Question about Dryers
Whirlpoolm dryer Model gec9858hq0
The heater element turns on red hot for about 20 seconds then cuts out then will turn back on and off the whole cycle. The problem is the clothes don't dry as fast as they used to. Is this a normal operation. From what I can see ther is a thermal fuse & T-stat on the heater box and on the blower exhaust fan housing also. What should I replace or how can I test to see what is wrong?
Thank You
    Scholar:
  • 178 Answers
It is recommended that the airflow path from the lint filter catch, through the blower motor and out the exhaust pie be cleaned once a year for optimal airflow. I would check the airflow of the dryer to be sure no lint build up is obstructing it before I got into anything major. Feel free to contact me if you need further assistance.
Posted on Mar 14, 2008
I am trying to take the back off of my Whirlpool clothes dryer model LEQ8611LW1 to replace the heating element, but the back will not come off. How do I get to the heating element?
The dryer doesn't have a removable rear access panel and the heating element is accessible through the bottom front panel. Using a flat-blade screwdriver, locate and release the two bottom front panel clips approximately 4 inches from the sides.
Once the panel is off, locate the heating element housing is on the right side and remove the hex-head screw from the heater shield.
Remove the hex-head screw from the side of the heater housing and slide the heating element out then slide the new heating element in and secure it with the hex-head screw.
Note:
The heating element is not necessarily busted and needs to be replaced when the dryer fails to heat up. The first thing to look at is the thermal cut-off. It blows open and cut power to the heating element if the high-limit thermostat is faulty. Disconnect the red wire from the thermal cut-off and the red/white stripe wire from the heater. Connect the red wire disconnected from the thermal cut-off to the heater terminal where the red/white stripe wire is disconnected from.
Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards.
Apr 01, 2011 | Whirlpool Dryers
I have a speed queen electric dryer model number aem45300. problem the dryer runs but does not heat. We cleaned out all the area that contained lint. Is there a reset button for the heating element in...
There is no reset button, check yoru breaker, by turning FULLY OFF (somewhat forcefully off) then back on and test again.
All thermal limiters will auto reset when cooled...
Mar 04, 2011 | Speed Queen AES17AWF Electric Dryer
How to replace heating element on a 20 gallon ge electric water heater
First thing is to cut power supply off at the breaker box. Next turn main water to the water heater off. Once power and water is cut of to the water heater you are now ready to drain the tank for element removal.
Once water is drained remove wires from element and remove with socket if it is that type of element or 4 bolt type.
Upon starting putting it all back together remember to open all faucet's hot side to purge out all air out of system before turning power back on.
Water need's to be running out of faucet's and no air before cutting power on. If you turn it on before air is out of system it will damage th enew element you just installed.
Aug 09, 2010 | General Electric GE SmartWater Household...
Hot point model nvl333eyoww will ot dry clothes
your dryer has a belt switch go here to see it www.repairclinic.com once there enter your model # and it will show you your parts
Mar 10, 2009 | Hotpoint NVL333EY Electric Dryer
Bradford White Water Heater Model: M165R6DS13
Immediately turn off power to heater. One of two things has happened. Either: A. The electrical contacts in one of the thermostats has welded together, necessitating replacement of the thermostat(s). (in this case I would recommend replacing both upper and lower thermos) or B. The lower element has burnt through, and because there is 120 volts to the lower element at all times (it normally only heats when the thermos complete the circuit to give it a path to the other "hot", putting a full 240 volts on it) a section of the element will continue to heat up to the point where the break allows the current to complete it's path to neutral ground via the water in the tank. It can continue to heat until the high limit safety thermo trips out. (the red reset button on the upper thermostat)
If either condition exists, the high limit safety thermo should trip out power to the heater before boiling water, and thus steam, is produced. Even if the safety thermo should fail to cut power, the pressure / temperature relief valve should open, releasing excessive pressure. If that should also fail to open, due to corrosion or such, the water heater will create steam and can actually result in explosion, and possible injury or death!
Several years ago I came across one that was boiling and when I turned on a hot water faucet to relieve the pressure it filled the entire basement with steam. (I still shutter to think if I didn't catch that fast enough I or someone else could have been killed)
The most likely cause of your extra hot water is actually the lower element. After you turn off power to the heater, turn off the water supply to the heater, open a hot water faucet to allow air to enter the tank and drain the tank. Remove the lower element. A bad element is usually visually apparent. If it looks good, you would have to test it with an ohm meter. (should be about 20 ohms if it is good) Install new element, turn on water and fill until water flows steadily from the hot water faucet you left open. Now you can turn the faucet off and turn power back on to heater.
Feb 14, 2009 | LG (LRBC22522ST) Stainless Steel
Heating element won't stay hot.
Hello vsjant3,
I assume you cheated out the door interlock switch when running your test. If you did not, then the dryer will shut off when the door is open as part of the safety interlock system. If you did cheat it out and the element shut off after about 20 seconds, then you may have a problem with one of the temp sensors. When an overtemp condition occurrs, it disables power to the heater and it will shut off.. Other considerations are the wiring to the heater.. if you had a poorly tightened heater wire that was ok when first started and cold but when hot and passing current opened, that would also exibit the same symptoms. If I were a betting man, I'd say you probably have a bad temp switch. You can measure them with an ohm meter ( dryer unplugged of course).. or simply jumper the wires together to bypass one to see if it is the fault. Make sure you replace a bad sensor and do not leave it bypassed or you risk fire.
Here is a link to the wiring diaghram of your dryer.. http://www.pcappliancerepair.com/model-display.php
Hope that helps,,
Regards,
Rick
Jan 08, 2009 | Maytag PYE2300AY Electric Dryer
Dryer gets hot and turns off timmer still going,wont restart for approx 20 min
there is a thermal switch it cuts out the heater element when its at temp. also so has a thermal switch that cut out the unit if it gets to hot. there will be two thermal switches or a combined one. it will have 2 to 3 wire on it and is directly connected to the the drum. one of these is the problem the thermal switch is working as its cutting out the unit. to stop a fire.
Jun 18, 2017 | Whirlpool GEW9878LW Electric Dryer
The heating element turns off after about 2 mins
the most common cause for thermostat problems is lint build up. in the exhaoust duct, in the vent hood on the outside wall, in the squirrel cage fan
there is not enough air moving past the heater element to keep it within normal operating ranges, the thermostat cuts it out.
when the reduced air flow cools the element below max, it cuts in, overheats the thermostat and cuts out, for the whole timer cycle.
clear the exhaoust ducting, fan and vent hood of all lint
and try again
If there is too much overheating a firesafe device thermal cutout will trip and does not reset
locate the thermal cutout, a small device that looks like this 39ec5e4.jpg or this 9756eee.jpg screwed to the exhaust duct or fan housing. not resettable, test with ohmmmeter or battery and bulb,
the local parts guy will have the part, there are only a few for all the different dryer models
probably 75% chance of fix
Apr 20, 2008 | Roper REX4634KQ Electric Dryer
Whirlpool dryer GEC9858HQ0
There are 2 thermal fuses located on side of heater box, part # 279769. These come as a kit. One of the fuses if blown the unit will not heat at all, the other is a cycling t-stat. The other thing to check would be your venting in the wall. If its not clear in the wall, it will take extra time to dry clothing.
Mar 03, 2008 | Dryers
Open Questions:
Dryers Logo
112 people viewed this question
Top Dryers Experts
Marvin
Marvin
