How to connect loptop pc to Hitachi 42 inch LCD
I have a bit of a problem because i used to connect my Acer loptop before on our hitachi L42VP01U 42 inch lcd tv but recently we move furmitures around including the tv & now i wanted to connect it to the lcd again but now i dont know which connections it is. I know the blue connections from pc & tv which i think is called dvi which has them two screws on the side they are connected in the right place. But now there's that other lead to connect which i have but not sure if that was the one i connected before, it has two connections red & white color on the other end which is to connect on the tv & the the other end of the connections is only one & it's black. is there anyone who can help me or even better show me a picture to how it looks like.
regards,
Alecs
  • 88 Answers
Sounds to me like an audio 3.5mm jack to L-R phono leads. The single jack connector would need to go into your pc's line-out port on the soundcard and the red and white phono connections on the other end go to either your television or home theatre system.
Posted on Mar 14, 2008
SOURCE:
No sound or picture on tv
haul to a repair shop and have it tested .
Jun 18, 2015 | Hitachi Gst Hitachi L42S02A 42 inch...
Hitachi HD monitor 42 inch ultra vision digital has bad colors is it possible to have a bad converter ?
its a projection,it is going to cost as much to fix as a used lcd hdtv!,turn it into a fish tank
May 11, 2015 | Hitachi 50VF820 Projection TV
Where can I buy a large base for my 42 inch Hitachi?
I guess you are looking for a MOUNT. Check for something like this at Amazon:
http://www.amazon.com/Mount-It-Articulating-Mount-40-Inch-70-Inch/dp/B002CTV060
Apr 25, 2015 | Hitachi Gst Hitachi P42E102A 42 inch...
Why does my Hitachi 42HDS69 42 inch Plasma TV have horizontal green lines across the screen? I have checked all connections and tried to tweek the color settings but nothing has helped. I went thru th
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 13, 2014 | Hitachi 42HDS69 42 in. Plasma Television
I have black line down right side of 42 inch hitachi lcd tv screen
You have a CCFL lamp that is failing in the panel, time for a new TV
Jan 22, 2018 | Hitachi Televison & Video
How to connect hitachi tv 42" to internet inorder
A computer and a VGA computer cable. The TV has to have the computer VGA hookup in the back of the set. Once hooked up you will need to get the proper input on the TV to VGA or PC.
Jun 23, 2011 | Hitachi 42HDS69 42 in. Plasma Television
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
Jun 24, 2017 | Hitachi UltraVision 42HDS52 42 in....
When i cut my tv on it cuts off i have an hitachi 42 inch
TVs don't like being cut. It breaks them.
If you meant to say "when I turn on my TV, it turns on for a second then turns off", call Hitachi.
Oct 12, 2009 | Dell W1900 19 in. HD-Ready LCD Television
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
Ekse
