Question about Kenwood VR-407 Receiver
Subwoofer shutdown The subwoofer has power, the green light is on, so it is not in the standby mode, but no sound comes from the subwoofer. I hooked up another subwoofer and it works fine. So the problem is in the sub itself. Is there anyway to "reset" the sub?
  • 7 more comments
  • pdoug Jun 13, 2008
    I even replace the subwoofer speaker which went bad. Still having the same problem - all the lights show 'ready' but nothing comes out, yet it will still rumble when going through the test mode
  • wizbri Nov 01, 2008
    Sorry, didn't mean to louse up this thread with the ill-posted "solutions."
    Basic question:
    If a sub is producing sound when a receiver is in test-tone mode, but not when that receiver is processing audio from other sources, is it safe to say the problem is with the receiver? Specifically, with the internal device that should be separating low frequencies and sending them to the sub output?
    And if so, what might a fix entail?
  • Anonymous Nov 27, 2008
    I have the same problem with the sub-woofer. what is the sollution?
  • nbgary Jan 11, 2009
    I bought the whole system from a friend, I listened to it work for over a year. After I set it up at my home I haven't had the sub work yet. Same as you guys, rumbles, green lights on, but nothing.
  • Anonymous Jan 13, 2009
    same problem with my subwoofer as above
  • Anonymous Mar 28, 2009
    Exactly as the other submittals; no sound from audio works only during the setup
  • rjrenegade Mar 28, 2009
    I have the same issue as the others Subwoofer not geting a signal from audio but works during the setup.
  • skeebknot Apr 05, 2009
    I have the same problem, but it does not rumble in test mode. Green light is on, and I hear it click on when I power on the receiver, but no sound from the subwoofer.
I'm having the same issue as pdoug: Sub rumbles in test mode, doesn't produce sound otherwise. Which makes me suspect it's the receiver itself -- the filter (or whatever) it is that should be separating the bass signal and sending it to the sub is not working. At least that's my guess.
Either way... this sucks.
Posted on Nov 01, 2008
I'm having the same issue as you guys: Sub rumbles in test mode, doesn't produce sound otherwise. Which makes me suspect it's the receiver itself -- the filter (or whatever it is) that should be separating the bass signal and sending it to the sub is not working. At least that's my guess.
Pairing my lsb316 sound bar and subwoofer
There is a button on the back of the sub that you need to press to complete the pairing..the led will be green when paired successfully or red if it is in standby mode
Feb 03, 2013 | LG Lsb316 Sound Bar With Wireless...
Is there a on of switch and is the green or red light to be on
There is no main AC power switch on the BU series; it's in standby mode whenever it's plugged in.
When playing music normal LED color should be green. After no signal for 10 minutes or so it will turn back to Red (Standby)
Nov 23, 2010 | Infinity BU-120 Subwoofer
No sound coming out of my Onkyo SKW-200 subwoofer
A subwoofer is just really a mono amp for the signal. As with all amps if you touch the audio section/parts with a small screwdriver, you should hear a buzz from the speaker. (Follow the audio wires to be certain you are on the audio section). This can be used for testing the amp section. If you get no buzz or noise (anywhere) at all then it's power supply could be playing up. If you have a multimeter you can test it looking to see if it is getting power. Allways suspect any part that is on a heatsink. Before removing any suspect you can put the part numbers into Google to see if you can get them and it will give you a clue to cost.
PS don't short any parts when you touch with a screwdriver, and don't put it on the power parts.
Feb 02, 2010 | Onkyo SKW-200 Subwoofer
AR SW-30 subwoofer doesn't switch to standby mode when off
Disconnect its input cable to see if a true lack of signal lets it go to sleep. If not, it has a bug. Otherwise, you probably have some sort of signal present on the sub cable.
Jan 17, 2010 | Audio Players & Recorders
No Sound for Velodyne VLF-1012
Sounds like your amp is damaged.
Jan 29, 2009 | Velodyne VLF-1012 Subwoofer
Monitor Audio FB212 buzzing
Apparently there is an issue with the 10000uF 80V capacitors. They are poor quality ones and the issue is that the dielectic forms hydrogen internally which eventually blows the dielectric out.
Dec 31, 2008 | Monitor Audio FastBass FB212 Subwoofer
Dont know how to turn it on
Just plug it in to an outlet. The lights on the front should be red (or standby mode). When it gets a good sound signal, it turns green (that's when it's on). It does not have a power switch.
Jul 10, 2008 | JBL PB10 Subwoofer
Fisher stm-t750w subwoofer
My have same too so don't worry about it
Feb 07, 2007 | Fisher SW-M750 Speaker
Blinking Led power light
I have a alpine MRP-M350 700 watts class D... i will ask if it can support 2 subwoofer a 1200 watts 10" JBL subwoofer?
Aug 22, 2006 | Alpine MRP-M350 Car Audio Amplifier
Kenwood VR-407 Receiver Logo
673 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
