSTEM REPAIR, and hit enter do the step by step process and will be fixed.
if this dont work, reinstall your OS
Mar 15, 2010 | Compaq Presario M2000 Notebook
After replacing fuser, I get "10-397 Restart Printer" I've tried six new fusers in five different printers and get the same error on every one. I've tried leaving the printer unplugged overnight and it did...
Have you checked that there is enough toner in the cartridges. It may help to remove the cartridge, shake the toner quite rigourously, replace, restart the printer. Also make sure that the paper is not cold or damp.
Oct 20, 2009 | Dell 5110cn Laser Printer
Changed Toner but its still saying "No Toner"
You may need to replace the drum this time. Usually after a few toner changes the drum needs to be changed to.
Apr 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
I just bought a web cam and i cant get to work
did you install the drivercd that came with your webcam?
when installing make sure that your webcam is not plugin into your pc...let the driver installation finish and connect your webcam when promted by the installation wizard....some some installation need your PC to reboot or restart for the installation to take effect..
hope this helps...
^_-
Jul 24, 2008 | Computers & Internet
Minolta magicolor 2300W Laser Printer Logo
187 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
