Cisco and Lynksis Routers
I bought a 16 port router on Ebay,it seems to function intermittently ,while the Lynksis 8 port router does not seem to function at all.2 Gigs can I ship them to you for an estimate??????
    Scholar:
  • 141 Answers
Hi, you don't have to send it to me. I can help you with that. First we will check if the router is still working. Simply connect a computer to port 2 or 3 or 4 or 5, and lets see if the computer will get an ip address of 192.168.1.100, if it does there is a chance that this could work.
To checked ip address:
After connecting the pc to the befsr81, puss the reset button for 30seconds when the power is on, wait for 1 minute, reconnect the power. The power light of the befsr81 should be steady and the port light where you connected the pc should be lit.
Go to the computer. if pc is XP, click START then click RUN, in the open field type cmd then click ok, it will take you to the black screen. on the black screen type ipconfig, click enter. If the ip is 192.168.1.100 that means that we are in business.
I'l wait for your next post so i will have an idea on whaT IS GOING ON.
gOOD dAY
Posted on Mar 15, 2008
I have a Netgear WPN824v3. It seems to be functioning normally except I can't APPLY any changes. I get a "wait a moment" and repeated looking-up of routerlogin.net, but no response. Viewing the router's...
It seems that you need to reconfiguer router
please follow steps to reconfigure router
RESET THE ROUTER :
1. At the rear panel of the router, near the antenna, there is a very small round pinhole that contains the reset button.
2. Using a pen/pencil/paper clip, hold the reset button for 60 sec. so that the test light starts flashing.
3. After few seconds when the test light stops flashing Power cycle the unit.
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5.Login to the router (Username = admin Password = Password)
6. Click on lan ip setup under advance.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. click Apply.
17. Open up another browser window and try to access internet.
hope it will resolved your issue
Thanks for using Fixya
Jun 09, 2010 | NetGear RangeMax WPN824 Router
I have a new Macbook pro and when I attempt to set up a network I get a message that the connection is "timed out" I cannot seem to establish a network with either DLink or Lynksis Any suggestions?
Hi! Absolutely, the Router is OS independent. All you need is a computer with a properly configured Ethernet LAN adapter and a web browser to configure the Router. Any platform that supports Ethernet & TCP/IP is compatible with the router. You may need to provide additional hardware & software (i.e. Ethernet cards and/or software drivers) to ensure that all clients operate with the router.
By default of your mac computer it has already a buil-in LAN port same as other pc and it should be properly configured. just connect the cable from the mac lan port and the other end goes to your port 1 to 4 of the linksys or dlink router and it should give you an internet connection. if there is no internet access, pls check the ff:
1. Go to system preferences, network
2. It will pop up the network window
3. location set it to automatic
4. show - set it to built in ethernet
5. once you set it to built in on the lower portion it should set to tcp/ip and the ip address should show, once there is an ip address, you should get an internet connection, sabe or apply the settings
6. you are going to do the same thing if you are going to set the pc on a wireless connection.
if you have any querry pls feel to get in touch..
Aug 16, 2009 | D-Link DIR-625 (790069292637) Wireless...
My new itouch will not boot up. It just seems to be dead
Check the wall outlet where the Power Transformer is plugged in and verify that it has current by using a lamp or something like that. If ok, then...
Check the laptop battery for charge state. The indicater light should show full or good charge. If not, the battery could be dead....
If no current from the adapter, the battery goes dead in 2-3 hours of use.
Daniel Bonnici
Mar 27, 2009 | Dell Inspiron 1525 Notebook
Losing Ports on Linksys BEFSR41 v.3
Try a different wall plug power supply. The power supply that comes with this unit is very unreliable and unstable when loaded.
Dec 21, 2008 | Linksys EtherFast Cable/DSL Router
SMC ethernz problem
Typically you will connect your router to port 1 of the switch. Unless you have a port that is labeled WAN or Uplink. Then you would use that.
Daisy chain is when you have multiple switches connected to eachother. So it would be router to port 1 computers on ports 2-15, port 16 would connect to port 1 on another switch, and so on.
Jul 20, 2008 | SMC EtherEZ Networking Hub
Cannot aquire IP address through my Desktop using Lynksis Wireless Router
what you do is to reboot your desktop and everything will be fine or either unplug or disable and enable the status of the connestion. But the best way is to reboot the system. Good luck
Jun 29, 2008 | D-Link (DI-784) Wireless Router
Lynksis wrt150n .. setting
Log in to your router and select the wireless tab. Then click on wireless security. Set your security mode, encryption type and create a key that will be needed to connect to the router wirelessly. Administration tab should be right next to status tab.
May 14, 2008 | Linksys Wireless-N WRT150N Router
Router problem: Linksys router (RV016) not working
to reset your router there is a small button at the back of your router press it for a few second then start to configure again open your internet explorer then type the default af add 192.168.1.1 then enter then at the log in box type admin leave the password blank then set up your router by entering your modem ip address, gateway,subnet mask ,dns... to get the ip rigth clik the connction icon at the lower right of your monitor then click status then click support
Mar 18, 2008 | Computers & Internet
Lost data cable
Hi, there are currently 16 of them available on eBay
6 to 8 dollars shipped
Jan 29, 2008 | Olympus Stylus 770 SW Digital Camera
Router stops responding with red alert light turned on
I had the same problem since a bought it last week and I was going crazy. Install this firmware and everything will work fine:
http://booobi.googlepages.com/uperJerry_V2.8b4_Worldwide_A.rar
Oct 20, 2007 | 3Com OfficeConnect Wireless Router
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
